Possible loophole advantage..
Posted 29 July 2012 - 15:08
Posted 29 July 2012 - 15:12
Then, you have to pass all others drivers, and with these tyres, when you are just behind a car you destroy your tyres. Its much better to run in clean air.
Posted 29 July 2012 - 15:15
Posted 29 July 2012 - 15:21
Posted 29 July 2012 - 15:26
Posted 29 July 2012 - 15:41
Did he get the speeding penalty for speeding before the start or at the pitstop on the first lap?
because if he got it for a breach before the green lights it seems wrong to me. Then a monetary fine as they get under FP and Q would be more fair.
Posted 29 July 2012 - 15:48
I don't know for sure, but from his interview "Then we even had a drive-through because maybe the pitlane limiter or something didn't work properly during the puncture phase." I guess it happened when he pitted with a puncture. Maybe the indicated wheelspeed was wrong due to a deflated tyre or something, which seems a little odd because I don't remember this ever happening when a driver pits with a puncture. Although quite often they are just crawling around with a puncture anyway.I don'tthink that's an issue either. But there was another issue I was thnking of when Schumacher was pushed of.
Posted 29 July 2012 - 15:49
Posted 29 July 2012 - 16:08
If start is aborted, the race distance will be shortened by one lap, hence why todays race was 69 laps instead of 70.
Nevertheless Schumacher drove 1 lap less than the others.
But, as others have already said, first of all you don't gain 1 whole "fuel lap", because the others consume much less fuel than during a "hot" lap of racing, and second, even this little amount of fuel that you have and can possible give you a couple of laps of a more powerful engine map cannot make up for all the disadvantages that come with basically having to run behind the field.
Posted 29 July 2012 - 16:43
ok, no problem then.
