Lewis Hamilton is serious about winning next season's championship. So much so that the Mercedes man is willing to 'chop his own nuts off' to meet the weight.
Hamilton: I Weigh 71 Kg And I Am Not Going To Be 65 Kg Unless I Cut My (Wedding Tackle)
Posted 08 October 2013 - 22:34
Posted 08 October 2013 - 22:47
A lot of talk recently from the Mercedes drivers about their testicles. What's happening over there?
I bet Lauda is involved.
Posted 08 October 2013 - 22:52
Ironic. I've always said I'd chop my own nuts off to race F1 for a living, but never did I think that would one day be an actual requirement.
Posted 08 October 2013 - 23:01
I really hope F1 sorts itself out and raises the limit by 10kg to a round 700kg.
It's just ridiculous that 75% of the grid is too heavy. Looks like next year's championship battle will be between Vettel, Massa, Gutierrez, Pic and Perez...with everyone else dropping at least 0.1 seconds per lap.
Like Vettel needed another advantage.
Formula 1 is rapidly becoming an expensive joke.
Posted 08 October 2013 - 23:09
Incredible.
You're right there. This is unbelievable. I mean, Mansell and Piquet weighed over 12 stone, yet they managed fine in the 1980s, in the turbo era...
F1 seems to be doing an excellent job of shooting itself in the foot...
Posted 08 October 2013 - 23:11
How heavy are these KERS contraptions?
Before they came around, 605kg was enough to play around with weights and I don't recall hearing much if anything about the drivers. You always had to be small, sure - Webber is often seen as a tall driver and measures in at only 1.85 meters - but certainly not to these extremes.
Posted 08 October 2013 - 23:16
1.85m = ~6'1", right? That's taller than average even out in the 'real' world.
Posted 08 October 2013 - 23:17
Lewis has other problems if his nuts weigh 13 pounds.
Edited by Knot, 08 October 2013 - 23:18.
Posted 08 October 2013 - 23:18
i dont get it to be honest!
serious question, why isnt there a maximum weight limit for the car itself? why is it the package that counts and not the car on its own?
Lewis has brass balls confirmed
Posted 08 October 2013 - 23:26
To avoid giving a direct weight advantage to lighter drivers?
Posted 08 October 2013 - 23:32
Because in that case the driver's own weight is a clear and simple penalty.
The idea of a combined weight is to open the possibility to even it all out under that minimum weight. Still, having a heavier driver means that you can't place some required ballast -to make up for the minimum weight- at the most advantageous places.
That said, I think that it's all blown out of proportion. We have the same kind of regulations at this moment, just with other figures. Have look a the current grid - I guess Hulk is heavier than Gutierrez, Button is heavier than Perez, Alonso is heavier than Massa. And who's scoring the most points?
Edited by scheivlak, 08 October 2013 - 23:32.
Posted 09 October 2013 - 00:10
Posted 09 October 2013 - 00:17
probably those balls swallowed up a lot of water while hanging in the pools.
Posted 09 October 2013 - 00:37
So that heavy drivers aren't at a disadvantage. If the rules gave a maximum weight for the chassis only, then lighter drivers could lap faster than heavier drivers as the total weight would differ depending on how heavy the driver is. By including the drivers weight it means all cars have the same minimum weight, the only disadvantage heavy drivers have is that they have less ballast weight to place around the car to help balance it.
With the new regulations they have increased the overall weight to compensate, but even though no cars have been built yet they have calculated they can't get the chassis more than 65kg lighter than the minimum weight limit, whether that will turn out to be right we won't know until the cars are built.
Posted 09 October 2013 - 00:42
If Mansell just took that bear off his face he wouldn't have had any problems.
Posted 09 October 2013 - 00:44
What bear?
Posted 09 October 2013 - 00:51
What bear?
It turns out I don't have the patience at the moment to Photoshop a bear onto Mansell's face so just know I was referring to that epic moustache.
Posted 09 October 2013 - 01:49
Nico Rosberg looks pretty small also. I would bet they will up the anti for next season. You don't want health to be a concern. Course over at RBR, weight has always been a priority, so Newey's new requirements might be down right scary. Lewis should take heart!
Posted 09 October 2013 - 02:07
Packaging will be key next season.
http://www.autoweek....02/f1/130909986
Posted 09 October 2013 - 02:26
Posted 09 October 2013 - 02:38
Incredible.
Formula 1 has been a joke for a while now.
Posted 09 October 2013 - 03:09
ok lewis ... you know the procedure, if u wanna cut your balls off, call Ellen Page, she's the best
Posted 09 October 2013 - 05:59
Humorous opening post and attention grabbing title but never going to lead to a decent discussion about the driver weights mess.
