Ford Mk IV and Weslake heads. What about ?
Posted 14 December 2006 - 21:44
1. Ford GT 40 Mk IV had Weslake heads for his "427" big block ?
2. It is the first Ford had them, or also Ford Mk II mounted Weslake heads ?
3. Gulf Wyer GT40 ('68) was the first Ford car that mounted Weslake heads ?
thanks
I've read all the three versions of this story.
What's the true one ?
Posted 14 December 2006 - 21:54
However, I do believe that the Weslake people did up some special heads for John Surtees' CanAm Lola circa 1968 and that was a large-bore Chevy.
I stand to be corrected on all this, of course.
Edit: Should have digested your post a little more thoroughly before responding. Sorry. As to your point #3, I cannot be sure of that but I can tell you that Dan Gurney was using those special heads on his USAC Champ car in 1968 and possibly even late 1967 and I would think well before they may have appeared on the GT40's/Mirages. It occurs to me just now, in fact, that they were fitted to his CanAm Lola T70 in 1967.
Posted 14 December 2006 - 22:01
MkIIs used a medium rise aluminum head with Ford XP (experimental) part numbers.
MkIVs used tunnelport heads. So called due to there round intake ports. Both the MkII & MkIV had 427 CI (7Liter) engines.
There is still some debate regarding wether the MkIV heads were aluminum or cast iron. I have internal Ford memos indicating both were used.
Posted 15 December 2006 - 01:35
Posted 15 December 2006 - 03:10
The first ones were, IIRC, in a Lola.
And I think I recall (less sure of this...) that they were on experimental (or pre-production) 351 blocks. Or at least blocks with an extra inch of deck height.
Posted 15 December 2006 - 03:47
Lothar Motschenbacher also ran the G-W heads in his M6B.
Posted 15 December 2006 - 12:11
Posted 16 December 2006 - 08:02
Thanks, as usual, for your answers:
cstlhn
Gurney Weslake heads were used in 1968 & 69 (1) on the Mark I cars and the 5 liter motors.
Manfred Cubenoggin
...and possibly even late 1967 and I would think well before they may have appeared on the GT40's/Mirages...
Right, John Horsmann says that (1) in his book "Racing in the rain", but Wimpffen' book "Time and two seats" reports the Mirage M1 car at the 1000Km Nurburgring 1967 (Piper-Thompson) as "Mirage M1 Ford-Weslake", so also in 1967 Wyer's team was using Weslake heads.
cstlhn
Do you know if the MkIV heads had a particular name or if Ford engineers done them a code ?
Posted 16 December 2006 - 11:40
Chuck
Here is a comparison of the medium riser vs. tunnelport intake side.
Here is an add showing the pushrod tubes in the intake.
Note you could buy the SOHC and tunnel port engines over the counter, or tunnel port heads and intake separately. The part numbers are all C7 indicating the engineering work for these heads was done in 1967. The one tunnelport head I had was a C7 casting number but the casting date was 1970 indicating they were viable service parts into the early 70s. By the same token, my 427 side oiler service block was cast in '72. If only a guy had the foresight to stock up then
Posted 16 December 2006 - 16:43
Posted 24 December 2006 - 12:47
These show two basic Head types
Type 1 known as Street Head
Type 2 known as Competition Head
The main difference being the shape of the combustion chamber and the size of valves used.
Other differences were the rockers and pedestels two types of each altering the ratio.
I think the competition one would be the one drawn september 1965.
Heads should have external factory mark to show which is which.
It was good to see that in the Classic and Sportscar gt40 test the Gurney Weslake powered car still out dragged the others even the new Ford GT.
Stuart
Posted 24 December 2006 - 20:14
Originally posted by chuckbrandt
.....my 427 side oiler service block was cast in '72. If only a guy had the foresight to stock up then
That applies to all of us, of course...
But what I'd really like is an explanation of what this 'side oiler' term means, please.
Posted 24 December 2006 - 20:55
On a "Side Oiler" which was introduced in '65 a new gallery was cast into the side of the block to give the main bearings priority oiling and then the cam. This was supposedly needed for sustained high RPM on NASCAR tracks. Only 427 blocks from '65 on had this.
Chuck
Posted 24 December 2006 - 21:20
Gurney's 1967 Rex Mays winning Eagle.
photo by Gil Munz-scanned by Ike Smith
Posted 25 December 2006 - 10:29
Sometimes it takes a bit of guesswork to work out what various nicknames mean.
Who, for instance, could possibly conclude that 'wide block' meant an engine with heads that sat out wider than its successor? The block being the same...
Posted 25 December 2006 - 11:04
It must work the other way too, and with Europe vs UK vs Australasia, and even between different types of racing.
Posted 25 December 2006 - 22:30
Posted 25 December 2006 - 23:28
Also there are a couple of really interesting SAE papers written about the 427 used in the GT-40 Mk II.
http://www.sae.org/t...l/papers/670066
http://www.sae.org/t...l/papers/670067
Chuck
Posted 26 December 2006 - 11:04
Posted 26 December 2006 - 12:15
Chevy also used the A833.
Posted 26 December 2006 - 13:54
AMC was always an amalgam of parts from the big 3.
Low-Medium-High Riser terms refer to intake and cylinder head development within the Ford 427 program. The 427 was Ford's primary performance engine from '63 - '68 and received a lot of development effort.
The '63 427s got a cylinder head that was only a little changed from the cylinder heads of the 390 and 406 of earlier years. It did get larger valves and a machined combustion chamber. This head and intake combo would later be termed "Low Riser" and it should be noted that it fit under the stock production hood of the Galaxie.
For '64 it was decided that to make more power for drag racing the intake charge needed a straighter shot and the "High Riser" head and intakes were designed. The ports on the High riser are much taller, the floor is in roughly the same position but the roof was raised about 1/2". The intake manifolds that coorespond to this new head were much taller as well raising the carburetor(s) several inches above the Low riser. It was impossible to fit this induction system under the hood of the Galaxie and Fairlane (Ford Built 100 '64 Fairlanes with 427 engines for drag racing called the Thunderbolt), so a tear drop shaped hood bubble with inlets in the back was fitted.
For '65 they took a more scientific approach and designed the "Medium Riser" head and intakes using a flow bench as part of the GT-40 program. Although the ports were shorter and a little wider than the "High Riser" they flowed better making an easy 525 HP in the GT-40. An interesting side benefit was that the "Medium Riser" setup fit under the hood of production cars.
All three styles of head require matching intake manifolds and Ford sold dual plane manifolds for each one with single or dual holley 4 barrel carburetors. The Medium Riser got a couple of other interesting intakes, one a single 4 barrel design with the carburetor offset slightly to one side to equalize runner lengths called the "Sidewinder", and the other a single plane dual 4 barrel intake with an air gap underneath the runners which is refered to as the "Tunnel Wedge" intake.
Simultaneously with all this the SOHC heads were being designed for the 427. This hemi head had large round intake ports because they weren't pinched by the push rod placement and a camshaft mounted on top. The cams were driven by a 6' long timing chain that ran off of a sub camshaft mounted in the normal location. This engine was outlawed by nascar but found dominance in drag racing for many years.
Then as mentioned above, in '67 the tunnel port heads and intakes were designed. The desire was to have the large round ports of the SOHC in a pushrod engine. To make this happen the push rods passed through tubes in the center of the intake port of the manifold.
The SOHC and the Tunnel port were never sold in a production car, you had to buy them over the counter at your Ford dealer. But the Medium Riser was used on all production cars that got the 427 through '68.
Chuck
Posted 27 December 2006 - 01:45
Posted 27 December 2006 - 02:14
Ford built one factory experimental drag pickup in 1963. The current owner, Bill Naudain, traded his brand new thunderbolt for it in '64. Bill is a real story teller and one of the many I heard the day I met him and saw the truck involved a "lippie" cam. He said that Ford wouldn't give him any monetary support for the truck but when they saw a racer was doing well they would frequently give him free parts. The story was they sent out the lippie cam (which I had never heard of at the time) and it was supposed to be the latest and greatest thing, but they couldn't get it to run right. Don Nicholson said it worked great for him. It turns out there were some girls hanging around the shop when they installed and they got it timed wrong and that's why it didn't work for them.
I spent several weeks trying to corroborate his stories and the "lippie" cam eluded me until I finally found this ad in a Holman Moody catalog. Mystery solved.
CDB
More info on the F-100xl at www.f-100xl.com
Posted 27 December 2006 - 03:21
AMC did not use an amalgam of parts fromt the big 3.Originally posted by chuckbrandt
[B]Ford, Chevy and AMC did all use their own versions of the Borg-Warner T-10 transmission in the early years of sporty 4 speed vehicles.
As you said, many used the Borg-Warner T-10 variations (and Doug Nash made the ultimate version) but other than that, AMC used their own versions, 20 and 35, of the Dana rear-end.
AMC switiched to a Chrysler auto some time in the seventies, from the Borg-Warner M-11 and M-12.
The only thing wrong with the Borg-Warner was it was not designed to be set-up for hi-po work.
Bob
Posted 27 December 2006 - 03:25
Posted 27 December 2006 - 08:53
But my question was : did Ford Mark IV use Weslake heads ?
In the last book of Janos Wimpffen ("Winged sport cars and enduring innovations", I bought it for Christmas gift) he says that when he's speaking about 1967 season.
Following your answers I understand that is not right, because the Mark IV used Ford heads only (tunnel heads).
What do you think about Wimpffen's statement ?
Best wishes for a happy new year everybody.
Posted 27 December 2006 - 12:52
Bob
I'm probably talking about their later years, but here is what sketchy evidence I have. We had a '74 AMC Ambassador when I was cutting my mechanic teeth in the late 70s. It had an AMC 360 engine, but a chrysler torque flite transmission, Autolite/Motorcraft (ford) carburetor and charging / electrical system.
Probably just an expediency in the fading days of the Pacer
Chuck
Posted 27 December 2006 - 13:22
I would tend to disagree with his statement but I've learned it's foolish to say never no way in situations like this. I am quite certain that the Gurney Weslake heads only fit the smallblock. But it would not surprise me if they put in a smallblock for a race or two if they thought it had an advantage. I recently read they ran a four cam indy engine in a GT-40 at one point. I'd love to track down a picture of that configuration. Did any of the Mk IV cars race after the '67 season?
Here is the GW setup in GT-40 Mk 1 1083
Posted 27 December 2006 - 18:20
Even if the FE heads had attached in "standard" form, Surtees found out that what works with small engines, cannot neccessarily be transfered to large ones.
Bob
Posted 30 March 2007 - 21:23
Finally I have the answer.
Mr Phil Henny, former Carroll Shelby's employee at the time of the Gurney-Foyt MkIV's win at Le Mans, wrote:
"the 427 ci was a NASCAR engine, cast iron side oiler and aluminum heads. Weslake heads were never manufactured for the Ford Big block."
Phil Henny is the author of the book "Just call me Carroll"
Posted 01 April 2007 - 01:37
At Le Mans the iron ones were used.
Best
Posted 01 April 2007 - 07:37
Please help me:
thanks
i pidi pesanti. . . e Piedone. non era pesnate?
