Dyno testing... speed relevence.
Posted 20 February 2002 - 23:50
I figure it would lead to a more accurate measurement of the vehicles actual power at certain speeds, you could perhaps accomplish this by taking a large blower and direct it toward the airbox. The only reason I thought of this, is becaus I saw the TF cars running a fuel tank vent that produces 14psi at top speed into the fuel cell so the power doesn't drop off at the end of a run.
Posted 21 February 2002 - 00:31
Posted 21 February 2002 - 00:37
Posted 21 February 2002 - 03:32
Delta Pressure = 1/2 (rho)*(Velocity_1 - Velocity_2)^2
Assume: Isentropic compression, V_2=0 (not correct, I know, but close enough), STP
200mph=89.41 m/s
I get a delta P of 4815 Pa. That's 0.6984 psi. So that's a 1.0475 pressure ratio (ie- a 4.75% increase). While there quite a few things not taken into account, this will get us close. So assume some fudge factor, and say 3% increase, to be a bit pessimistic. So, Wolf, your estimate seems quite good. However, I would say that these guys would sell their dear old grandmother into third world slavery for a 4% increase in pressure ratio. For 10% they'd probably be willing to start whoring out their ma. If I was in charge of dyno operations (for an F1 engine), and some underling told me that he couldn't be bothered to figure out something to simluate this, his ass would be out the door. Feel free to point out any corrections to my calculations.
Posted 21 February 2002 - 16:48
Posted 21 February 2002 - 17:04
Posted 21 February 2002 - 17:25
I understand that airbox designs have been developed more by experimental trial and error than by a feeling of actually understanding the aero goings-on inside. Of course CFD simulations have been done, but the intermittant nature of the intake process as well as the resultant resonances, harmonics and standing waves all dependant on both vehicle speed and engine rpm makes modeling of the behavior of the flows within near impossible.
Don't forget as well that there is a neccessary tension between the aero boys doing the chassis trying to get the shape of the airbox optimised for external aero, and the engine crew trying to optimise there for feeding the engine. One can imagine that at times these aims run at cross purposes to each other.
As an example of how poorly understood airbox aero is here's a snippet from John Judd's Engine Developments Ltd. General Manager Stan Hall on the subject: "Even now I don't think people really understand what makes a good airbox; there are wide variations around. I know that Renault spent a vast amount of money trying to analyse the problem, but as I understand it they didn't get a good answer as to what makes a good engine airbox design.
"There are all sorts of strange things going on. It tends to be more of a problem at places where there are high speeds, such as Hockenheim. You can get a situation where on one particular lap on one particular straight, the driver shifts up normally but once he hits sixth the car just won't go on accelerating, it might even slow down. The problem doesn't occur on the next lap. The other car doesn't do it. Bring the car in and change the airbox for one nominally the same and the problem goes away...
"Inside the airbox are maybe little sharp edges here or there, or maybe it's the driver's head position on a certain lap. It is a weird thing. It is all to do with resonances and harmonics. I think it is to do with the natural frequency of the airbox itself, the pressure and volume of air inside it- all things that are very difficult to simulate."
My father, who is currently writing a book on the physics of musical sound, suggests that insights into the behavior of F1 airboxes might be gained by viewing the airbox as a 40-reeded musical instrument!
Posted 21 February 2002 - 18:06
anyone got any info on teams design's & work?
jezz
Posted 21 February 2002 - 18:46
Posted 21 February 2002 - 19:47
Posted 21 February 2002 - 21:37
Scoops on car hoods just look nice, but dont do anything. Compressibility factors in airplane external design only arrive at near .75 mach. WWII airplanes never had this taken into account in their airfoil design. Intake design for supersonic aircraft take compression gain(super sonic) into account to slow air to sub sonic velocities before entering the compressor, so those'Barge boards' or splitters are there for very different reasons than on a F1 car. The max speed of a F1 car is the speed that these airplanes fall out the sky, so their aerodynamic considerations are vastly different. Even Lears have Vref speeds at over 140kts at full gross.
I often wonder why they have that airbox on top at all. Surely the increase in drag offsets any power gains. When i first read about Renaults wide V, it stated that one of the main reasons was to illiminate yhe overhad airbox and to get denser air down the sidepods as the inlets were between the cams and the exhaust would be less restrictive coming out the top.
I remember the 61 Ferrari F1 (shark nose)car and the LM Ferraris of the same year had identicle engines except the LM car was detuned so as to run for 24 hours. Turns out, by having no intake scoop or airbox, and a different exhaust system, the detuned engine produced more HP. Maybe the airbox is there for traffic reasoms. I know NASCAR cars loose HP if they draught too close. The base of the windshield is the highest pressure. Educate me.
[QUOTE]Originally posted by desmo
[modeling the of the behavior of the flows within near impossible.
Posted 22 February 2002 - 00:22
Desmo, I imagine that the transient modeling of the airbox is much more difficult than steady state performance modeling. With a transient there are residual waves, that are harder to predict, and their timing of when they hit the valve, will depend somewhat on how fast the engine's rpm is changing. One of the other problems that I am aware of is modeling large and complex volumes like this, in engine simulation packages, like wave or gtpower. More subvolumes are required to accurately predict wave travel. Even, with more subvolumes, they don't handle spherical wave travel very well. These subvolumes don't work well with bigger volumes, thus some models are linked to a CFD package, where the CFD and engine simulation package hand off data to each other. That way the airbox can be done in CFD. This can get isanely time consuming, though. Then you have mixed gas flows, from the fuel vapor, and flows around all kinds of things, so I can see how it gets unmanageable real quick.
On a side note, the new Renault engine's airbox has a kind of ridge or hump in the middle of the bottom of the airbox. Seems like they are dealing with keeping the volume in spec along with the increase in width, maybe?
BG, I'll have to take issue with the generalization that there are no compressibilty effects below 0.75 Mach. What pressure rise (and thus performance rise) is of concern to you? Is a 1% increase in performance at 100MPH not signifigant? I'm sorry but I always hear people saying that compressibilty is not a factor under x.xx Mach or whatever. Sure, but how much is important? If the reports of an F1 engines horsepower is reasonable at 850bhp, then at 200MPH (and @850bhp), the stationary power would be around 825bhp. 25bhp more horsepower sounds worthwhile to me.
While there are likely some cylinder air balance issues to be looked into, with a pressure rise, I would still want to adjust my fuel properly, to take into the account the pressure rise. Even if there were no balance issues.
Posted 22 February 2002 - 05:12
I think that I would be more concerned about drag than the small gains in engine power. I think the air box is there for traffic considerations IE turbulent air rather than any increase in pressure. But since it is there, they might as well experiment with it. If the air goes in thru a small hole and the airbox gets wider as it gets to the trumpets, i dont think compression is a factor in the design but rather to give better control to the active stacks to perform their optimisation of intake velocities at the valves. I also think that air density plays the biggest role in engine performance. When the density drops, so does the intake velocity at the valve and the stacks extend to the appropriate place in the airbox. Fuel is adjusted. obviously The HP difference in Malaysia and England with the potential atmospheric extremes, can be as much as 50hp. A multi valve inlet is more sensitive to atmospheric changes than a two valve set up.
How often does a F1 car get to 200mph? But the drag is significant at 100mph. Also, if a 25hp gain was achieved at 200mph, it is not sufficient to overcome the increase in drag that the airbox sticking in the wind offers at that speed.
( compression gain in the airforce refers to the transition to mach1)
The downforce variations are more drastic, but that is another story.
Posted 22 February 2002 - 06:39
Posted 22 February 2002 - 08:56
Posted 22 February 2002 - 21:24
Originally posted by remmosffej
In my (intro) aero text, they treat all flows less than 0.3 mach as incompressible and all above as compressible. The criterion is change in density. Less than 0.3 mach the change in density of air is less than 5%. According to my aero prof, that was a fairly standard value.
Posted 23 February 2002 - 04:36
Why wouldn't a team simply use two air intakes located in the sidepod and use a roll hoop like those found on some LMP's? You'd get a straighter shot at the wing, less surface and frontal area, less drag, and no "packed" air that forms a barrier around the intake.
I would like to thank all of you for your comments as well, it is much appreciated.
Posted 23 February 2002 - 05:52
FIA Technical Regulations downloads
The relevant section is:
3.16 Upper bodywork :
3.16.1) With the exception of the opening described in Article 3.16.3, when viewed from the side, the car must have bodywork in the triangle formed by three lines, one vertical passing 1330mm forward of the rear wheel centre line, one horizontal 550mm above the reference plane and one diagonal which intersects the vertical at a point 940mm above the reference plane and the horizontal 330mm forward of the rear wheel centre line.
The bodywork over the whole of this area must be arranged symmetrically about the car centre line and must be at least 200mm wide when measured at any point along a second diagonal line parallel to and 200mm vertically below the first.
Furthermore, over the whole area between the two diagonal lines, the bodywork must be wider than a vertical isosceles triangle lying on a lateral plane which has a base 200mm wide lying on the second diagonal line.
3.16.2) When viewed from the side, the car must have no bodywork in the triangle formed by three lines, one vertical 330mm forward of the rear wheel centre line, one horizontal 950mm above the reference plane, and one diagonal which intersects the vertical at a point 600mm above the reference plane and the horizontal at a point 1030mm forward of the rear wheel centre line.
3.16.3) In order that a car may be lifted quickly in the event of it stopping on the circuit, the principal rollover structure must incorporate a clearly visible unobstructed opening designed to permit a strap, whose section measures 60mm x 30mm, to pass through it.
Posted 23 February 2002 - 17:50
WPT
Posted 23 February 2002 - 20:55
Originally posted by imaginesix
Li'l Adam:
Yes, I have a binder filled with the 2001 Tech Regs and Illustrations. Is 3.16.1-2 the literature you are refering to preventing this? I don't see anything in the regs preventing the structure from being a hoop, what I mean precisely is a roll over hoop like a Champ car, what exact part of the regulations prohibits a rollover hoop like this?
Posted 24 February 2002 - 06:08
The regulation that prevents the Champcar rollover hoop look is 3.16.1. "...when viewed from the side, the car must have bodywork in the triangle formed by three lines...".Originally posted by AdamLarnachJr
I call it the 'billboard rule'.;)
Posted 24 February 2002 - 06:59
Thanks for clearing that up.
Thats a stupid rule btw, very freaking stupid, "billboard" rule is right
Posted 25 February 2002 - 20:56
AS for the 'billboard' reg. From what I can make of it, it should be easy to make low drag solution if one really didn't think the airbox offered any advantage.
Posted 25 February 2002 - 21:32
The rule was recinded mid 95 I think.
Ben
Posted 25 February 2002 - 22:38
I agree.Originally posted by Ursus
The regulations specifying an airbox as currently seen aren't 'airtight' (pun intended). There is some scope for running an intake elsewhere, without incurring the drag penalty of the 'billboard' area.
My theory as to why such an intake has not been developed is simply that the FIA would ban it before it had a chance to race. The 'intent' of the rule is pretty obvious, and any divergence from the standard interpretaion would make for a strange-looking car with a big performance advantage. The FIA isn't into 'strange' or 'performance'.
Posted 26 February 2002 - 01:26
I don't think it would make much of a difference really.
Posted 26 February 2002 - 05:27
Posted 05 March 2002 - 10:25
A Yamaha R6 makes 108 bhp at the crank static, but at a given speed can make up to 120 bhp. This is purely thanks to the ram air intake in the nose of the bike pressurising the air box, and 12 bhp is not a bad increase for free..
Posted 12 June 2002 - 05:29
Posted 12 June 2002 - 14:20
Posted 15 June 2002 - 15:36
About the ram air issue, I think that it's clear from calculations above that isentropic compression does not make for a very large effect. However, an effect that hasn't been discussed is the air flow resistance of the intake trumpets and channels. The faster the engine revs, the higher is the gas velocity, and flow resistance increases.
The work needed to suck air into the cylinders is tapped from the engine output. But with a ram air intake, the small pressure increase and freely available ram air velocity means the engine has to generate less of the necessary intake manifold velocity. So the power loss caused by the intake stroke is reduced.
The theory, or rather thought, as I have no expertise in this area, is that the increased engine power output is due to a reduced flow resistance and not to a "supercharging effect" due to the somewhat higher air pressure.
My guess is also that if an engine is equipped with a supercharger or turbocharger, then a significant part of the increased power comes from reducing (or even eliminating) power loss during the intake stroke -- it's the blower that takes care of putting the gas in the cylinders, not the pistons. The other part, of course, is that the total charge can be increased.
Any comments?
Posted 15 June 2002 - 19:07
The CART 2.65L V8, is trbo-boosted only .151bar - 2.195psi over atmospheric !
As the engineers continue to find more and more hp, the regulators continue to turn down the boost, despite all this the 2.65L produces over 800hp!
Posted 15 June 2002 - 21:53
Posted 16 June 2002 - 05:27
Even in a naturally aspirated engine, the pistons do not bring in the air into the cylinders. May seem like semantics, but the difference in pressure brings the air into the cylinders. Many people have the opinion on pressure charged engines, that they don't have to worry much about pressure losses in the intake path. This is not a good approach or attitude for obtaining maximum power. Both a pressure charged engine and a naturally aspirated one are relying on a pressure gradient to fill the cylinders. What is nice about pressure charging is that you can do some of the compression then after cooling then do the rest of the compression work in the cylinder. The aftercooling not only drops air temperature (ie - likelyhood of knock), but also reduces total compression work.
I still think 120 bhp for the R6 is a bunch of crap.
Posted 16 June 2002 - 18:59
MRC, I find your points very interesting but have some minor problems with the quote above.
I think it's clearly the pistons in a naturally aspirated (NA) engine that bring the air into the cylinders. First, you're of course right that without a pressure gradient, there wouldn't be any flow at all. But my point is that this pressure gradient is in the NA engine created solely by pulling the piston down during the intake stroke. The required energy is taken directly from from the crank. (And then indirectly from other cylinder's combustion stroke, and/or from the flywheel.) In addition, the faster the engine revs, the greater is the flow resistance in the intake path. The resistance and work needed to bring the air into the cylinder presents a load on the available power at the crankshaft.
For a supercharged engine with a high enough boost pressure, this is not so, the pressure gradient is then created by the blower. Likewise, any ram device is going to supply a little bit of the pressure gradient, and also a good amount of gas velocity. This implies that the pistons during the intake stroke will present a smaller load, or none at all, on the crank, thereby reducing internal losses in the engine.
You are of course right that in the supercharged engine you have additional benefits, such as to have an increased charge, a pre-compression that again reduces the load on the crank presented by the compression stroke, and then an intercooler will both increase density and efficiency.
Posted 17 June 2002 - 01:43
My main point here is that one has to be very careful to make comparions between pressure charged and naturally aspirated engine. Flow losses through duct work are not going to be much lower in a NA setup vs a pressure charged one, given the same duct work. Total pumping losses (on a percentage basis) will likely be lower, however. From what you were saying, I'm getting the jist that you were thinking that there might be lower flow losses with the pressure charged setup. The flow losses will not really be any lower. The velocity of the air is mostly dictated by the demands of the engine rather than the pressure charging device. The pressure charging device really is using work to raise the pressure.
My other point is that attention must be paid to all the intake and exhaust parameters that were deemed inportant design decisions with a naturally aspirated engine, as pressure charged engines. Many times I have seen modified engines to run some pressure device where no thought was given to runner length, for example. Just becuase something is pressure charged doesn't mean everything else can be disregarded.
Posted 17 June 2002 - 02:06
Posted 17 June 2002 - 09:14
The power to drive a blower or a turbo is not free, if that is what you are implying.
Of course not, that is all very clear, the engine "produces" the power to drive the supercharger or turbocharger. What is free, however, is the ram effect (small). As for the turbocharger, I suppose you could say that a certain amount comes "for free," since the turbine recovers some energy that would otherwise be lost in the exhaust.
A little bit aside, think of a gas turbine (let's say a turbojet engine). The turbine saps some energy to drive the compressor. Remove the turbine (and hence the compressor) and that engine becomes pretty lame -- a ramjet, which won't be very good unless the speed and ram effect really produces compression. But then we essentially have to be in the transsonic to supersonic regime. For lower speeds, there's a huge payoff in tapping exhaust energy with a turbine, and feeding it back to a compressor. If I understand the idea behind blown piston engines, the same conditions apply there (although in piston engined airplanes you also need a compressor to compensate for low air density/pressure at altitude).
Yes, that was my thought. I'm aware that the flow losses in the intake pipes will be pretty much the same, but there is also a loss in creating the pressure gradient. Doesn't it make a difference whether these losses will be covered by the piston, or by the blower? In an NA engine, it's the pistons, although ram effect my cover some of those losses. (Unlike in the ramjet, in an ICE the ram effect doesn't have to provide any compression, flow is enough.)
So in the NA engine, the piston has to be pulled down to generate the pressure gradient, and take the necessary force and energy from the crank. The force isn't that small. Suppose piston area is 40 cm^2, and you need to maintain a 0.2 bar pressure difference, then that equates to an 80 N force. Assume you have to move that piston 25 m/s; then we need to tap 2 kW power, or roughly 3 hp, for that single cylinder's intake stroke. (These figures aren't actual data, they're just guesstimates; I took the figure 0.2 bar because if you'd be down to 0.1 bar it's really hopeless to create a 100 m/s gas transport in the intake pipes.)
But if it's a turbocharged engine, the high pressure boost is generated by tapping exhaust energy that would not have done mechanical work on the crank. (Thermal losses alone are about twice as large as mechanical work on the crank!) And because the hot high pressure exhausts still expand down the exhaust manifold on the way to the turbine, this energy comes if not for free at least at a very low cost -- the back pressure increase implies that the pistons may have to help pushing out the exhausts a little bit, but I think it will cause a very marginal loss of power.
What I don't quite understand is the statement that there are no cases without piston pumping work. There are, of course, although I'm not sure if this is of any relevance to ICEs in general and high revving ones in particular. The case I'm thinking of is piston steam engines. There, high pressure steam pushes the pistons. Why exactly wouldn't the blower provide a pushing effect if you can build a really high boost pressure, say 2 - 5 bar? A pushing effect would more than eliminate piston pump work losses.
Ok, this has been a little bit aside from the ram effect, but I think one can suspect from physiscs alone that the ram effect can help reduce flow losses in the intake, losses that certainly cost a good number of hp.
Again, I'd like to emphasize that all I'm using here is physics, I'm not an ICE expert, so take it with a pinch of salt, read it critically, and correct me where I'm wrong.
Posted 17 June 2002 - 09:52
Airbox design is critical to the F1 engine. I'm sure a lot of time is spent with internal splitters and such to get cylinder by cylinder distribution as even as possible. There is also an air filter in there as well! (an ingested stone is terminal for the engine ~ and with all those gravel traps.......) But the one thing all these posts have forgotten is that engine crankcase venting has to be discharged into the airbox!!! Now think that one through! And further you just might want to get some cooling air to the ignition driver / hydraulics / actuator manifold.....?
Just noticed the Monaco close -ups ..... whats that on the back of the air box for the Arrows???????
Billy G
hangyerganzieontneckiesneck
Posted 17 June 2002 - 19:46
The Arrows photo with the aluminum-looking valve body or junction block feeding into the rear of the airbox, does raise some interesting questions. Some of the vent hoses one sees in photos terminating in the airbox look to be of a pretty large diameter. As if quite a lot of air might be moving through them at times.
Also, although I can't post them here or share them, I've seen some interesting shots of the Cossie Arrows is running and the heads look very strange, almost as if there is only enough metal in them to support a single cam per bank. The photos don't show the timing drive end though, so it is really hard to say.
Posted 17 June 2002 - 22:55
I think the performance gain you are touting do to a reduction in pumping work because super/turbocharging is some what offset by the need to throttle an SI engine. If you get the air in there to push the piston down you are going to have to do something with it. A CI engine is fairly tolerant of excess air and you can use fuel to throttle an CI (some don't use butterfly valves) engine to a certain extent, but I can't think of any example where an SI engine used fuel control to throttle an engine as the main instrument of load control. Hell a diesel never really run rich, most are lucky if they get to stoic. SI's just don't like excess air.
You've got the air in there now what do you do? You can't open the intake valve longer to pump it back out and you can't add any fuel through the valve either, so you just have to open the exhuast valve with some VVT and pump it out.
Now you add DI, you can add fuel and ignite that off late or open the exhuast valve early to reduce power, although combustion in the manifold may keep the turbo spooled up and exhuast valve metalurgists probably won't like you too much.
Now add DI and some crazy EVA lsolenoid or ultra crazy camshaft VVT lobes and you can let lots of air into a cylinder then open the exhuast valve early around BDC, then close it, add fuel, ignite as usual, then open the exhuast valve again in the usual manner. No need for an AIR pump.
A wastegate or boost valve would be indirect examples of engine throttles.
Posted 20 June 2002 - 04:57
I don´t know what it means, but i think it is an interresting difference.
Bjørn
Posted 21 June 2002 - 04:22
All of the GT/GTS cars run a similiar method before the restrictor whereas most of the NA LMP's dont. I have a few pictures of them at the following URL.
http://home.off-road...ajlarnach/ALMS/
#44
Posted 21 June 2002 - 04:29
This is an image of the Panoz/Mugen, notice the two K&N air filters that lead into a "coveted" airbox, I have no idea where the restrictors are located in that airbox. The intake in the bodywork is a small NACA duct.
