New engine
#951
Posted 31 December 2012 - 20:40
I have silently read all you ideas for some time now and have been very impressed with your creativity.
However, the more I think about it, the more I believe the time of the petrol engine is drawing to a close and the future is electric. If you could apply your impressive mind to batteries .... ?
Posted 07 January 2013 - 03:42
http://fti.neep.wisc...00/lecture9.pdf
Of course, the acquisition of the MHD generator, which has electrodes inside..
To assist the electron reactions, a high voltage can be applied, as in TIG welding machines,..
Andrew
#953
Posted 07 January 2013 - 23:00
if we pipe with a radius of 10 cm heated, it will receive its length 1cm, 600 watts, which is enough for the house to its length of 20 cm or 12 KW .... ....
Extremely small heating stove diameter 20 x 20 cm, and everything we have in the house for electricity, including heating ..
In this case, the inner tube should have fins to really depriving heat of combustion.
Andrew
Edited by Feliks, 07 January 2013 - 23:06.
#954
Posted 09 February 2013 - 03:13
http://www.lasaero.c...le?id=R012B36S5
http://members.eaa.o...20Options).html
Andrew
#955
Posted 09 February 2013 - 09:30
#956
Posted 09 February 2013 - 09:40
Andrew
#957
Posted 10 February 2013 - 00:06
Edited by Greg Locock, 10 February 2013 - 07:09.
#958
Posted 10 February 2013 - 00:24
#959
Posted 10 February 2013 - 16:35
I think these use the reverse principle - using airflow over the device to generate a partial vacuum.
Yes, you right . Industrial processes : http://www.croll.com/
Of course, I see that freed the next ideas of something we are very happy. Introduced only basis to be developed. Now I am going to have such a number, which encourages the implementation of this idea. Venturi nozzle is one in the figure is the front surface of 3.14 x 2.1 x 2.1 = 13, 8 cm sqare.
6 pieces battery has 6 x13, 8 = 83.0 sqare cm. that is, it is only the surface 8 x 10 cm ....
A man riding a bicycle is at least a surface of 50 x 50 cm = 2500 sqare cm. Theory can obscure the surface without loss, for which he will be hidden. So such sixpack can theoretically put 2500/83 = 30 pieces ... without magnification face of the rider. So these 180 pieces of brass drums ....
Andrew
Posted 10 February 2013 - 22:01
You do realise that the energy recovered by the air motor will be at best a small fraction of the energy lost to aerodynamic drag of the venturis?
#961
Posted 11 February 2013 - 15:11
Or you could put a streamlined helmet onthe rider and gain far more.
No...
If on the brass cylinder with electric gyro cut the steps for air, we get a full hybrid-electric-air drive ...For sure the electric motor would be well-cooled, which contributes to the miniaturization ..
Andrew
#962
Posted 13 February 2013 - 11:03
Originally Posted by trumpy81
That's an interesting concept Andrew. My only concern is do the venturi's produce any sound at all. I would imagine that at certain velocities they would 'whistle', it might be good for scaring off dogs though ... lol
So it may be true. Just how will "whistle. Such a musical instrument, bearing a mouthpiece similar to trumpet mouthpiece seems very strong, low sound ... and the number of watts = 0, but the glass vibrates around ...
http://en.wikipedia.org/wiki/Tuba
However, I definitely prefer this art to a smaller nozzle Venturi ..
https://www.youtube....p;v=1hHi6QuksNA
Regards Andrew
#963
Posted 02 March 2013 - 03:29
These old-style sausages only reach about 0.2 atmosphere vacuum. A new way of sucking exhaust ejector via a venturi is able to achieve 0.8 atmosphere vacuum. We can add it to the engine power of about 30% if the well will adjust camshaft....
As a result of additional air into the exhaust also added clarity will improve as a result of combustion gases....
The company has also achievements in the treatment of gases, both solid particles and NOx ..
For large trucks and marine engines, you can give the water cleaner exhaust. Then, no longer see the black smoke from the exhaust pipe truck. A vacuum is created and injected via a closed loop water will improve engine efficiency as a significant ..
Regards Andrew
#964
Posted 04 March 2013 - 11:34
Or Euro 10 standard
http://www.croll.com...etscrubbers.pdf
http://www.croll.com...ns_article1.php
Andrew
#965
Posted 04 March 2013 - 23:04
All the drawings of the exhaust venturi gadget have disappeared? It is an interesting idea but I am not sure if applying a suction to the exhaust would actually improve the performance of the engine.
#966
Posted 04 March 2013 - 23:45
It might - but the power required to drive the suction system would be several times any power gained. Damn that "perpetual motion" rule.All the drawings of the exhaust venturi gadget have disappeared? It is an interesting idea but I am not sure if applying a suction to the exhaust would actually improve the performance of the engine.
#967
Posted 05 March 2013 - 21:46
No. If a traditional single exhaust with long pipes, that's to do it just to increase the engine power ... Here, instead of a long tube relatively very short venturi nozzle and the air can be let in only when you need full power jet. Certainly the driven venturi vacuum in the air is much large than the normal long pipe ..All the drawings of the exhaust venturi gadget have disappeared? It is an interesting idea but I am not sure if applying a suction to the exhaust would actually improve the performance of the engine.
It is just as if it was "Turbo" on the exhaust side...
Andrew
Edited by Feliks, 05 March 2013 - 22:00.
#968
Posted 06 March 2013 - 04:20
Andrew
This is a bit off the subject but in Oz in the 1950's there was a gadget that it seemed every second car on the road had. It was called the "Kleinig Extractor" and it was a venturi type of arrangement that was attached to the very endof the exhaust pipe. The idea being that the wind from the car's speed went into the venturi and sucked on the exhaust pipe end. It was claimed by the makers to give an increase in fuel economy - but I think it was generally accepted that it had no measurable effect.
Which reminds me - the TV has ads on again for the "Hiclone" (I think it's called) - I doubt that it does anything either.
#969
Posted 06 March 2013 - 11:15
I think the most important thing is for you to learn to distinguish between "witches" of scientists ... But it takes many years of reliable acquisition of knowledge, at least at the level of a scientist ... Then you can prophesy and appropriate examples to quote...
If you think on that "sausage" in the formula 1 is the only gadget...
Andrew
#970
Posted 06 March 2013 - 23:01
Very true.I think the most important thing is for you to learn to distinguish between "witches" of scientists
#971
Posted 07 March 2013 - 10:58
Very true.
Living in Krakow, We had to learn to verify the information from the newspaper "Pravda" in Moscow.
"Pravda" in translation is True....
Unfortunately, many people with so-called "scientists" cocking his nose, he went to school for two years longer than others .. I think they can start the reaction, which does not know how to stop the problem and leave others to thousands of years ... Here is an example of how "Scientists" invented a new method of cooling the reactor ..
http://www.guardian....r-reactor-video
Here is a "right" to verify..
I think that was told to us that found a new way to dispose of nuclear waste, after which longer even leak out, then they will not be anyone to harm the health claim ... If so, I think that now they should accept nuclear waste from all over the world and take care of after them .. Because unless the Columbia River has some mysterious properties of neutralizing radioactive leaks ....
http://edition.cnn.c...?iref=allsearch
With this in mind, I think that sometimes "witch" has more common sense than 1000 scientists, and you can hear it, how has your best interests in mind ..
Andrew
#972
Posted 08 March 2013 - 19:37
http://en.wikipedia....urg_hemispheres
Andrew
#973
Posted 27 March 2013 - 00:19
http://www.youtube.c...player_embedded
But why in such a complicated way ...
In my design variable compression ratio is achieved with only ONE hydraulic device, a changing angle between the crankshafts ....
Here the results of the calculations excel...
Even in all 16 cylinders at a time....
Andrew:smoking:
Edited by Feliks, 27 March 2013 - 00:26.
#974
Posted 27 March 2013 - 12:39
#975
Posted 01 April 2013 - 13:21
Andrew
#976
Posted 15 April 2013 - 22:44
http://www.new4stroke.com/volume.zip
But already you do not need a program to design cams...
Edited by Feliks, 19 April 2013 - 23:53.
#977
Posted 24 April 2013 - 23:58
http://www.britannic...power-generator
From other sources I found out that the biggest difficulty was to obtain high stability of our power. But today, thanks to patent my friend, who at the end of the 60 lived in Krakow and was in the same club as me HAM. Station club had prefix SP9KHR and I ran as the transmitter of surplus U.S. - BC-610. My good friend, Tadeusz Bator, efficiently assisted me in this work and launched a SSB transmitter power of 1 kW at the club. A colleague at the beginning of the 70 he emigrated to Sweden. There, in 1982 received a U.S. patent on the device that we now effectively helps in achieving sustainable energy sources .. This is the patent as the inventor:
https://docs.google....s/US4371917.pdf
Now this version of the microprocessor is very popular, and we can easily obtain current, high stability of the MHD generator. It's an old idea with a new face ..
To be economically competitive, a coal-fired power station would have to combine an MHD generator with a Termionic generator in what is termed a binary cycle. The hot gas is first passed through the MHD generator (a process known as topping) and then on to the termionic of agenerating plant (the bottoming phase).
The third system is a framework for jet engine jet gases coming from the double thermal cycle. All three components are mounted, as in the classic treadmill, and drive generators disposed on the rotation axis, or to the external parts of the treadmill....
An MHD power plant employing such an arrangement is will known as an" open-three cycle".
Andrew
#978
Posted 29 April 2013 - 10:56
http://www.creative-...rg.uk/duck.html
http://www.creative-.../wavetanks.html
http://www.youtube.c...p;v=bEfrtAOMuvk
Now, if someone wanted to work on the MHD and plasma must be provided with the device ..
http://en.wikipedia..../Langmuir_probe
Andrew
#979
Posted 01 May 2013 - 13:32
For me, more expressive than the original ..
:wavey
Posted 04 May 2013 - 13:22
http://edition.cnn.c...arebar_facebook
To calm the nerves
http://www.mp3god.pl...k-alber-natalie
Andrew
#981
Posted 04 May 2013 - 14:45
And now for something to relax, guitarist Bartek is the son of my friend, the guitarist, who died in 2008 ...
:wavey
That was wonderful.....thanks for that!
#982
Posted 04 May 2013 - 17:28
Edited by Tony Matthews, 04 May 2013 - 17:28.
#983
Posted 04 May 2013 - 23:59
Yes, thanks Feliks.
Well, how are you like just another Katie but with another guitarist, .. I notice also like ..
#984
Posted 11 May 2013 - 00:19
http://www.youtube.c...p;v=nZGCZlsYMO8
Andrew
#985
Posted 12 May 2013 - 07:42
That is superb.
#986
Posted 13 May 2013 - 09:04
That is superb.
Thanks Gruntguru, it should be used for improving our imagination....
Poor Chesy ... but it shows its superiority to the limited "scientists" ... and this is the third time ... supposedly to three times a charm .. Thanks to this picture, which shows the ineffective actions planned by the "scientists" in order to provide current, also see "professional" electricians employed in the nuclear power plant ... Namely, you can see at a glance that the cable mesh used here are not quite matching the power supply wire (as you can see, 50 mm2) currently used for this section are structured differently (with a thick tube symmetrical to the cable mesh). These were in the last century used by Tesla .. Clearly, the narrowest cross-section of wire mesh at its base there is a section of 50 mm2 ..... It is not surprising that Chase wanted to warm up ... Also, a method for isolating the tight mesh wire with electrical tape like electrical work in villages Congo ... a little more, having reserved electricians are now using special thick-walled heat-shrinkable tubing, in addition to the printed kind of phase / zero to Chase know where, do not warm up. ..
50 so it looks professional:
Further lecture on making t-shirts cable: For the a / can clearly see the individual copper wires "clamped" cable ... and so it is a place which way you get any oxygen and salt until the end of the cable, allowing the coastal climate Fukushima wires and accelerate the oxidation deterioration of the contacts between them. And no insulating tape can not be his shield. Only, the use of appropriate wire mesh, and their adequate protection sleeve shrink, they are able to secure a single contact wire cable loop cable properly to protect against the ingress of oxygen and excess salt ... Not to mention that if rats wandering Chessy, made in the visible copper wire in your pee group, the quality of the contact even in the two days it may just aggravate that there will be a fire ... But that "Science" rather precludes such events. Therefore we "We teach" how to "anencephaly" scientists "provide us with your competence and infallibility and demand high salaries for their very competent action ... and apparently contacts in May another 40 years to work until there is the power ... I guess the other is just ...
Andrew
#987
Posted 13 May 2013 - 19:20
Well, to forget about all the nuclear horrors, it's still Kate, but flex more entertainment...That is superb.
https://www.youtube....p;v=MViUFh814T4
#988
Posted 15 May 2013 - 04:23
#989
Posted 15 May 2013 - 09:10
whether it's an intake or exhaust, a venturi or extractor can only produce a max pressure differential equal to the ambient pressure. There can also be greater pressures created by inertia effects of the fluid mass flow. Ultimately, it boils down to how much energy is transmitted to the gas flows.
Yes, indeed, you have provided true depending on ..
But he and others're trying to improve the efficiency of its windmill, however, take advantage of them .. I think that the way indicated by me are true and fair things develop ...The maximum value of the vacuum, indeed can not be greater than one atmosphere, but be aware that he can make a tornado, or hurricane, where the pressure difference is only a few dozen hectoPascal .... Because it is important that quantity possible we can in a relatively easy way to get ..
And keep in mind that the turbine engine with a power of 100 KW flows only 1 KG per second ( 1 m^3), and it produces such great power, with its relatively small size
http://sheerwind.com...ow-does-it-work
Andrew
Edited by Feliks, 15 May 2013 - 09:23.
#990
Posted 19 May 2013 - 09:17
The famous experiment played in Krakow. The horses did not give advice...
http://wiadomosci.on...f9aVyM.facebook
Andrew
#991
Posted 24 May 2013 - 01:14
Still there is no such thing as a free lunch.
In this case, I agree with you that someone is trying to deceive you, however, that free lunch orally .... ....
Forever Electric car ( by wind force generator) - YouTube
But how do you replace the propeller, such as my amplifier, it obviously will not be quite as much as the delightful film ... get it right?
Certainly amplifier and give more energy propeller.
Yes, this dinner is certainly a lot cheaper ... It's just a matter of when the price will be less than zero....
Andrew
#992
Posted 25 May 2013 - 12:20
Andrew
#993
Posted 28 May 2013 - 10:26
You can see that at higher speeds, the propeller can be very small ..
As you can see the propeller drive in serious applications
So may be small and of recognition, a lot of power to control such a large fighter, because at higher speeds the propeller is more efficient. Its efficiency according to the speed increases up to the third power in the dependency ..
Andrew
#994
Posted 28 May 2013 - 14:39
Feliks - only 7 to go to make the magic 1000.
#995
Posted 28 May 2013 - 17:51
Well, one more to the magic 1000 ...
Full view of the Viggen
right on the apron in front of the hangar, and yet it was the Museum of Aviation, I played my models on a Wire ... I made a nice deck Tarpan plane ... Sorry did not start, bi was too small only 2.5 cc engine and was required 5 cc .. but this did not have .. I could only dream of ..
Andrew
Edited by Feliks, 28 May 2013 - 18:04.
#996
Posted 29 May 2013 - 06:21
Five to go.
#997
Posted 29 May 2013 - 09:58
Feliks - With regard to your idea earlier about applying venturi suction to a turbine - maybe you should try applying the venturi vacuum to a 1950's car windscreen vacuum motor. I have no idea how well it would work (or if it would work at all) - but I can see that a venturi-and-motor (whether turbine or positive displacement") could possibly have some advantages over a wind turbine.
Five to go.
Oh, yes, of course
On another forum
If you had even a basic understanding of engineering, you wouldn't feel that way.
Feliks has the sort of naive ideas that "environmentalists" have when they make sweeping generalizations about how doing X will save the world.
These designs are hair brained and outlandish, at best, with very little utility in the real world.
That small prop on the airplane is a small generator that powers the hydraulic and navigation software. Yes, when you are flying 500mph, you can generate 10hp by coasting. You WILL NOT power an entire city with the same principle and a 1' dia prop unless you are traveling at the speed of light.
I would LOVE to see some actual calculations. Math is math. Anyone with math skills should be able to read and interpret his calcs. Post those and I'll give him some credit. Until then, this guy is yelling the bible aloud from the street corner.
All right, we'll use the math ...
At the beginning of your data correct some of the aircraft speed. If it is to be an emergency control of the airplane, that's for sure, it must be to enable the load, ie the propeller must give sufficient power, as you have specified about 10 HP power control ... It's just that the aircraft lands at a speed of 220 km / h, and it must work perfectly yet. Propeller has a diameter of about 30 cm.
part no 9 :
http://www.temporal....iggen_final.pdf
Well now using venturi calculator, count the venturi nozzle, which is in its narrowest point is 300 mm, so that the propeller be able to run when inserted into it. As you have specified, at the speed of 220 km / h it will give the 10 Hp.
I asked to facilitate the original input parameter of the nozzle diameter to 1000 mm (1m). her throat identified on the 300 mm. There's a quiet propeller would seem to shoot ... Here are the results of this calculator venturi ... input speed is 25km / h and the speed of the throat is 284 km / h, which is significantly more than the 220 km / h landing ... So we should calmly from the propeller to obtain these 10 Hp power ....
Now you should do such an experience (or as you have enough imagination you can not do): You have to cut out some plywood, or flat plates made of plastic, and cut out the circle with a diameter of 1000 mm (1m). So cut the wheel, you have to fasten themselves to the chest or his back. It should then get on the bike, and try to accomplish this on a bicycle pedaling speed of 25 km / h. I think it lets you easily measure .. A man riding a bicycle is not achieved by 1 Hp ... but quietly get this rate, the pinned wheel with a diameter of 1 m.
This wheel has the same, or even greater air resistance as a venturi nozzle with a diameter of 1 meter original input. But this gives us the nozzle throat, as he You noted about 10 Hp, because in the throat, the air flows at a rate ~ 10 times greater than the speed of Input, or 280 km / h.,
And the propeller can give us the 10 HP. It is 10 times more than we can give strength to propel the bike with the circular wheel strapped to us. I think that in order to achieve a speed of 25 km / h, we do not need more than 300 watts .... So, if the bike mount the front section of the nozzle 1000 mm, it will get the 10 Hp in her throat on the propeller and drive the bike with the nozzle to a speed of 25 km / h, we only need 300 watts ..
I think the only thing I have left is to wait for your points ...
Andrew
#998
Posted 01 June 2013 - 01:09
And here the story framework:
http://en.wikipedia....Ram_air_turbine
stuff here alternators produce. At the same time, such as is sufficient to drive the the bicycle. It gives as much power as the guy who races
http://www.basicaircraft.com/
http://www.basicairc...r-bae-14-28.asp
Now matching jets such dimensions alternator, it will have the characteristics needed to drive the bike (and other vehicles as well).It will have only 600 mm outer diameter ..
If the resistance front will be much smaller than the flat full circle. In laminar flow, may have only 15% of the value of such a flat resistance, as it has air wing profile....
Andrew
#999
Posted 01 June 2013 - 04:25
Without researching on the internet etc. - I doubt if the Me163 was the first with a ram air turbine. I think they were fairly common on 1930's biplanes.
One to go until the new minellium.
Edited by Kelpiecross, 01 June 2013 - 04:28.
Posted 03 June 2013 - 02:33
http://ieee.rackoneu...resentation.pdf
Somehow strange lately rats have an impact on the formation of electrical energy ... Fukushima say that this mortal terror, and UTC are saying that this life .. Maybe show us in which direction we should go ...
Andrew
