Ferguson P99 to run
Posted 05 May 2005 - 13:34
Now if only they could have Dickie Attwood in BRM P67 as well.................
Has P99 run since Peter Westbury used it in hillclimbs?
Paul M
Posted 05 May 2005 - 14:10
Now that would knock spots off Goodwood!
Posted 05 May 2005 - 17:02
Paul M
Posted 05 May 2005 - 21:21
I think Jack Fairman is away testing a prototype somewhere, and Stirling, of course, is running the Ferrari.
Posted 05 May 2005 - 22:29
Four wheel drive on a slot car is not new. Scalextric did it quite successfully with an Audi and an R.S. 200 years ago. That was achieved with rubber bands and believe me, it worked.
However, with an open wheeler it would be more difficult - solid drive shafts from one axle to the other, as in Macca's diagram, probably being the way to go.
There is one massive drawback.... If the front wheels are driving, then they must be permanently on the track surface. Any bump, which would just flick a floating front axle up in its slot in the body, would inevitably lift the brushes clear of the rail, however briefly, and that would cut the engine causing intermittent running. Maybe there is a way to make the front axle 'float' while still being driven - sponge suspension, perhaps... I may look into it.....
But then, I don't actually have a 32nd scale Ferguson bodyshell at present, nor have I the time to make one. I know they are out there so maybe one day.....
Posted 16 May 2005 - 12:18
If it's treated as an engineering exercise, rather than a pure racing machine, just like the original.........
Paul M
Posted 16 May 2005 - 16:47
Definiately not 'new', Barry ....Originally posted by Barry Boor
This is terribly O.T. chaps but you have dragged me in....
As far back as 1967, M.R.R.C. (the original company, based in Bournemouth) produced a slot car with 4-wd and steering ! It was based (I think) on the 1964 Indy Novi-Ferguson. 4-wd was achieved by taking drive from both ends of a large (star-wound) 'split-6' 3-pole motor via bevel gears, to the rear, and to an 'Ackerman' steering arrangement at the front end. Here, drive was transmitted to the front wheels using short stub-axles and what is best described as 'star and dog' CV joints.
And it worked too - if you could ever finish building the kit, that was ! The 4-wd version of the model only ever came in kit form. It was also available as a 'R-T-R' in 2-wd with the standard MRRC 3-pole motor. The 4-wd kit was incredibly complex - it also included 6 ball-races, which were held together in a cup and shim washer arrangement, which you had to assemble yourself. Incredibly fiddley ! Unfortunately the main chassis frame was moulded in nylon - and any serious 'shunt' resulted in the chassis flexing and 1mm ball bearings rolling around the track !
MRRC also produced a Felday 4 in the same range (and, incorrectly, a Mercedes W154 GP).
I still have my Indy Novi Ferguson - restored to original mint condition - in white with lots of STP decals - although I believe the original car was actually red.
Does anybody have any photos of the real car ?
Here is a link to the current Jersey-manufactured 'MRRC' Indy Novi-Ferguson (re-release) -
http://www.merchantr...ar.00.news.html
.... and another to the assembly instructions for the original 4-wd version:
http://www.nostalgia..._indi_novi.html
Posted 17 May 2005 - 11:36
Yes..............both b/w from 1964 (and the 'Autocar' article with cutaways), and my colour shots from the FoS a couple of years ago - I'll put them on Imageshack when I get a chance.
Paul M
Posted 17 May 2005 - 17:25
Did anyone else drop one of the balls, spend a frustrating hour searching for it on the kitchen floor, only to find it stuck to the motor magnet ... or am I the only pillock that does this sort of thing ?The 4-wd kit was incredibly complex - it also included 6 ball-races, which were held together in a cup and shim washer arrangement, which you had to assemble yourself. Incredibly fiddley !
Posted 17 May 2005 - 20:36
Posted 17 May 2005 - 21:04
Posted 17 May 2005 - 22:14
Originally posted by jph
.....I'd have sworn I remeber it running in an historic GP cars demo at Silverstone before the British GP, possibly in '69 or '71.... including... getting all four wheels on to the grass coming out of Woodcote.
Hmmm... now what did Dougy say?
Originally posted by Doug Nye
and with Innes Ireland... behind the wheel...
Sounds about right!
Damned journos... have they got no respect?
Posted 17 May 2005 - 23:36
You are FAR from the only one who has ever done that kind of stuff when putting together a slot car...
Posted 18 May 2005 - 15:39
Here's a photo of my MRRC slot car, which I've owned since 1967. I can remember going into my local hobby shop, on the day I bought it, and agonising whether to buy the MRRC Indy-Novi kit, or the (latest release) Scalextric Bugatti Type 35B.
I now know which would have been the better investment. Hindsight is a wonderful thing !
Note for Russell Sheldon ....
O.K., so it's not quite 'mint'.
Don't know if you can make them out from the photo, but there are a couple of minor 'mods':
Rear axle is 3/32" threaded (instead of push-fit)
I have fitted Super Shells 3-eared K/O's to the wheels, and
The tyres are Super Shells soft slicks, rather than MRRC ribbed treads.
Another tweak that you can't see, was my addition of 10 thou shim washers to the outsides of the axle ballraces - which seemed to fix the errant ball bearing problem (in the event of a shunt).
So it may not be quite 100% original, but it's a lot better than it once was - this slot car, at one stage of it's racing career was fitted with 3/8" wide front and 5/8" wide rear YELLOW 'spongies' !
Luckily I seem to have a spare bodyshell (with chrome and a full set of decals) ....
Guess I need to spray it STP 'dayglo' red with #9 to be 'correct' .... even though I prefer it in white !
Posted 18 May 2005 - 18:16
Only race victory perhaps. But there were loads of hillclimb wins ;)Originally posted by MCS
Only victory for P99 - Stirling Moss, Oulton Park Gold Cup 1961
Posted 18 May 2005 - 19:22
Mark
Posted 19 May 2005 - 06:28
I am unaware of what is going to come out of the German connection.
Posted 26 May 2005 - 17:06
So it would seem that rather than depending on the pin for front-end grip, all four wheels need to be kept on the track - that means even weight distribution and the front wheels mounted on the chassis plate rather than the body. The trick, then, is to stop the pin jumping out over bumps, or the brushes lifting off the track..........hinged section of chassis plate forward of the front axle maybe?
But without differentials, even if the front wheels hop, as long as the current still gets through, all the power will still get to the track.........so maybe flexibly-mounted front axle?
Paul M
Posted 01 July 2005 - 07:57
Can you recall any other car in history that was used in F1 racing, Tasman racing, hillclimbs but also ran at Indianapolis, if only for a demo run? And the impact and results that eventually had?
Quite a car, glad to know that it was ran once again.
I regret it wasn't there yet in '98 when P104 came over to Goodwood. Now that would have been a very special moment if P99 and P104 had met another and been at the same grounds.
I saw P104 back in '98 but regrettably I couldn't attend Sundaymorning so I never saw it run since it failed to run properly on Saturday.
So good to know historical P99 being in good shape again.
Henri
Posted 01 July 2005 - 08:10
Thanks for the photos, Paul. Looks like that 'side-saddle' tank was a later addition.
IOf you refer to the saddle tank on the original, genuine car, that's correct.
In fact, the airfix racer resembles the P104 as it was delivered by Ferguson quite well.
But shortly after arrival and the first testhops at Indy in was damaged in a fire and during the rebuilding the car got this saddle tank as well as a dffferent design nose cone and rear end.
henri
Posted 28 July 2005 - 15:35
Posted 28 July 2005 - 15:49
Originally posted by Henri Greuter
I think P99 must have been one of the most charismatic and versatile cars ever.
Cooper T51 - possibly more influential
Well there's always next year - Doug, are you reading this!
I saw P104 back in '98 but regrettably I couldn't attend Sunday morning so I never saw it run since it failed to run properly on Saturday.
Henri
Posted 28 July 2005 - 16:43
Was the car still entered by RRCW?
Posted 28 July 2005 - 18:11
Posted 28 July 2005 - 21:47
Lots of other cool stuff too, I suggest attending on the Friday general practice day when there should be somewhat less crowding and almost everybody will be running.
Paul
Posted 08 May 2006 - 17:18
Will I now make a car? Mmmmm.... well, given that it has an internal width of only 18-19 mm and the motors I use are 20 mm wide, it may be an insurmountable problem.
Also, it is very shallow and so the motor would intrude into the cockpit area to such a degree that there would be little space for the driver.
I have considered the possibility of vac. forming a shell around the body I purchased, which would obviously be that much bigger.
I have excatly the same problem with my yet to be started Lotus 12s as they were only 2 feet wide - scale size 19 mm. Same problem!
Posted 08 May 2006 - 21:27
Posted 08 May 2006 - 22:10
Posted 09 May 2006 - 01:08
(Car number) 7 (Group) 4 (Pre 61 GP) (Entrant) MOSS Stirling (Driver) MOSS Stirling GB FERGUSON P99 1960
on this website:
http://www.acm.mc/gphm/gphm_main.php
Does SCM own the Ferguson now? Or did I miss something?
Vince Howlett, Victoria, B.C., Canada
Posted 10 May 2006 - 20:55
Ah ...that's it! I always wondered why the 16 was fatter!
Posted 10 May 2006 - 21:48
Posted 11 May 2006 - 08:31
Is it in Donington Collection or in Ferguson Family Museum?
Posted 11 May 2006 - 11:14
There is only one P99. It appears from googling that it is now in the Ferguson Family Museum on the Isle of Wight, but for all I know it may still be at Donington.Originally posted by tobbe j
Is there only one P99?
I believe there is also only one P104.
Posted 11 May 2006 - 19:07
P104 ??
Posted 11 May 2006 - 21:40
Posted 11 May 2006 - 21:43
Well, that's what Henri Greuter called the Novi-engined Indianapolis car in posts 22, 23 etc. If it's incorrect, all I can say is that I took what he said in good faith.Originally posted by macoran
P104 ??
So what is the correct designation of the Indianapolis car then?
Posted 11 May 2006 - 21:54
OK sorry, just couldn't find any reference to that designation in any of the Studebaker Novi Ferguson articles I have.
Posted 04 November 2010 - 11:05
Highest bid of £410,000 was apparently not enough...
Posted 04 November 2010 - 11:42
The Ferguson P99 failed to sell at RM Auctions in London last week
Must check the Lottery!
#44
Posted 05 November 2010 - 14:06
I was at RM........the car's estimate was £475,000-575,000.
Only 13 cars out of 107 did not sell
Gross was a tad under £20 million.
I am not a fan of London but it was a great night out !
This was the big one.............million short of 'hoped for'
#45
Posted 05 November 2010 - 14:12
'35 years in the Donington collection then recovered to the Ferguson family museum on the Isle of Wight to be overhauled.'
