Hey friends,
Is there any adapter available to use spin on oil filter on the old Volvo B16B engine?
Posted 23 May 2015 - 15:47
Hey friends,
Posted 27 May 2015 - 09:19
Possibly the way to go is to relocate the filter. You can buy 'adapters' for most engines to remote mount the filter. Just be careful/ prepared to do some mods to get a full flow through the adapters. If it has external lines to the filter it makes it very easy.
Last time I did it I spent an hour with the die grinder!. I routed the oil through the cooler to the filter and directly back to the engine instead of the adapter. Saves a few kinks and has less restriction than the original system. Though this was done with the engine in bits.
Hard to find these days is a slant 6 Mopar oil filter mount. Very well designed and uses a Z9 filter which is common to many cars.
Posted 28 May 2015 - 18:45
16b became the 18b then the 20b and with a OHC the 21b and 23b all known as redblocks
so a newer cars parts should fit the basic block
