It's Graham, and it's a Brabham. But...
Posted 08 January 2006 - 18:09
(I tried to set up a link to the source of this picture, but failed - so here's a copy of it - copyright unknown)
Posted 08 January 2006 - 18:13
Paul M
Posted 08 January 2006 - 18:23
Posted 08 January 2006 - 18:42
http://www.formula2.net/F264_19.htm
(and NGH is wearing the rubber collar he wore in late summer 1964, eg Austrian GP)
Paul M
Posted 08 January 2006 - 18:46
Posted 08 January 2006 - 19:10
I have a Max le Grand picture** of NGH standing contemplatively on the railed pit road at Silverstone, foot on wheel, chin on hand, (dated as '65 Grand Prix). He's wearing the rubber collar there: was a safety measure akin to current foam neckbrace or was he nursing an injury? I'd always assumed the former - the latter possibility has only just occured to me. (The collar looks as if it might be inflatable.)
(**I think the image is quite well known - the print is Graham White, but I think the image is from the Ludvigsen Library. It's much too large to get on my scanner at home - even if I were to consider it prudent to do so - a lovely picture though.)
Posted 08 January 2006 - 21:35
Originally posted by Macca
Oulton Park Gold cup 1964:
Forgive me for drifting away from the subject a little, but I noticed the following ......
Entry Number 17 Sid Fox, GB - David Prophet Racing Brabham BT10 - Cosworth SCA
Just curious as to why David Prophet would be entering somebody else and why Sid (Syd?) Fox ?
Posted 08 January 2006 - 21:41
Posted 08 January 2006 - 21:57
Posted 08 January 2006 - 21:58
Posted 08 January 2006 - 22:04
Pale blue and dark green. Here's a 1966 pic:Originally posted by philippe charuest
what was the john coombs team "colors" . my guess is white and dark blue ?
Posted 09 January 2006 - 00:37
EDIT: Looked again and realized that this really doesn't make sense as the brakes should get a lot of air anyway... so maybe it's an attempt to diminish the "air braking effect" of the suspension....
Posted 09 January 2006 - 01:52
Was it a Coombs F2 car that JYS raced in 1970.
That was white with blue AIR
Posted 09 January 2006 - 07:45
It was; and as you say, it was white with blue trim. Cevert drove a Coombs March in 1972 which was adorned in a similar use of those colours.Originally posted by Vicuna
Posted 09 January 2006 - 09:23
Funnily enough, Alan, I found that photo too and was going to post it on a athread about early aerodynamics......but I don't know where either, only I'm sure I've seen a pic of another Brabham with those on it.
Paul M
Frank Gardner ran nose wings on his BT6 Formula Junior in 1963. Just flattish ones, not like these which seem to be triangular in section.
Posted 09 January 2006 - 10:14
Surely John Coombs' cars were pale grey. As to the nose colour, I was never quite sure - dark blue, dark green, black ????
But I'm pretty sure about the grey because the famous Coombs E-type was the same colour.
Posted 09 January 2006 - 10:33
Posted 09 January 2006 - 10:43
I'm not sure how far forwards the radiator sits in the nose, but these seem to be placed and shaped to extract hot air.
Posted 09 January 2006 - 11:28
Posted 09 January 2006 - 11:31
As an interesting aside, if they were aerodynamic (and they would be regardless of whether they made the front go up or down!) it wouldn't be the first time NGH had prevented Brabham making an aerodynamic breakthrough years ahead of their time.
Ron Tauranac told me that the BT34 would have achieved ground effect via its central front wing if NGH hadn't insisted on running it flat to get more speed on the straights.......from the horses mouth.......
Posted 09 January 2006 - 12:11
Would the aerodynamic appendages be more to divert/streamline air from the aerodynamically "unclean" suspension components rather than to serve for downforce?
Posted 09 January 2006 - 16:25
Posted 09 January 2006 - 19:14
They're symmetric and at zero incidence, so they're not going to be producing lift. If the intention was to divert the flow around the aerodynamically messy suspension, then they've shot themselves in the foot: the blunt tailing edge that I assume is present will be producing tons of drag. Some sort of exhaust vent system, even if not well thought out, would seem to be the most logical explanation.
Posted 09 January 2006 - 19:19
Posted 09 January 2006 - 19:38
Posted 09 January 2006 - 19:50
On Cevert's Coombs March 722 the white is white (check out the helmet for a reference), and the blue is blue (check out the Elf logo). Stewart's 1970 Brabham was adorned in the same colours.
Posted 09 January 2006 - 19:57
Posted 09 January 2006 - 22:17
Posted 09 January 2006 - 22:20
(Basks in reflected glory.....)
Posted 09 January 2006 - 22:21
Posted 09 January 2006 - 22:31
Posted 09 January 2006 - 22:37
Posted 10 January 2006 - 00:13
Originally posted by Doug Nye
No, no, no - Noddy Coombs' cars for Graham were a very pale Jaguar grey - not any shade of blue, nor white. I think the nose band was actually black, but I can check. Any drift from that pale grey - as on Noddy's Jaguar saloons and the prototype Lightweight E-Type '4 WPD' is due to the vagaries of colour photography and/or colour reproduction in print. The Hill-driven cars - based in my home town of Guildford and prepared for Noddy by Roland Law, were pale grey and pale grey ONLY. Incidentally I believe that the nose fairings tried at Oulton were just that - fairings, intended to minimise the obstructive aerodynamic effects of the Brabham's outboard coilspring/damper units relative to the inboard-spring rival Lotuses. I'm pretty sure it wasn't worth the effort, and they surely had virtually neutral lift effect. Just look at them. No downforce from those babies...
I certainly wouldn't have called it pale blue or white, but it certainly wasn't grey either. Off-white is the nearest expression I can think of to describe Coombs Jaguars and the Brabham looks to be similar.
Is Coombs still alive BTW?
Posted 10 January 2006 - 00:30
Then again, I thought the latest MotorSport was green...
Posted 10 January 2006 - 02:16
Posted 10 January 2006 - 11:07
The later entries Noddy made for the Formula 2 cars of Stewart and Cevert were definitely lighter but from memory I don't think their base colour was a true 'brilliant' white, more an off-white inclining towards grey (stone) as opposed to yellow (i.e. producing a cream colour).
But Graham's earlier Coombs cars like the F2 Brabham, F2 Cooper, F2 Lotus and F2 Matra were - as Barry has recalled - in normal circs DEFINITELY GREY, GREY, GREY....
PS - Yes, John Coombs is very much alive and keeps generally in amazingly good form, looking barely any older than in his heyday, he was sharp as a pin when I last saw him back in September and he is very much a respected elder statesman of British motor sport, originally as an owner/driver, latterly and more prominently as owner/entrant.
Posted 11 January 2006 - 12:19
As Mr A has pointed out, there was a little aerodynamic knowledge around by that time... it was only a season or two later Jack was using bits of aluminium to deflect air at the suspension opening, which is the normal outlet from the radiator.
Check a picture of his 1966 GP cars to see what I mean...
Posted 11 January 2006 - 12:39
Posted 11 January 2006 - 12:54
For the outlets to be behind the radiator, we'd see them in this picture.
Posted 11 January 2006 - 16:15
This is a red herring, IMHO. They are just trying to get a bit of extra grip at the front end using a home-made, non-technical method.
Posted 12 January 2006 - 12:17
