* * * - - 3 votes
New engine
1416 replies to this topic
#1 Feliks
Feliks
  • 654 posts
Posted 04 December 2004 - 00:42
What change in F1?
Please visit www.new4stroke.com
#2 Mark Beckman
Mark Beckman
  • 782 posts
Posted 04 December 2004 - 14:00
Fekiks, I have built a couple of prototype motors myself and I applaud you knowing the time, effort and tenousisness it takes to acheive an engine at running status.
However I simply think this motor will not be recieved due to many combustion problems such as high combustion chamber surface area, poor combustion dwell time, intake charge dilution and masking which will simply make fuel efficiency and especially exhaust gas emissions impossible for todays standards.
Maybe taking this engine down the diesal road or natural gas (in its favour, the motor has very high rpm potential) might be a better option if you continue to pursue it.
#3 observer
observer
  • 4 posts
Posted 08 December 2004 - 12:43
"Why haven't I figured this out before this guy did?.. it's so simple" ... :confused: Beckman?
Congratulations Andrew, I guess its an ocean of new things in Your idea, and I'm sure it's not Your worry now to develop it. Lot of testing needed... but it seems to be worth the effort.
Keep the faith.
#4 Vrba
Vrba
  • 3,334 posts
Posted 08 December 2004 - 13:37
Very interesting idea! I have enjoyed the reading.
I presume a turbo-diesel version would be very efficient as I'm a bit concerned about the breathing efficience without a blower. Nevertheless, plenty of potential for testing! Andrzej, I hope you filed the patent :-)
Hrvoje
#5 Big Block 8
Big Block 8
  • 2,423 posts
Posted 08 December 2004 - 13:51
Originally posted by Feliks
What change in F1?
Nice concept Feliks!
Unfortunately, new ideas are not likely to go through with the internal combustion engine. As such, it's a very old concept and has been carefully honed through 100 years of compromises between efficiency and cost-effectiveness. To get this (or any) concept competitive with the current traditional poppet valve designs, it would require a huge amount of research (money). And then it would probably be only competitive, not superior.
In different engines and/or applications the idea might be worth checking out though.
#6 Mark Beckman
Mark Beckman
  • 782 posts
Posted 09 December 2004 - 14:02
Keep the faith.
:confused: Observer
I am always up for debate, please feel free to tear apart my thoughts.
Do you really think this design hasn't crossed the minds of a few thousand before, heres a news flash - I've drawn this one on paper and about a hundred variations of it.
#7 ViMaMo
ViMaMo
  • 5,159 posts
Posted 09 December 2004 - 16:18
How does top crankshaft and the pistons receive lubrication?
#8 observer
observer
  • 4 posts
Posted 09 December 2004 - 22:41
The top crankshaft revcieves lubrication just as the main piston do. Just turn a normal engine upside down ( for. eg aircraft engines ).
You could have drawn even 101 variations, and I probably did so too, but it's not about drawing and wasting pencils, it's about drawing the RIGHT thing and deciding wich way to go.
Didn't mean to tear apart Your thoughts. It would be better rather to focus them.
Debate is needed here I guess.
Greetings,
#9 Mark Beckman
Mark Beckman
  • 782 posts
Posted 10 December 2004 - 15:51
101 ? Mate I assure you I have thought and drawn thousands of engines searching for "Gods gift to the motoring world" as many others before me and after me will continue to do.
As a kid I would run to my Dad and show him my latest radical design to be always met with "its been done" everytime :
I love looking at different and especially radical designs (of which you can find many in this forum), but the bottom line is that they must perform a basic function being that they must produce 'X' amount of energy from 'X' amount of fuel at 'X' amount of weight and at 'X' amount of production cost.
#10 schumyfan
schumyfan
  • 111 posts
Posted 22 December 2004 - 22:52
What change in F1?
I think it is a really good idea. Just a couple of questions/concerns:
1) In a conventional camshaft, the cam profile can be varied to control the valve movement during various phases of it's travel. This design will always give a "symmetrical" movement, since it is driven by a crank. The inlet/exhaust windows can be profiled to achieve a similar effect, but that might compromise the flow characteristics.
2) When the mixture ignites, it will exert (almost) equal pressure on all the pistons. So the engine will try to "drive" the valve-crankshaft in 2 ways, viz., (a) the timing chain/system and (b) through the piston valves. This may make the over-head piston valve system weak due to fatigue and impact loading. Resonant frequencies will have to be carefully studied to prevent a run-away system or a "stop-stop-go" system.
Probably these issues have already been thought about and resolved! Please feel free to correct me if I am wrong...
#11 Mark Beckman
Mark Beckman
  • 782 posts
Posted 23 December 2004 - 04:33
Ok, your wrong.
1. The lateral positioning of the cam-crank can be changed to give non-symetrical timing, in fact the present positioning is already in a non-symetrical timing position.
2. The Guys obviously got a running engine and probably doesnt even own a computer so I would think 'resonant frequency studies' are probably a moot point to him. :lol:
#12 johnyboy
johnyboy
  • 4 posts
Posted 08 January 2005 - 22:59
Sorry to be a sceptic, but I can see a few problems looming, won't go into everything but two biggies would be:
Uncontrollable uHC emissions, a piston passing a port will doubtless lead to both high wear and lube-oil emissions.
There are too many large crevice regions hindering effective exhaust scavenging, resulting in poor combustion, high HC and CO emissions and a poor full-load performance. Also difficult to see a way to avoid back-flow to intake system.
Always like to see new ideas though, and as someone mentioned earlier there maybe a niche market out there where emissions isn't such a big deal.
J
#13 Mark Beckman
Mark Beckman
  • 782 posts
Posted 09 January 2005 - 14:10
J
Are you mocking me Johnyboy ?? :lol: (read post 2)
Seriously though even China ect will be frowned upon shortly about there contribution to the dark clouds above so theres not going to be a lot of places left.
#14 johnyboy
johnyboy
  • 4 posts
Posted 09 January 2005 - 21:11
The chinese government are actually being proactive in trying improve the emissions standards of their growing vehicle fleet, won't help the CO2 burden, but nothing will really.
By niche markets, I really meant something v. different (not automotive certainly), nothing really comes to mind though.
Oh, and I wasn't mocking :evil: , but I will if you like! I may also learn to read other peoples posts before I reitterate many of their comments.;)
J
#15 observer
observer
  • 4 posts
Posted 18 January 2005 - 13:51
After getting into it a little deeper, it seems to be pretty difficult technologically... but it also has many really NEW things in it.
And about those emissions... the combustion chamber would be really horrible if it would be not dynamic - but it IS dynamic here, so it actually might end up with better and cleaner burning.
I doubt all that oil-emissions-concerns. I think that the flow is forced psyhically in the right way, considering exhaust resonances too etc. I'll try to be a little optimistic and not to be narrod minded and i'll say that there might be more advantages than disadvantages in this idea. I guess this is the first prototype, so there's a lot of work ahead and lot of fixing the problems and testing the right model.
Open minded thinking, new, interesting.
Maybe it's worth to send guys a computer ;) Oh yes, I'm mockng...
#16 crono33
crono33
  • 346 posts
Posted 21 January 2005 - 17:30
am i wrong when i believe that some power is transmitted to the upper valve/pistons?
gm
#17 observer
observer
  • 4 posts
Posted 22 January 2005 - 13:42
yes it is
#18 clSD139
clSD139
  • 129 posts
Posted 24 January 2005 - 14:07
The oscillating engine! Even worse than the presentation of it:
http://www.geocities...0/prototype.htm
Otto cycle engines are history, or will largely be replaced by turbines etc.
http://www.osti.gov/...osti_id=6142153
The rise of real turbine-engines:
http://www.historyen....com/SP4306.htm
#19 Mark Beckman
Mark Beckman
  • 782 posts
Posted 25 January 2005 - 15:36
gm
Its a bit more complex than that.
Simple version, if the valve pistons are going away from their TDC's at firing point then indeed they are helping the torque of the main crank but at the cost of losing TDC compression dwell time which is not good
On the other hand if the valve pistons are still approaching their TDC's they will be increasing TDC compression dwell time which is desirable to build combustion pressure to maximum before applying leverage to the crankshaft but this pressure then forces the valve pistons/cam-crank against the main crank
This case is even a bit more complicated because the 2 valve pistons dont reach their TDC's at the same time (I havent looked at it intently enough to work it out)
Engines are give and take, come up with a bright solution and theres always a downside and thats why we still run around in constantly refined poppet valved engines.
#20 Mark Beckman
Mark Beckman
  • 782 posts
Posted 25 January 2005 - 15:50
Its actually a great presentation that should draw in some suckers hard earned $ and then never be heard from again.
Not the fist time, wont be the last time. :rolleyes:
#21 clSD139
clSD139
  • 129 posts
Posted 27 January 2005 - 14:10
Some ideas are on the net, other existed only on paper but the best are already in cold hard metal. See what this sucker tries to do:
http://www.geocities.../evolution.html
(suggesting "telescopic valves", 16V+ 16v sort of...)
There are also responsible and well informed fanatics, here the patent of a big valve with a little in it:
http://patft.uspto.g...RS=PN/6,546,902
Shame that interesting site's with BB's like that are vulgarised. It is even history-falsing, for my part they can put them with the rest in Abu Graib.
#22 Feliks
Feliks
  • 654 posts
Posted 11 February 2005 - 21:08
Rent a computer--effect
Posted Image Posted Image
For resonance in my engine, I need rent computer for nuclear simulations-anybody help me?
#23 desmo
  • 13,439 posts
Posted 11 February 2005 - 22:20
Build a single cylinder test mule with changable EX and IN lengths and generate some empirical data?
#24 clSD139
clSD139
  • 129 posts
Posted 12 February 2005 - 17:58
As mentioned, emissons could become a problem when the top pistons use their oil. But the proportions of the valves seem accordingly to the upper-crankshaft size. But when the real valves are sliding in the side why not try to do the same in the main cylinder, a 3 dimensional expansion chamber. What are the advantages over the mechanical loss? What with higher revs and/or detonation? How is heat best extracted for motion?
This new 4 stroke seems exactly the opposite of a rotating valve system. No more wine-glass-bottom poppets but discs with a pie out it instead. When the 3 quarters have passed the valve opening gas can be exchanged. The thing almost looks like a beefy crankshaft-balancer so imagine the potential speed. No more rockers! Why need ram if the rpm can be doubled? It'll also be more efficient then electric valves.
But perhaps the real 4 stroke evolution has the characteristics of a 2 stroke. Direct injection existed in the 50' but only now serious applications are tried for double work of a piston engine. No moving parts in the combustion chamber (container), except the transmission-connection (rod) and the energy catcher (piston). Not the number of interdependent parts but also the functional proportions are important I think, and the environment of course...
#25 clSD139
clSD139
  • 129 posts
Posted 12 March 2005 - 20:23
The used gas can suck fresh mixture in using underpressure. Both valves have to be open, like illustrated.
Posted Image(see indicated icon)
Maybe using Co-latency (of exhaustmatter and a decelerating piston) can re-introduce a 2stroke principle!!!
Only yesterday (Belgian release GT4) I discovered this "inspiration"! I don't think a polished exit is a mistake!
#26 Feliks
Feliks
  • 654 posts
Posted 29 January 2006 - 12:34
:rolleyes: Welcome! New animations 3D and position pistons table :) :)
#27 Powersteer
Powersteer
  • 2,460 posts
Posted 03 February 2006 - 05:08
This engine work like a two stroke engine with two crank shaft and the pistons meet each other. Instead its a four stroke. Mechanically a brilliant idea.
#28 Feliks
Feliks
  • 654 posts
Posted 03 February 2006 - 09:08
Possible this mutation is better?:
In old "below head" are impossible enough compression ratio.
In "this version" not problem...... :rolleyes: :rolleyes:
Are unfortunately drawings.......
#29 Stian1979
Stian1979
  • 420 posts
Posted 07 February 2006 - 00:38
http://www.revetec.com/
I think this look more interesting and atleast they have started to sell there stuff allready. Maybe you should ask for partnership with them felix? As a boxer it will not colect a huge amount of oil on yout valve-pistons. They seam open minded so if not even they like your stuff you should let the project rest. Why not runn 1 crank for echaust and 1 for inlet air? Then I think you could make the construction lower and also have variable timing.
#30 Tooheavy
Tooheavy
  • 34 posts
Posted 07 February 2006 - 06:03
Revetec is another example of a crap engine idea turned expensive development project. :mad: More victims of the torque uber alles mentality, and again fleecing large numbers of uniformed investors because of it.
They have a boxer engine with all the weight and bulk penalties associated with doubling up on cams, blocks, heads, manifolds etc. (There is a reason why boxers are not the standard engine format). To this they add a cam drive system for the pistons, with huge bearing issues. In essence all they are doing is replacing the crankshaft with a much trickier dual counterrotating three lobed camshaft.
So now they are crowing about getting three times the torque. Like that is some kind of miracle when you have three times as many piston strokes per crankshaft revolution! And they have only managed to get 150Nm out of a 1.4l engine (equivalent to about 35Nm per litre from a conventional engine or one third that of a good racecar engine (110Nm/litre) at a maximum speed of 2600 rpm (because of course the pistons are going at 7800 rpm at that speed).
But of course they haven't told the world that that is the limit in terms of their rpm. Or that a good inline four will produce three times the power they have achieved, or that high torque/low rpm is bad in that it means a much heavier and more expensive clutch and gearbox. Or that the piston driving bearings are spinning at huge speeds and are likely to pound themselves and the cam to pieces in short order.
There should be a website created to debunk idiot ideas like these. Or maybe I should loosen my morals and become the one parting the stupid people from their money.
End of rant
As a public service I will add the following keywords to hopefully open the eyes of anyone doing a search before investing.
Revetec Crap Shit Rubbish Steaming Pile Flawed Bad Too Heavy
#31 Stian1979
Stian1979
  • 420 posts
Posted 07 February 2006 - 06:26
don't say it loud!
Let them hock up and don't bother us with there patents. I'm shure they could build a nice hopeless engine together. And please Felix also be shure to make it compound engine
#32 Christiaan
Christiaan
  • 1,831 posts
Posted 20 February 2006 - 13:50
Theres a plethora of new engines being advertised. Its like the 50s again. I don't see any one of them being the next big thing
#33 Feliks
Feliks
  • 654 posts
Posted 21 February 2006 - 13:29
Christiaan, Your motto help:
"Our parents assigned pain when they sent our contrary to our will for school .
We learn for personal good. I think, that it is obliged to be by whole life so, not only as there is young .But little slowly.
It can change hurts in too joy,when we little learning.This land are name: "Global". There is next natural step of motosport. " :wave:
#34 hydra
hydra
  • 417 posts
Posted 21 February 2006 - 16:26
I wish I saw this earlier... I was under the impression that specific weight (engine weight/displacement) got better the more cylinder banks you had due to the crank (heaviest single part of the engine) getting shorter. For instance, a V6 will invariably be lighter than an equivalent straight-6, same goes for a V8... Granted there's less of an advantage with 4 cylinders, but its still there. A Subaru EJ25 motor weighs only around 140kg, and that's with iron cylinder liners and a cast iron manifold. Honda's K20 (S2000) weighs 145kg and has ceramic liners, thin-wall headers, and 500cc less displacement...
#35 Feliks
Feliks
  • 654 posts
Posted 06 June 2006 - 11:46
If possible please made traditional p-V diagram (simile Otto) my engine.
It's little different.........
#36 Feliks
Feliks
  • 654 posts
Posted 10 June 2006 - 23:31
Too unfortunately drawing.....need 3D ....
But idea are understand ??
Regards Andrew :) :)
#37 Feliks
Feliks
  • 654 posts
Posted 05 August 2006 - 22:04
One important question :
One CH physicist elegant describes:
intake / inertia is better for valve piston than main piston !!
Another important question:
second important question:
#38 Stian1979
Stian1979
  • 420 posts
Posted 06 August 2006 - 04:09
You have ben asked befour and you have not replyes as I can see HOW DOS THE VALVE PISTONS GET LUBRICATION?!?!?!?!?!
This engine has ishues and a concept far more fuel efficiant and tested is allready out there.
This concept has ben used for 80 years and is the moust fuel effician internal combustion engine.
#39 AndrewD
AndrewD
  • 36 posts
Posted 06 August 2006 - 06:21
"This concept has ben used for 80 years and is the moust fuel effician internal combustion engine"
Thats a bold claim. Care to provide supporting information to that?
How can you adjust intake valve timing and inlet flow characteristics to suit a wide variety of operating ranges?
How does that piston get lubricated?
How about emissions?
#40 Stian1979
Stian1979
  • 420 posts
Posted 06 August 2006 - 08:40
Thousands off ships world wide use this engine and is not a bold claim, but a fact.
Fuel oil consumtion down as far as 160g/kwh is curently in use.
How do you adjust valve timing on anny other engine?
What you have not mentioned is how the air gets into the cylinder and I'm kind off suprised you do not mention that problem first.
This engines nead a blower and therfore they are more exspensive to produce.
The worlds largest engines are build on this concept.
Do I have more bold claims I nead to back up?
#41 Catalina Park
  • 5,888 posts
Posted 06 August 2006 - 09:29
I much prefer this version....
#42 Stian1979
Stian1979
  • 420 posts
Posted 06 August 2006 - 10:06
The old cummer engine. Oposit pistons are a great design, but space consuming.
My favorite is this one
#43 Catalina Park
  • 5,888 posts
Posted 06 August 2006 - 10:54
The Commer TS3 is really a very compact engine. It sat below the floor of the truck, not much higher than the chassis rails. They are almost half the height of a 6V/53 GM of similar output. ;)
#44 AndrewD
AndrewD
  • 36 posts
Posted 06 August 2006 - 12:37
Well, where do i start?
160g/kwh, wow, those ships must go through their fair share of oil then...
In any other engine you would find a camshaft to actuate a valve to adjust valve timing, and hence only a new camshaft would be needed to adjust those characteristics. But in your case, that engine would require a new cylinder sleeve and a complete rebuild of the upper crankcase, if not modification to the crankshaft, conrod or piston.
So far as air getting into the engine, if you would like me to critisize the engine design furhter let me know, id be happy to. So how about you clear it up for me, how does the air get into the cylinder? Why does it require a blower? Is a blower required to overcome severe pumping losses? if this is not the case, im sure with acoustic tuned manifolds you could utilise the scavenging effect during overlap to create enough vacuum at the inlet valve and raise the volumetric efficiency of the engine to a reasonable level.
I wonder why the worlds largest engines are built on this concept. Large engines would be rpm limited by large inertia forces, and most likely steady state operation and hence a design such as this would be suited to their operation.
If you ask me a true engine is designed for transient operation, such as motorsport racing, and hence any engine designed for less is out of its league.
Think of the design challenges in overcoming turbo lag or combustion chamber design in a high compression ratio, high boost operation. Thats an engine worth designing. How about the complications of lubrication in high g force loadings? Should i continue?
I guess what i could have said is, that while this engine may be suited to a niche market, it is far from perfect.
#45 Stian1979
Stian1979
  • 420 posts
Posted 06 August 2006 - 15:52
Dos anny other combustion engine widly used have bether fuel consumtion?
So why can I not use diferent camshaft for this engines exhaust valve?
Please come with it.
If you can not tell why it nead a blower then maybe you should not have started making coments in the first place. I'm shure 90% off the others in here can tell that by first look.
I wonder why the worlds largest engines are built on this concept. Large engines would be rpm limited by large inertia forces, and most likely steady state operation and hence a design such as this would be suited to their operation. [/B]
They are build on this concept because it's the moust fuel efficiant and cost efficiant one.
They has also ben used by smaler engines like GM diesel and Detroit. Some large truck has ben using them peterbuildt if I remember corectly.
If you ask me a true engine is designed for transient operation, such as motorsport racing, and hence any engine designed for less is out of its league.[/B]
A true engine is the bast design and what that is we will newer know since all exsperimantal things is baned. Did you read F1 engine regs latly?
Originally posted by AndrewD Think of the design challenges in overcoming turbo lag or combustion chamber design in a high compression ratio, high boost operation. Thats an engine worth designing. How about the complications of lubrication in high g force loadings? Should i continue?
I guess what i could have said is, that while this engine may be suited to a niche market, it is far from perfect. [/B]
How are you going to have turbolag when you got a blower :confused:
I can not see the lubrication problems your talking about witch I asume other engines would have aswell.
If it's lubrication off cylinder liner you worry about then I would inform you that this engines has independent lubrication off cylinders.
So please tell me what is the perfect engine?
Traditional two strokes is suited for a niche market(chain saws and mopeds) four strokes for a niche market (like auto and lawn movers)
#46 12.9:1
12.9:1
  • 270 posts
Posted 06 August 2006 - 21:40
Ok, Ok,
Just arguing may be fine for the 'fan boy' forum, here at The Technical Forum we try to bring "facts" and information to enlighten each other! Google is so handy for this.
Most powerful - Most Efficient
#47 Greg Locock
  • 4,656 posts
Posted 06 August 2006 - 23:33
0.26 lb/bhp hr=161 g/kWh~ 52% efficient.
You might find some combined diesel/steam plants, using steam turbines driven off the exhaust heat, that are a little better than that, in return for an enormous increase in plant complexity and cost.
Alternatively you could put Peltiers all the way down the exhaust, again a lot of cost for not much output.
Finally you might find some fanatics claiming better efficiency than that for Stirling engines. I iamgine that if you built one as big as that diesel engine it probably would be more efficient. It would also have about 1/3 the power output (WAG).
The fact is, oil is still cheap, it is not worth wringing every last joule out of it.
#48 Powersteer
Powersteer
  • 2,460 posts
Posted 07 August 2006 - 00:13
This is a 2 apex rotary patented by an indonesian named Adi. I cannot find pictures of it on the net so I had to draw it.
#49 Powersteer
Powersteer
  • 2,460 posts
Posted 07 August 2006 - 01:04
Q U A S I M O T O ? ? ?
Quasiturbine Photo detonation?
#50 J. Edlund
  • 1,295 posts
Posted 07 August 2006 - 17:43
There are combined cycle gas turbines that have an efficiency of about 60%, one could however argue that those are external combustion engines. With two stroke ship engines the exhaust heat is usually used for something, if not running a turbine directly, or heating water to power a turbine, it is used for other heating purposes (after first having passed the turbochargers).
The stirling engine is also an external combustion engine (or in some cases not a combustion engine at all). In any way, its efficiency will depend much on the materials used in it, like with gas turbines, as this usually limit how high temperatures that can be used.
