http://www.autosport...t.php/id/118066
It seems a team may be scamming the "no accumulation device" rule by varying the pressure between the tank (incl FF Meter) and the engine. This will cause a variation in the volume of fuel in this section of the system allowing the engine to temporarily consume more than the 100 kg/hr maximum. The most effective way to do this IMO would be reducing the pressure sufficiently to form a vapor bubble.
If the scam uses a vapor bubble, it would be acchieved by having LOW pressure in the lines (including the fuel heater). For extra power, the fuel pressure is reduced causing a vapor bubble in the fuel heater and allowing the liquid fuel to be drawn out of the heater in addition to the 100 kg/hr coming from the tank.
When the engine demand is less than 100 kg/hr, the flow meter continues to see 100 kg/hr - the difference is fuel being used to re-fill the heater.
