"Sometimes you're lucky in life and you stick all the elements together and they add up," said Whitmarsh. "Sometimes they just don't.
"There were times when it's come good and we don't really know why.
"At the end of last year, some of the developments overperformed. We were actually overdelivering at the track.
Martin Whitmarsh feels 2012 car 'overperformed' [edited title]
Posted 09 August 2013 - 10:09
Posted 09 August 2013 - 10:19
Edited by femi, 09 August 2013 - 10:20.
Posted 09 August 2013 - 10:23
At the mid point of the season McLaren are no where near last years achievements, so what is the reason for it?
Was this all down to Lewis out performing the car?
I find it troublesome when the team leader says that the fastest car the team has had for some long years, came to be being "lucky". Troublesome indeed.
Edited by 10e10, 09 August 2013 - 10:23.
Posted 09 August 2013 - 10:31
Posted 09 August 2013 - 10:32
Similarly with Mercedes you can check if it's purely the Hamilton effect by comparing Rosberg's 2012 and 2013 performances and results - he's doing significantly better this year suggesting the car has improved relative to the competition.
Posted 09 August 2013 - 10:33
Why should it only overperform (I believe relative to wind tunnel analysis etc.) at the end of the year in that case? The drivers were the same all year."At the end of last year, some of the developments overperformed. We were actually overdelivering at the track.
Posted 09 August 2013 - 10:35
Can you provide some data to back this up? McLaren had a poor start to last season too. Obviously not as bad as this year but some data will help establish your grounds to discuss further.
Posted 09 August 2013 - 10:36
I interpreted his comments on the 2012 car overperfoming as being in line with his previous remarks about them having unfounded optimism for the 2013 car, of placing too hopeful an assessment of the numbers being generated in the design process. After all, if the 2012 car delivered as much or more than expected, with hindsight (hey!) it's understandable if not excusable that they assumed the MP4-28 was going to over-deliver on what the numbers told them too.
Now, obviously, they know that all their experiences of last year's car should have told them is that their measuring metrics weren't reliable, not that they just consistently underestimate the true numbers.
I really don't think he's talking about drivers at all here, not even between the lines.
Posted 09 August 2013 - 10:41
Classic Ron Speak. Put this season's car in a better light by negatively painting last season's car as an overachiever.
Posted 09 August 2013 - 10:44
You can check if it was the Hamilton effect by looking at the common factor between last year's Mclaren and this year's Mclaren, which is Button. That comparison tells anyone with a grey cell functioning that this year's car is much worse relative to the competition than last year's car.
You could be right but note that there is no LH to provide a yardstick for JB to measure himself against. Some people have already mentioned that it would be hard to see how really fast the 28 can go with LH gone.
One could also argue that the arrival of LH has motivated Nico to work harder he strives to match LH. It will be interesting to observe how these battle evolves now that LH seem to be getting tuned in to the car. Hopefully they would be to replicate the tyre management on display in Hungary at the remaining tracks at the very least.
Posted 09 August 2013 - 10:49
Posted 09 August 2013 - 10:51
The wider context of the interview suggests more that MW thinks McLaren lost an overall perspective in the 2013 design process and fell too much into working in compartmentalised little teams with not enough guiding vision.
These are still not very flattering and moving forward quite troubling...
Posted 09 August 2013 - 10:54
Posted 09 August 2013 - 10:56
Yes that's why the last race of the season was won by Jenson.......
Ah yes that inherited win.
Posted 09 August 2013 - 10:57
In pretty special circumstances on a wet track after Hamilton got taken out by Hulkenberg...
Posted 09 August 2013 - 10:58
.. and the opener. Jenson had a shocking mid season though.
Posted 09 August 2013 - 10:59
After Lewis was knocked out by Hulkenburg......
I don't get why people can't accept that Lewis Hamilton THRASHED Button last year. Points don't tell the whole story and that fact of the matter is there is a maximum of two races that Button was actually racing better then Lewis ( And even that can be doubted with the fact that we don't know who Spa would of gone).
Oh and btw, Jenson beat Lewis in 2011. Fair and square.
Posted 09 August 2013 - 11:00
Yep!"At the end of last year, some of the developments overperformed. We were actually overdelivering at the track."
Can't believe he is really saying that and I thought my rating of him as a team principle couldn't get lower ...
Posted 09 August 2013 - 11:05
Yep!
You think?
Try this little chestnut from the same article!
"You have a little bit more compartmentalisation than you would like and the organisation has to pull together a synthesis and make sure that there is actually some synergy and cohesion between all those elements."
I took it as a sign that the Wind Tunnel numbers didn't correlate with what they had on track, but for a positive meaning, that is, car was performing better than the Wind Tunnel said it would. Martin is talking about a correlation problem, not an external input differentiator.
If your correlation between WT - simulation - reality is off, you might be lucky and the parts perform better than expected, but this luck never lasts. Add some faults in the design or in the design team (lack of overall vision for the whole car, too many small projects thrown together) and you have a problem.
Posted 09 August 2013 - 11:06
Button had a chance to win by his own right. It was just strategy and weather see-sawing. The point is Button looked pretty good himself (except for the middle part where he disappeared). So it can't be just Hamilton adding speed to the car. That is just a silly interpretation... and the opener. Jenson had a shocking mid season though.
Posted 09 August 2013 - 11:08
This year it is hard to tell were the car is on pace, last year it was easy to tell if Jenson was having a good weekend or not, when Hamilton was his teammate you knew when Button was struggling because he was half a second behind but now it is hard to tell. Is Button underperforming or is the car that bad? When he finished 5th a few races back maybe Hamilton would have won that race.
With drivers like Vettel or Hamilton you know that they are pretty much getting all that the car can give.
Posted 09 August 2013 - 11:09
Posted 09 August 2013 - 11:13
Other then Melbourne and maybe Spa (We'll never know) when did he realistically look like beating Lewis? (Baring in mind broken suspension at Suzuka)
Posted 09 August 2013 - 11:18
In a nutshell.Poor excuse by a poor team boss
Posted 09 August 2013 - 11:19
No it wasn't.
Posted 09 August 2013 - 11:23
You think?
Oh boy I am glad LH didn't learn to speak like that!
Posted 09 August 2013 - 11:31
This is not Button vs Hamilton thread. The point is Button was quite comparable and credible in comparison to Hamilton in the car. It's not like Hamilton was showing extra-special week-in and week-out to show it was Hamilton adding that extra-speed that Whitmarsh refers to as over-performance. That is the point. Based on the statements listed here, I get no indication whatsoever that it was related to Hamilton and just Hamilton's car overperforming while Button's matching with their theoretical correlation.Other then Melbourne and maybe Spa (We'll never know) when did he realistically look like beating Lewis? (Baring in mind broken suspension at Suzuka)
Posted 09 August 2013 - 11:41
Also, the OP didn't include a link to the interview the quote comes from, so here it is for completeness: http://www.autosport...t.php/id/109224
Posted 09 August 2013 - 11:46
No, But he was a big part of getting the car setup, IE: Montreal 2012. I think the drivers don't have that benefit this year.
Posted 09 August 2013 - 11:48
...but Whitmarsh would never put words on that, as it would be counter-productive and it would be stepping on Button's and Perez' toes.
Whithmarsh simply wanted to indicate that the windtunnel figures predicted a slower car.
Posted 09 August 2013 - 11:50
McLaren are their own worst enemies, they make it so hard to find sympathy for them sometimes.
Posted 09 August 2013 - 11:52
Anyways, is Whitmarsh really just saying "Our windtunnel -> track correlation sucks" ?
Edited by SUPRAF1, 09 August 2013 - 11:53.
Posted 09 August 2013 - 11:53
Yeah sure the MP4-27 "overperformed", but the logic invalidates it as they won neither the WCC nor the WDC that season, giving them both to RBR/Seb instead
The heck they were EVEN beaten by the "underperforming" F2012 in the constructor's
Conclusion: He is not fit for this sport, give him a different gimmick Ron~
Edited by BrawnGeePee, 09 August 2013 - 11:56.
Posted 09 August 2013 - 11:59
Seems so.Despite the fact that Button performed well in last year's car (relative to this year) and even won a few races, he said that the 2013 car feels better to drive .
And that was with one of them being driven by Massa....
Outperforming a car is physically not possible. Not in this universe.
This is about how Mclaren's aero department functions. Nothing to do with Hamilton vs Button. Nothing!
Edited by Timstr11, 09 August 2013 - 11:59.
Posted 09 August 2013 - 12:01
Ron must have been typing into a teleprompter in the background.You think?
Posted 09 August 2013 - 12:07
Casey Stoner?I don't care who it is, NOBODY can outperform their car
Posted 09 August 2013 - 12:15
I was speaking to a top motogp journalist about this very thing. Ducati bike always had performance, getting it out was the problem. It suited a very particular style that stoner happened to have, it brought the best in both of them. Maybe it's not dissimilar to the Hamilton -27 combination. Incidentally, that same journalist went one to tell me how lost Ducati have now got, moving philosophy towards a more Japanese style of chassis but then sticking to other traditionally Ducati characteristics. They've ended up making a pigs eat out of it not entirely dissimilar to how Mclaren have lost their way with a concept...Casey Stoner?
Edited by bonjon1979a, 09 August 2013 - 12:16.
#44
Posted 09 August 2013 - 12:17
Have you actually looked at the data?
Here is the results of the first 10 races of 2012 vs 2013 for both Button and Rosberg.
2012
Rosberg
Average Qualifying Position = 7.1
Average Finish Position (exc DNF) = 7.7
Pts after 10 races = 76
Button
Average Qualifying Position = 7.6
Average Finish Position (exc DNF) = 9.6
Pts after 10 races = 68
2013
Rosberg
Average Qualifying Position = 4
Average Finish Position (exc DNF) = 6.8
Pts after 10 races = 84
Button
Average Qualifying Position = 10.4
Average Finish Position (exc DNF) = 9.3
Pts after 10 races = 39
What does it show?
Mclaren appears worse in Qualifying but better in the race. Pts are distorted due to Buttons inconsistant highs and lows in 2012, he either finished well or nowhere.
Very difficult to justify your statement of "anyone with a grey cell functioning that this year's car is much worse relative to the competition than last year's car"
Mercedes is qualifying much better than last year and finishing around 1 place higher.
Arguably Button is a superior driver to Rosberg so should be getting more out of his car than Rosberg. Yet comparing the 2012 figures the Mercedes did better in qualy, and race and had more points.
#45
Posted 09 August 2013 - 12:18
Totally agree - ignore the driver cr*p. And McLaren is not alone in suffering ongoing correlation problems.It's a pity this thread is descending into driver performance bickering.
http://www.espn.co.u...ory/120091.htmlFerrari is currently using Toyota's wind tunnel in Cologne to develop its car while its own facility in Maranello is updated, but F138's chief designer, Simone Resta, says the data is still not correlating with the car on track.
#46
Posted 09 August 2013 - 12:19
But maybe somebody can drive a car in a way that it wasn't designed to be driven.
For example maybe Hamilton could drive the car with the configuration that they had in Jarez. And that could maybe open up a whole new development direction.
#47
Overperforming ? Even when wining all races, both champs, all poles, a car is not performing too much. Whitmarsh excuses for a bad job sound miserable.
I can hear "our 2012 upgrades were working better than expected and it screwed 2013 car", and that is even more stupid
#48
Posted 09 August 2013 - 12:22
No.At the mid point of the season McLaren are no where near last years achievements, so what is the reason for it?
#49
Posted 09 August 2013 - 12:24
It's nonsense.But maybe somebody can drive a car in a way that it wasn't designed to be driven.
All Withmarsh was trying to indicate with his remark is that there were already signs last year that the correlation was off.
#50
M.W. comes across as a nice guy but possibly not anywhere near as strong or motivating as Ron Dennis as a manager. There has been a steady drain of talent at McLaren for a few years now and it was only a matter of time before they had a torrid season.
