F1 2014 Power units 'Side By Side' comparison
35 replies to this topic
#1 eronrules
eronrules
  • 3,395 posts
Posted 20 April 2014 - 05:30
from formula1.com ...
schematics of both mercedes and renault PUs have been revealed and a comparison between them has been made.
Mercedes
features :
1. Mercedes have separated the hot side of the turbo (in red) from the cold side (in blue) and have the MGU-H mounted in the 'V' of the engine between the two parts of the turbo.
2.The heat transfer between the two parts of the turbo is minimised, so less cooling is required to keep the charge air temperature down (or if the same cooling capacity is used, the charge air temperature will be lower, giving more power to the rear wheels).
3.  having the MGU-H mounted between the two sides of the turbo could allow Mercedes to have either or both sides working through one-way clutches, making the complete unit more efficient.
4. Basically the exhaust gases coming out of the engine on the hot side of the turbo only ever have to drive the cold side of the turbo and/or the MGU-H, creating electrical power from this component and feeding it directly to the MGU-K.
5. The MGU-H only ever has to drive the cold side of the turbo, increasing the charge air pressure, thus reducing turbo lag and increasing power.
6. The potential advantages of the Mercedes concept could be significant over the course of the season, especially as retro fitting a similar solution will be very difficult for the other power unit manufacturers.
7. personal note: the way mercedes engine packs it's exhaust manifold means the MGU-K is less affected by the heat of the exhaust pipes. this can be significant in the performance of the MGU-K motor unit.
Renault
features
1.Renault have the hot side of the turbo (shown in red) bolted directly to the cold side (in blue).
2.There is heat insulation between them, but there will inevitably still be a lot of heat transfer between the two parts, meaning that a larger intercooler and more airflow will have to be used to reduce the charge air temperature.
3.Mounted to the cold side of the turbo is the MGU-H, which will drive or be driven by the turbo through a central shaft. With this packaging both turbo elements will be driven simultaneously (whereas Mercedes' solution offers the possibility of driving the two elements independently).
4.Mounted to the cold side of the turbo is the MGU-H, which will drive or be driven by the turbo through a central shaft. With this packaging both turbo elements will be driven simultaneously (whereas Mercedes' solution offers the possibility of driving the two elements independently).
5. Personal note: both Ferrari and Renault have extended exhaust manifold that curves around the MGU-K unit. this configuration usually provides good exhaust pressure for the turbo , but is bulky and less packaging efficient.
FERRARI  (From an early speculation from TJ13)
059-3-sketch.jpg?w=497&h=373
V6 Ferrari 059/3 sketch, courtesy of Paolo Filisetti (for larger image, click here)
Features
1. Exhaust manifold doesn't go downward like Mercedes or Renault, but instead goes upward.
2. MGU-H is placed under the Turbine
3. Emphasis on the compactness of the overall PU.
4. Use of air-liquid-air heat exchanger to minimize heat radiator size.
the Ferrari PU hasn't been published yet, will be updated if images become available.
also, the installation of Mecedes PU in the mercedes W05
read more at http://www.formula1....014/0/1173.html
and finally a flow diagram of the powerflow (hypothetical) in 2014 PUs (courtesy of f1technical)
Edited by eronrules, 20 April 2014 - 16:20.
#2 Petroltorque
Petroltorque
  • 2,856 posts
Posted 20 April 2014 - 10:39
Interesting comparison. I think you should note that Renault are operating an old school works and customer supply. The works spec always being a couple of iterations ahead of the customer supply.
#3 eronrules
eronrules
  • 3,395 posts
Posted 20 April 2014 - 16:07
after much googling, i found these images that i saw weeks ago ...
the Ferrari 059/3 engine on the marussia chassis. this image sort of confirms about the upward curve of the exhaust pipes above the ICE and possibly the MGU-H being under the turbine.
from F1 technical
Marussia-Formel-1-GP-Bahrain-Sakhir-3-Ap
#4 Clatter
Clatter
  • 45,831 posts
Posted 20 April 2014 - 16:10
Do you have any proof of that?
#5 eronrules
eronrules
  • 3,395 posts
Posted 20 April 2014 - 16:11
also, the exhaust config of 3 manufacturers ...
courtesy of jagunx51 from f1technical
#6 eronrules
eronrules
  • 3,395 posts
Posted 20 April 2014 - 16:17
btw, does anyone knows which turbo manufacturer supplies mercedes ??? AFAIK, Renault uses BorgWarner turbocharger (former KKK) and ferrari uses Garrett-Honeywell.
also, does magnetti mareli supplies the MGU-K and battery pack or the MGU-H as well for renault and ferrari. and what about mercedes PU??? is it all in-house job???
info please.
#7 Timstr11
Timstr11
  • 11,162 posts
Posted 20 April 2014 - 17:33
Mercedes has designed their own Turbo and ERS.
Edited by Timstr11, 20 April 2014 - 17:33.
#8 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 02:08
a sideway view of mercedes PU in W05 and VJM07
notice how clean and low the PU sits in the chassis. also note the exhaust manifold.
thanks to obi offiah
Mercedes-Formel-1-GP-Bahrain-Sakhir-3-Ap
Force-India-Formel-1-GP-Bahrain-Sakhir-3
the famed jar jar binks photo ... note the twin intake manofold entry (eyes) and the compressor (red mouth)
Mercedes-Motor-559x373-3d31f3de9990d826.
let's look at the cooling arrangement on w05 and RB10
Red-Bull-Formel-1-GP-Bahrain-Sakhir-3-Ap
#9 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 02:13
great article on the advantage of the Mercedes PU compared to others ...
http://www.omnicorse...re-e-nel-telaio
#10 Petroltorque
Petroltorque
  • 2,856 posts
Posted 21 April 2014 - 06:50
As to whether I have proof that Renault are running separate works Customer deals the answer is no. But it's worth looking at available evidence. Red Bull Technologies embedded software analysts at Viry resulting in improved performance in Melbourne. Red Bull also prevented sharing of those updates with Lotus and Caterham. What I found most amusing was that Marko was quoted in AMUS that once Renault cut the power deficit to Mercedes to 40bhp they would be matching Mercedes AMG. Taffin's confirmed in Shanghai that their projected power deficit was now only 40bhp. It's interesting that for the past 3 seasons Red Bull have won the championship having a car with the lowest top speed of the leading runners. That approach might work if you can blow the diffusor, it does not look like it's going to work this year. Let's face it Mercedes are also the quickest in high down force sectors as well. If Red Bull can't beat The Mercedes in Barca, then we can wheel the fat lady onto the stage.
#11 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 07:44
regarding the ferrari PU, my whole view is that it's not the weight that's the issue, rather the high COG. if we look at merc PU, it sits very low with all the ancilaries well below the engine plenum chamber (let's take that as reference ). the way ferrari exhaust manifold curves upward and the location of the turbine must cause headache to the vehicle dynamics boffins.
also interesting to note is that merc PU is supposed to be sacrificing around 15-20 HP because of the shorter exhaust manifold. (from the autosprint article posted above). also that merc compressor is larger. but due to bad google translation, i couldn't understand most of it, and weather it has any benefit. it says something about RPM and engine breaking and how merc MGU-H can bypass the battery and provide power directly to MGU-K and how the compressor bleed off can give more juice to MGU-K.
can anyone with italian knowledge please translate it better than google translate.  :wave:
#12 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 07:46
TBH, i found the whole facade farcical. why then other renault teams (i.e CT and Lotus) are paying more than other 2 suppliers and getting less. renault engine management ant viry is in disarray i'd think with no real organisation as to what is customer right and what is works right.
#13 v@sh
v@sh
  • 1,495 posts
Posted 21 April 2014 - 09:24
How do you know that CT and Lotus are paying more than TR/RB?
RB have their Infiniti sponsorship in place so it makes sense they would pay less + they are the 'official works' team. TR on the other hand would probably be paying the same as CT/Lotus.
Red Bull have sent their own software team to help Renault resolve their issues with their PU which is predominately software related. So why would Red Bull want to share their own hard work, money and resources with their competitors? Why have CT and Lotus not done the same and if they've done the same, why not ask for equality then? I for one understand why Red Bull and TR get first dibs on the updates.
I think its foolish to think that CT and Lotus expect to get the latest PU when its their competitors resources that have been hard at work helping fixing the actual PU. It's like saying you've just spent $100k fixing a software bug/enhancement that your vendor had problems with and now you've help fixed it. Why would you want your competitors in the industry having it at the same time when you've just spent a $100k investment? What have your competitors done to deserve that?
It would not surprise me if there are different deals for all the engine manufacturers either. The same works for certain businesses in general, so I don't see why it couldn't be the same for engine supply that there are different deals.
Additionally, CT/Lotus and the rest of the Renault teams should re-negotiate a revised engine supply deal after the piss poor start Renault have had to the season as it has been detrimental for all the teams in terms of constructor points + prize money. For the most expensive PU out of the three manufacturers, they've received a lousy product.
#14 Clatter
Clatter
  • 45,831 posts
Posted 21 April 2014 - 11:00
It's quite possible that the various teams are using different software but the hardware is still the same. In the age of the homologated engine they cannot supply different versions to their various customers.
#15 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 14:35
actually your last paragraph sums up what i was trying to say. forget performance gains, lotus and CT needed new software mapping just to run the car uninterrupted. yes you can argue that RBR-STR programmers should be entitled to keep their fruits of labor for themselves, but at that point in time, it was more about getting other teams running.
regarding costs, i was alluding to what you wrote, off all the 3 manufacturers, renalut PU is the expensive one and most troublesome. they should seek compensation.
#16 eronrules
eronrules
  • 3,395 posts
Posted 21 April 2014 - 15:25
awesome article TC3000  :up:
regarding the intercooler design, when one wants more cooling, one has to use large radiator that takes lot of space.also, large radiators create large back pressure. perhaps mercs were able to use shaped radiater that has even shallower angle than say RBR ones and the area behind the radiator is small compared to others which gives the radiator exhaust  a smoother path to exit the car.
#17 Petroltorque
Petroltorque
  • 2,856 posts
Posted 22 April 2014 - 15:54
For anyone asking for Proof that Renault are offering separate works customer deals, may I point you to the front page article where Lopez gives an insight into their Renault customer supply. He CONFIRMS that Lotus only received the units Red Bull have been using since the start in China. Ergo Red Bull have only been giving away 40bhp to Mercedes since the start of the season. It's the software within the ECU ROM that is separating the Renault Power Units.
#18 warp
warp
  • 1,453 posts
Posted 23 April 2014 - 02:32
others who are more proficient in Italian will add to this, and perhaps point out a mistake or two, but here in bullet points, what I read from the linked article.
Awesome article, thanks!
IMO, I think it's more of the concept of how Mercedes envisioned their engine.... and their expertise. Thousands of units on the road provide you with invaluable experience on how to balance all the different components on these new PU.
For example, having a larger turbine certainly has its benefits, but they inherently have more mass and more rotational inertia. The turbine, compressor, exhaust, intake, MGUH and MGUK all have to be sized accordingly to gain any benefit from it.
The Mercedes PU of this year is a brilliant piece of machinery... and I'm a Ferrari fan.
#19 FPV GTHO
FPV GTHO
  • 2,393 posts
Posted 23 April 2014 - 02:41
Red Bull had the updated engines for Bahrain. Lotus and Caterham recieved them for China.
#20 KingTiger
KingTiger
  • 1,895 posts
Posted 23 April 2014 - 04:09
According to Horner, RBR was losing 7 tenths on the straight in China.
#21 Petroltorque
Petroltorque
  • 2,856 posts
Posted 23 April 2014 - 05:16
Anything Horner puts in the public domain needs very careful scrutiny. The implication is that the lack of straight line speed is purely down to a power deficit. Half the deficit is due to excessive drag of the Red Bull. It's Newey's emphasis on down force that is yet to pay off since the Mercedes cars are faster through the high down force sectors as well.
#22 ray b
ray b
  • 2,968 posts
Posted 23 April 2014 - 05:24
we had exhaust blown
will they now dump the excess heat in a way  to get a effect ?
do the cars have a normal alternator/battery or are the ''MGU-K/H''
providing all the cars power for pumps sparks radio computer wheel read outs ect
#23 Timstr11
Timstr11
  • 11,162 posts
Posted 23 April 2014 - 05:48
I'm also beginning to believe that it's not all down to Renault.
They may have to re-optimize their car around a lower L/D ratio for improved straight line speed and better fuel consumption.
#24 HoldenRT
HoldenRT
  • 6,773 posts
Posted 23 April 2014 - 05:57
Of course it's not all down to Renault, STR demonstrates that.  You can have high top speeds with a Renault engine, you'll still be slow though.  Just in a different way.
Doesn't mean the Renault isn't down on power.  Straight line speed isn't the only way to judge power.  What people don't realize when talking about that, is that you can have a higher drag setup but the higher power engine is still going to help power that through the straights, the same way it would on a car that has a low drag aero package.  Mercedes could strap on their high downforce config, but they'd still have higher top speeds than they would with a Renault engine.
It used to be up in the air back in 2009 or 2010.  I could understand the discussions about it.  After this winter it became blatantly obvious, that the Renault is a liability.
Therefore Horner doesn't need to exaggerate anything, and I'm not even sure why I am typing this.  It's sort of embarressing.  It's been plainly obviously the beginning of the season, everyone in the paddock pretty much unanimously agrees and I wouldn't even see any point discussing it on here, because there's little room for grey area.  The only grey area could be how much they are actually down, and that's hard to discuss because it changes every race weekend.. as Renault seem to improve more and more as time goes on.  They are catching up, but still behind.
But yes.. Redbull's lack of top speed isn't ALL due to the engine, some weekends they have run a higher downforce higher drag aero setup.
edit - This post was a bit of an overreaction, not so much to any posts in this topic but the overall vibe that seems to pop up from time to time here.  Of things that appear obvious, yet I come here and people need things spelled out for them.  Things that leave little room for debate.  It's annoying, but anyways..
Not trying to detract from the OP.. I found the OP's info very interesting.
Edited by HoldenRT, 23 April 2014 - 06:02.
#25 Timstr11
Timstr11
  • 11,162 posts
Posted 23 April 2014 - 06:44
Horner is putting their problems all down at Renault's doorstep. So don't be surprised by reactions here.
Edited by Timstr11, 23 April 2014 - 06:45.
#26 teejay
teejay
  • 6,273 posts
Posted 23 April 2014 - 06:53
I also believe driveability is as vital to the engine this year as peak power.
Renault might be laggier, so when it comes on suddenly It upsets the balance of the car.
Ferrari seems to be the worst in that regard from what kimi and Alonso are saying.
#27 Jejking
Jejking
  • 3,111 posts
Posted 23 April 2014 - 09:20
It's a setup thing and a bad compromise from Red Bull. Merc isn't faster through the downforce sectors, RB are on their case. Watch China S2, no difference between them at all. But the overall balance is much better, Merc is pulling a massive gap in the speed traps. Truth is in a bit of both, RB probably lacks power but with such a downforce config it's just expected to see them fall back on the straights.
#28 Petroltorque
Petroltorque
  • 2,856 posts
Posted 23 April 2014 - 14:52
JetKing you have a valid point. Checking the sector times from quali 3, Riciardo gave up around 2 tenths to Hamilton in sector 2 and another half second in sector 3. I guess if Renault can cut the power deficit by another 20 bhp by Barcelona it could be game on as we can then see which design philosophy is superior between Red Bull and Mercedes. As an aside, on the topic of power units, I can see a flaw in the Auto sprint article. Bear with me as my science back ground is not mech engineering. The 36 second figure seems to be an Extrapolation of the ERS to a KERS system. 4Mega joules will only give a 33 second output from a 120KW motor. If you read the Cosworth study from their V6 engine, a greater proportion of the energy available for storage is used in the MGU-KINETIC and MGU-HEAT, with only 45kW stored by the ES. As I understand it the ES is then only used as a top up when the car is no longer traction limited.
#29 maverick69
maverick69
  • 5,975 posts
Posted 23 April 2014 - 16:27
Apparently Renault spent most of their money on software - where as Merc saw the hardware as the primary target (everyone has a budget limit).
Unfortunatly for Renault their system is "fraught with bugs"..... not to mention that brake-by-wire has got rid of a naughty little trick that they were running with RBR last year.........
#30 eronrules
eronrules
  • 3,395 posts
Posted 23 April 2014 - 16:47
any link??? or did u made it up???
Edited by eronrules, 23 April 2014 - 16:50.
#31 maverick69
maverick69
  • 5,975 posts
Posted 23 April 2014 - 16:52
No link. Just chat by the pool....... or I may have made it up :smoking:
#32 eronrules
eronrules
  • 3,395 posts
Posted 23 April 2014 - 16:54
an super awesome article describing more than i ever could ...
with lot's of images and explanations ...
please read  ...
COMPARING POWERUNITS, UNDERSTANDING EARLY SEASON ISSUES AND THE REAL REASON WHY MERCEDES AMG F1 ARE AHEAD - mathew somerfiled
In summary the Mercedes powerunits split turbo arrangement is a performance differentiator but it's decisions that the team have made in the rest of the installation that sets them apart from even those teams that also run the Mercedes HPP unit giving them not only a power advantage but creating a more internally aerodynamic efficient car. ....
with the Renault and Ferrari powered teams struggling generally with the transition of energy under acceleration and braking.  This affects the brake-by-wire system, as holes in the provision of energy or during harvesting will lead to communication issues between the MGU-H, MGU-K, ES, controller and braking system ...
With the Renault and Ferrari powered teams having issues that really revolve around larger packaging and problems with the ERS, fixing either of these issues during the 2014 season will not only be vast and expensive but come with their own compromises.
#33 maverick69
maverick69
  • 5,975 posts
Posted 23 April 2014 - 17:02
That's great. Thanks.
#34 senna da silva
senna da silva
  • 5,750 posts
Posted 23 April 2014 - 17:07
Interesting.
#35 OO7
OO7
  • 23,608 posts
Posted 23 April 2014 - 17:14
If Red Bull's RB10 is running more down force, yet still losing out slightly in the down force dependent S2 sector, that implies that the Mercedes W05 is aerodynamically the better package, as they are faster/similar in the same sector while running less wing.
#36 undersquare
undersquare
  • 18,929 posts
Posted 23 April 2014 - 17:48
I can't help wondering what the drag is from the tall, fat sidepods.
