Who can identify this Ferrari?
Posted 10 May 2003 - 20:05
This is my first post here and I thought you could help me a little with identifying this Ferrari...
This SHOULD be Alberto Ascari, July 19, 1952, Silverstone.
Only record I can find is that that is the day of the British GP and that Ascari drove a # 15 Ferrari 500 that day.
This is NOT a Ferrari 500...
Could / should be a 375 Formula Libre...
Who can enlighten me?
Jack Habits
Posted 10 May 2003 - 20:38
Posted 10 May 2003 - 21:54
Posted 10 May 2003 - 22:09
The same car is pictured on page 378 of Motor Sport, August 1952. As David says, it's in the FL race supporting the British GP.
It is described as "the car which Ascari took to Indianapolis".
Posted 10 May 2003 - 22:53
David:
Any idea which other meeting it could be with Ascari driving it? It should be the UK as that is most defenitely where the picture was taken (98% sure it's Silverstone)?
Michael & Vitesse2:
Looking up "the car that Ascari took to Indianapolis" on barchetta.cc, it should be a "375 Indianapolis", S/N 01 (the only 375 Indianapolis that Ascari actually drove at Indy).
However, there are no records that that car was ever in the UK so what is it doing at Silverstone?
http://www.barchetta...375.Indy.51.htm
Vitesse2:
Would you be able to email me a scan of page 378 of Motor Sport August 1952?
Best,
Jack
Posted 10 May 2003 - 23:08
Apologies for the rusty staple!
Posted 10 May 2003 - 23:10
Posted 10 May 2003 - 23:42
Ferrari weren't represented at any other British FL race in 1952 or 1953 AFAIK - GAV and EF tended not to race each other in those two years .....
[edit - except Boreham, which was F1 rather than FL! Vandervell apparently wanted £1000 starting money - the Daily Mail refused to stump up]
The figure 1 may look different, but I think that's just the slightly different angle and lighting. The 5 looks identical to me. And you can even make out the circlip holding the exhaust on in both pictures.
Posted 11 May 2003 - 00:01
Posted 11 May 2003 - 00:05
Posted 11 May 2003 - 00:13
Posted 11 May 2003 - 00:14
Vitesse, you're more than forgiven for the rusty staple!
Do we tend to agree that "my" picture was taken at Silverstone?
I have replaced the cropped image with the full-size scan.
Jack
Posted 11 May 2003 - 00:18
Littlechris:
Boreham could be true. Villoresi raced and won with a "375 Indianapolis" there on August 1952 but he used race # 17 and Ascari did not particpate in that race.
Jack
Posted 11 May 2003 - 00:20
www.atlasf1.com/bb/showthread.php?s+&threadid=33559
Posted 11 May 2003 - 00:38
1 It was run in torrential rain.
2 Villoresi's car was further modified, with another air intake just forward of the cockpit.
3 No mention of Ascari in the race report.
Posted 11 May 2003 - 01:31
I think it's different, and it can possibly be explained...
Remember Roger's discussion about the red numbers on the M-Bs at Aintree and Silverstone? Well, those RAC rules about race numbers probably demanded sans-serif digits (as did the Australian rules that were copied from them)...
In that case, it's possible that the numbers had to be fixed either after practice, or even after a pre-meeting practice day where perhaps Ascari drove the car?
Posted 11 May 2003 - 01:40
Posted 11 May 2003 - 06:38
Originally posted by Vitesse2
Boreham:
And he was in Germany for the Grand Prix.
The week following the Silverstone race, Autosport wrote:
"Contrary to popular belief, the 4 1/2-litre Ferrari which Luigi Villoresi drove at Silverstone was not one of the Indianapolis cars. It was a new experimental car with rubber-controlled rear suspension. Excesive bouncing made it difficult to handle, but it is said to be the most powerful Ferrari ever built"
I know nothing of this rubber-controlled rear suspension.
Posted 11 May 2003 - 07:27
It did have a transverse leaf spring, didn't it? Or that model did? Bump stops along the spring could give a rising spring rate I guess.
Posted 11 May 2003 - 10:25
"The new 4 1/2-litre cars retained the same suspension system as before, but incorporated a tubular ruber-block between the lower front wishbone and the chassis frame, the main transverse leaf spring being reduced in thickness, allowing the rubber to assist be being compressed."
Presumably the Slverstone car was similar.
Posted 11 May 2003 - 10:50
Jack
Posted 11 May 2003 - 11:21
Posted 11 May 2003 - 14:29
Jack
Posted 11 May 2003 - 15:47
The car is heading left to right which suggests it must have been taken from the infield looking towards the spectator areas, but even then there was a safety bank around most of the circuit periphery. An exception was the section from Club Corner up to Abbey, but if this was during the meeting one would expect to see at least some spectators there in the background.
Posted 11 May 2003 - 16:31
Jack
Posted 11 May 2003 - 16:38
Posted 12 May 2003 - 17:39
Posted 12 May 2003 - 18:25
