* * - - - 3 votes
Would races be interesting will fuel and type stops?
70 replies to this topic
#51 KWSN - DSM
KWSN - DSM
  • 9,968 posts
Posted 15 May 2014 - 15:39
I am against pit-stops, were we to have them they had to be slower. Like how at Le Mans it have to take 'x' minutes, rather than as fast as possible. If there were a mandated minimum length, and if the pit-stop were no mandatory, then a team could decide to forego and make their time on track.
Ferrari too fast
Brabham re-introducing look at 7:29
Fangio at the ring look at 4:11
#52 Youichi
Youichi
  • 3,073 posts
Posted 15 May 2014 - 15:52
Refueling sucked, I'd ban pit-car radios and let the drivers choose how they managed their tyres.
I'd also bring all four types of tyres to every event, and let them decide the best usage, three stops on super-softs vs two stops on softs vs one stop on Mediums, vs no-stop hards !
#53 SenorSjon
SenorSjon
  • 3,108 posts
Posted 15 May 2014 - 18:47
How are F1 high pressure refueling rigs road relevant? How is stopping to refuel a car every 30 minutes road relevant?
I would LOVE 10 second refueling at home. No longer freezing your hands of when you are holding the fuel pistol for 5 minutes at -10 C and cold winds. And no, in the Netherlands there are no clamps to keep the fuel flowing.
#54 Fastcake
Fastcake
  • 7,471 posts
Posted 15 May 2014 - 19:05
I'm still waiting for three second tyre changes, but alas they're probably a bit too dangerous for the average service station.
#55 KnucklesAgain
KnucklesAgain
  • 6,208 posts
Posted 15 May 2014 - 20:07
Type stops like this one? I think it will get old soon
#56 zanquis
zanquis
  • 758 posts
Posted 16 May 2014 - 04:58
I think banning refeuling is the best thing they have done in years, it ruined the racing and helped make it more predictable, because the car would behave close to optimal the entire race, look at the stats but during the refeul days, most of the times the order of starting turned out to be order of finish with exception of those who did not finish. Cars have plenty of fuel, they are not cruising to save fuel that much. But atleast now you have cars that go better on full load compared to others and those who go better at the end.now we just need to remove tire limitations, let teams decide which tire to use and when. Maybe team A wants full race on hard with maybe 1 stop, while team b wants to go for super softs with 4 stops.
#57 skyfolker
skyfolker
  • 336 posts
Posted 16 May 2014 - 05:48
There are only few things in racing more gruesome than qualifying on race fuel,waiting for cars to leave for pits to be overtaken and artificial racing between cars with different fuel loads,although proposal from OP would be experiment-worthy.
#58 PayasYouRace
  • 8,932 posts
Posted 16 May 2014 - 08:40
For some reason in F1 the combination of refuelling and tyre stops never really worked that well form the point of view of making races unpredictable. In most cases it meant that out laps would be slower than in laps, so the trick was to stretch your fuel, and overtake by pitting later. You could go for a lighter load and more stops, but unless you were a lot faster and could make the passes on track it wouldn't work well. At least with the undercut in today's races, you are almost certain of gaining position by pitting sooner, but it might come back to the other guy later because his tyres are fresher.
In Indycar they have refuelling and tyre changes, but I think there are two factors that work to make the races more interesting/chaotic. Safety car periods are more common, so it's generally worth gambling on pitting now rather than sticking to your original plan, because it might pay off later. In F1 you'd pit under the SC, but simply adjust your strategy to the end from there. The other thing is the limited fuel tank size, so there's a maximum number of laps that everyone can do. But this leads to fuel saving. If you think fuel saving in F1 is common, then you haven't seen the guys in Indycar gambling on a 2-stop strategy and trying to make it to the end in the last stint.
Would you want to turn F1 into Indy-style racing like that? I'd rather they kept their current characteristics.
#59 SenorSjon
SenorSjon
  • 3,108 posts
Posted 16 May 2014 - 09:22
Indy is gaining momentum while F1 is losing it...
#60 Tourgott
Tourgott
  • 1,148 posts
Posted 16 May 2014 - 09:35
I would turn F1 into everything else than what it is today.
#61 Maustinsj
Maustinsj
  • 1,704 posts
Posted 16 May 2014 - 09:36
How would you get the typewriter in the car?
#62 king_crud
king_crud
  • 2,015 posts
Posted 16 May 2014 - 10:18
the indy race on Sunday was a fantastic race because of all of the different strategies. So yes, I would want it.
#63 PayasYouRace
  • 8,932 posts
Posted 16 May 2014 - 10:55
I guess I'll see you in the Indycar threads from now on :)
#64 king_crud
king_crud
  • 2,015 posts
Posted 16 May 2014 - 12:16
I have been
#65 chrcol
chrcol
  • 1,218 posts
Posted 20 May 2014 - 03:52
refuelling was good, especially when had varying fuel loads during quali, which added some uncertianty to race performance.
At the time they ditched refuelling the reasoning was supposedbly to make pit stops less important, yet they are just as important as before, and now is tons of time pressure on trye changes.
#66 chipmcdonald
chipmcdonald
  • 1,527 posts
Posted 20 May 2014 - 04:51
This is not a logical conclusion.  Without the fuel flow limit, there is still a maximum fuel allowed.  Refuelling still isn't necessary.  So then you can get rid of the total fuel allotment.  The teams can still make the tank bigger if they want to use more fuel.  So in reality, neither the fuel flow limit, nor the race fuel allotment is what prevents refueling.  The only thing that prevents refueling is the rule that says no refueling.
I didn't exactly say anything to the contrary, I'm not sure why people here are so keen on legal interpretations of the syntax of posts?  Obviously I am in favor of refueling in conjunction with no fuel flow limit, for the likewise obvious reasons.
Light cars running to the limit of the engine, without consideration for having to conserve fuel by coasting into corners just to make it to the end - imagine that?  What a fanciful dream...
#67 chipmcdonald
chipmcdonald
  • 1,527 posts
Posted 20 May 2014 - 04:54
The overtakes you see now are because of DRS and tyres, not because of lack of refueling.
And the "overtakes" are not neccessarily "overtakes", when you've got mismatched strategies going against each other that in the end produces the same result.
Passes matter in the last 10 laps of the race this year - before that, it's just getting the tires and fuel strategy sorted.  Swapping positions every other lap because of DRS isn't "overtaking".
#68 SenorSjon
SenorSjon
  • 3,108 posts
Posted 20 May 2014 - 08:56
I strongly dislike bringing racing things into qualy. It only makes the order more stagnant. In the early parts of the '00, Ferrari was not a qualification monster like for example the Williams or McLaren. Bring in race fuel, tire strategy, etc into the fray and you can lose out with what otherwise would be a very fast, single lap car. Back then, you could also (and were allowed to) defend your position, that also helped.
#69 PayasYouRace
  • 8,932 posts
Posted 20 May 2014 - 09:22
The reasoning was more to do with making pitstops safer by removing the high pressure fuelling, and also to make the pit stop strategies less predictable. The perceived problem was that the strategy was set too strictly by fuel loads, and it was inevitable that the driver who ran longer would jump up the order after a round of stops.
Pit stops are still important, but the idea was that with tyre stops there's a bit of variance depending on how well you can look after your tyres and that there's a bit of gamesmanship in trying to pit before your opponent to get an undercut but not too early. I think on balance I prefer without refuelling, but I don't think they quite got what they intended.
#70 SenorSjon
SenorSjon
  • 3,108 posts
Posted 20 May 2014 - 10:13
If teams could choose between all compounds every race, then you could see a bigger difference in strategy. Let the teams choose their own two compounds a month before the race.
#71 Myrvold
Myrvold
  • 4,343 posts
Posted 20 May 2014 - 20:52
Like always in these discussions... There hasn't been a single rulechange in F1, that have removed as much overtakes on track, as the rule permitting filling fuel in pit-stops did.
