Solution for steering wheel buttons
39 replies to this topic
#1 glorius&victorius
glorius&victorius
  • 4,327 posts
Posted 16 March 2008 - 11:44
I thought how it can be possible for drivers to make mistakes with steering wheel buttons. Last year Hamilton, now Kovy, and I am sure other drivers in the past.
Good that these drivers are not flying F16's, but that same thought made me thing of a possible solution for the steering wheel button-problems: the button needs to be activated before being used
Since these buttons are not to be operated in fractions of seconds (such as the gear flippers) teams could incorporate an "activation step" prior to pushing the button.
One solution could be:
- that there is a global activation button on the steering wheel to activate all buttons.
Other solution (instead of a global activation button) could be that:
- every button needs to be pressed twice before its function can be triggered. So 1st push for activating that button and 2nd push for triggering the function.
#2 Muzzinho
Muzzinho
  • 385 posts
Posted 16 March 2008 - 11:49
Or on the other hand let them make a mistake. Isnt that the point of the new regs, that drivers should be responsible if they make a mistake?
As Martin Brundle said: Good driving is rewarded while mistakes are punished. Exactly the way it should be in my opinion.
#3 Dragonfly
Dragonfly
  • 4,496 posts
Posted 16 March 2008 - 11:53
By analogy with airplanes a simple transparent cover-guard-cap over the button which is lifted with one's thumb before pressing the button with the same thumb will prevent accidental activation.
#4 WildmouseX
WildmouseX
  • 2,654 posts
Posted 16 March 2008 - 13:30
another solution would be to connect all those switch's to radio servo's and put the switch's in the pits, so the driver who needs to focus on the road can call back to the pits and have the guys sitting around not moving 100MPH+ flip them.
#5 Fatgadget
Fatgadget
  • 3,069 posts
Posted 16 March 2008 - 13:45
Are there any engineers familiar with these systems on this board to explain exactly how the pitlane limiter is implemented on a F! car? Its just that I cant for the life of me believe a button that knocks off speed can be left unguarded on those busy steering wheels. Surely its not that difficult to implement logic preventing accidental activation of the limiter no?
#6 F1 Engineer
F1 Engineer
  • 311 posts
Posted 16 March 2008 - 13:52
I'm pretty sure thats against the rules.
#7 F1 Engineer
F1 Engineer
  • 311 posts
Posted 16 March 2008 - 13:54
I know how we implement it, but it may not the same system as McLaren. I can't give out details, but I believe some teams do have a form of safety built in, but you want the pit lane limiter to come on quickly, say if you call your driver in for a suddent pitstop, the last thing you want is a stop and go for speeding in the pit lane.
#8 WildmouseX
WildmouseX
  • 2,654 posts
Posted 16 March 2008 - 14:00
rules are often changed for the sake of saftey... all it would take is one driver to get hurt from wrecking while trying to play with those things at speed.
Nascar has a "kill engine" button on their wheel that can't be covered because it has to be avilible for them to hit if the throttle hangs in a corner. of course F1 has way more buttons, and doesn't often find themselves going into a corner with the throttle pushed all the way to the floor, but it is an example of why they wouldn't put a cover on a button like that.
#9 Dragonfly
Dragonfly
  • 4,496 posts
Posted 16 March 2008 - 14:01
A driver has more than enough time to prepare for pressing that button until he reaches the speed limit marking line at the beginning of the pitlane.
Actually I was thinking it may be possible to see if the fuel cap is open when Alonso overtook Kovalainen. I forgot to set up my computer to record the race and can't check right now.
#10 Fatgadget
Fatgadget
  • 3,069 posts
Posted 16 March 2008 - 14:08
@ Wildmousx. Would I be correct in saying said unguarded Nascar kill switch is positioned in such a fashion that it is almost impossible to activate it accidentaly?
#11 undersquare
undersquare
  • 18,929 posts
Posted 16 March 2008 - 14:12
I remember once Gerhard Berger accidentally pressed his fire extinguisher button, ended his race.
#12 F1 Engineer
F1 Engineer
  • 311 posts
Posted 16 March 2008 - 14:14
I'm not sure they always, not if they were just called in on the corner of, or before, the pit lane, there's probably other things on their mind at that point.
#13 Burai
Burai
  • 1,127 posts
Posted 16 March 2008 - 14:22
Nope:
http://www.nascar.co...fire/index.html
#14 rolf123
rolf123
  • 2,335 posts
Posted 16 March 2008 - 14:26
I don't understand why it caused a speed drop. Isn't it supposed to be just that, a "limiter". Why would it cause the car to slow down without manually applying the brakes? I would like to know just how it "limited". Was he stuck under a certain number of revs in that gear? And if so, how did it slow down?
Sounds like we have another driver aid that needs to be gotten rid of.
#15 Burai
Burai
  • 1,127 posts
Posted 16 March 2008 - 14:43
The speed didn't drop. Both he and Alonso were accelerating down the straight but once he hit his button his speed remained constant whereas Alonso's was still increasing, giving the appearance that the McLaren was slowing.
#16 WildmouseX
WildmouseX
  • 2,654 posts
Posted 16 March 2008 - 14:52
no, there are two posts that go from the center of the steering wheel to the hand grip - in the middle of the right post is the "radio talk" button, and in the middle of the left post is the " kill engine" button. knowing right from left is all the driver has to know to hit the right buttons - however there are times when they accidently hit the engine kill with their water bottle, or an elbow or something.
drivers usually only make that mistake once.
#17 Mayur
Mayur
  • 68 posts
Posted 16 March 2008 - 15:01
Good that these drivers are not flying F16's, but that same thought made me thing of a possible solution for the steering wheel button-problems: [B]the button needs to be activated before being used
Pressing the wrong buttons is pretty rare. Hamilton did not press the wrong button last year.
I dont think we need the activation method you mentioned for all buttons on the steering wheel. At the most, in the interest of safety, they could move the pit lane speed limiter button to the middle of the steering wheel where it will be difficult to press it by mistake.
#18 noikeee
noikeee
  • 11,021 posts
Posted 16 March 2008 - 15:17
I didn't think Kova's mistake was even possible. Someone in McLaren needs to re-think the system and the positioning of buttons in the steering wheel. It shouldn't be possible to activate a speed limiter in the middle of a straight just like that.
#19 inaki
inaki
  • 2,421 posts
Posted 16 March 2008 - 15:20
Give this gloves to pilots to wear in their hands while they drive.
#20 FrankB
FrankB
  • 2,639 posts
Posted 16 March 2008 - 15:26
As someone has pointed out - such "remote control" is not permitted... but even if it was, involving the driver in many of the adjustments would be redundant anyway, as most are made in response to instructions / suggestions which originated on the pit wall. All that would be necessary would be to notify the driver that a certain adjustment was being made.
Going on with the thought as to whether a driver is capable of operating the correct switch at the correct time... if they can't then give them less buttons to play with (or take out all of the onboard controls, mount a camera on the front of the car and let the engineers control throttle, brakes, gear change, engine management and steering from the pits ;) ).
#21 Blythy
Blythy
  • 960 posts
Posted 16 March 2008 - 15:36
here's the easiest solution - TWO buttons, both required to be pressed for it to be turned on, one to turn it off.
#22 pkrash
pkrash
  • 126 posts
Posted 16 March 2008 - 15:43
Heikki has a big enough head that he should know what he is doing....
Are you sure the intake wasn't blocked and the engine starved of air?
#23 glorius&victorius
glorius&victorius
  • 4,327 posts
Posted 16 March 2008 - 17:27
Didn't Ferrari tested a few years ago this voice commands system? I wonder why it wasn't implemented anymore...
#24 Fatgadget
Fatgadget
  • 3,069 posts
Posted 16 March 2008 - 17:58
Voice command? Is that for real? Imagine in the heat of the moment saying engage 1st...oh sheet I meant fifth! :eek:
#25 glorius&victorius
glorius&victorius
  • 4,327 posts
Posted 16 March 2008 - 20:40
I think it was Barrichello that tested it... problem is that I cannot find anything about it on the internet... anyone knows more about it?
#26 Clatter
Clatter
  • 28,475 posts
Posted 16 March 2008 - 20:50
It limits the engine speed, the equivalent of lifting off the throttle. Do that in any car and it will slow down, do it in an f1 car and it will slow down quicker than a road can with the brakes applied.
#27 Georg_Kuyumji
Georg_Kuyumji
  • 664 posts
Posted 16 March 2008 - 21:26
That happened to Gerhard Berger and Jaques Villeneuve, they didnt hurt, but crashed out while messing around with the buttons.
#28 mowaru
mowaru
  • 279 posts
Posted 16 March 2008 - 21:30
McLaren steering wheel ...
here
#29 Jodum5
Jodum5
  • 1,247 posts
Posted 16 March 2008 - 23:46
Basically the button just needs a guard
#30 Tenmantaylor
Tenmantaylor
  • 8,690 posts
Posted 16 March 2008 - 23:52
Stop mollycoddling them... my logitech wheel has 16 buttons and i just won a race online eating foxs crunch creams and drinking a cup of tea without turning my TC off or pit limiter on.
Just put it down to experience heikki and move on.
#31 Josta
Josta
  • 2,237 posts
Posted 17 March 2008 - 13:27
Well, given the fact that the ECU code was developed with Microsoft, I am surprised a pop up window doesn't appear whenever they try doing anything saying "Are you SURE you want to do that - OK or Cancel".
:D
#32 Mikael
Mikael
  • 110 posts
Posted 17 March 2008 - 13:47
Does anybody remember was it pit lane button too LH pressed in Brazil last year?
#33 BMW_F1
BMW_F1
  • 7,670 posts
Posted 17 March 2008 - 14:03
according to Marc Gene, Ferrari's test driver, Lewis made the same mistake last year in Brazil..
From his blog.....
http://www.elmundo.e...gene/index.html
"Lo que me ha sorprendido sobremanera ha sido el error de Heikki Kovalainen. Es increíble que en McLaren no hayan hecho nada desde aquel fallo de Hamilton en Brasil (2007) que les costó tan caro. En Ferrari, el limitador de velocidad sólo entra en marchas bajas, nunca cuando el coche va a tope. Sorprende que no hayan tomado cartas en el asunto. Sigo sin explicármelo."
translation
what surprised me was Heikki Kovalainen mistake. Is incredible that in Mclaren they have not done anything since Lewis fault in Brasil (2007) which cost them so much. In Ferrari, the speed Limiter only engages at low speed, never when the car is a full speed. Its surprising that they haven't address this issue. I still can't explain it.
#34 archstanton
archstanton
  • 425 posts
Posted 17 March 2008 - 15:05
can anyone point me to anything definitive that says Hamilton pressed the PitLane Limiter in Brazil.
i have seen this assertion repeated, and echoed, and then re-echoed, to the extent that some people now seem to think it is actually proven as such.
i just watched the onboard clips again, and yes in the corner he pushes the limiter button, but the cockpit displays are already flashing before he presses the button, he presses it a few more times, and tries a few more options before he is able to restart at proper speed. it seems to me something happened to the car before he started pressing buttons atttempting to resolve the problem.
i also watched all the mclaren pitstops from onboard (both cars), and when the limiter is depressed, the displays do not flash. when hamilton is back up to speed and for the rest of the race his displays do not flash.
what caused the displays to go into this (error-condition?) mode.
we saw how quickly Heikki was able to get back up to speed after pressing his Limiter, why did it take 30-40 seconds for Lewis to get going again, especially as we saw him press the limiter button (to cancel) a few more times very soon after the supposed initial press that "caused" the problem
if nobody knows for sure, that's fair enough, i just get a little nervous whenever i see speculation reported and then repeated as fact.
but either way, a 10pence flip-up cover over the button would be a good idea.
#35 MarkWRX
MarkWRX
  • 831 posts
Posted 17 March 2008 - 15:09
Without turning your TC off? You are in contravention of the 2008 FIA Sporting Code. Please send your Logitech Wheel and $100,000,000 to the FIA, Place de Concord, Paris, France to the attention of: MM. Fine to be paid in cash, non-sequentially numbered bills.
Thank you.
#36 Locoblade
Locoblade
  • 99 posts
Posted 17 March 2008 - 22:00
According to Ferrari, its only possible to activate theirs if the car is in a low gear which seems sensible enough. Not sure why you'd want it active all the time, either limit it by speed (say within 30mph of the pit limit) and/or gear selection.
#37 BMW_F1
BMW_F1
  • 7,670 posts
Posted 19 March 2008 - 11:40
New news from autosport.
It appears Mclaren will now address this issue with the limiter not getting activated by the push of a button while at high speed.
#38 SuperDaan
SuperDaan
  • 342 posts
Posted 19 March 2008 - 13:12
Thats from the intel from Marc Gene, belonging to Ferrari, Max do something :blush:
#39 djellison
djellison
  • 1,726 posts
Posted 21 March 2008 - 10:54
No mistake
Nothing to do with Hamilton touching the wheel - the technical problem starts before he touches the wheel. Gene is talking out his exhaust.
Doug
#40 HP
HP
  • 14,983 posts
Posted 21 March 2008 - 13:13
here
From the 2007 car. Wonder what they did with the TC off button?
