How much Downforce does a Modern F-1 Car produce ?
Posted 28 September 2000 - 04:44
Posted 28 September 2000 - 08:39
In medium-downforce trim it is 2,500-2,800lbs. at 150mph at a better lift drag ratio of around 3:1.
In low-downforce trim the downforce figures are obviously less, but the lift/drag ratio improves to something like 3.3:1.
It is possible to dial in virtually any amount of downforce within reason. The trick is to get the most downforce from a given amount of drag.
Posted 28 September 2000 - 17:13
Niall
Posted 28 September 2000 - 19:00
Posted 29 September 2000 - 04:52
This is part of the reason that I believe an F1 car has a similar top speed potential as a CART car. Considering the smaller frontal area (narrower track and tires) and smaller wings for a given down-force to weight ratio, the F1 cars 12% to 15% HP disadvantage would soon be balanced out when set up to run a theoretical superspeedway lap.
Posted 29 September 2000 - 16:22
Now that would be a media stunt....
Posted 29 September 2000 - 17:18
Posted 29 September 2000 - 20:53
Posted 29 September 2000 - 21:35
Yelnats: I also agree with you over a F1 car having a higher top speed than a CART car.
1. An F1 car is slim. CART car is not.
2. F1 car uses multiple elements in wing for efficent downforce. CART uses one giant wing. Not efficient.
3. An F1 car has a higher power to weight ratio than a CART car. Therefore an F1 car can lenghten it gear ratios much further as it won't reach Terminal Velocity as easy as it has more power for a certain acceleration due to its greater power to weight ratio.
Niall
Posted 30 September 2000 - 00:27
Additionally, Ali please stop arguing that since a F1 car has a higher power to weight ratio, it can be geared for a higher top speed than an indycar. Top speed is determined by horsepower and drag, and weight is nowhere in the equation. The simplified equations from the book "Race Car Engineering and Mechanic" states:
drag force = (0.0025)Cd(Frontal Area)(Velocity) squared
Cd = coefficient of friction
Horsepower = (.0027) (drag force) (velocity)
As the equations show, if you double your top speed, your drag force goes up four times and your horspower requirements go up 8 times.
Posted 30 September 2000 - 15:43
Posted 01 October 2000 - 06:52
Posted 01 October 2000 - 09:28
Posted 01 October 2000 - 09:32
CART's aerodynamic package is potentially more efficient than F1's, at least without the Hansford wing, as CART still utilises ground-effect tunnels, which are a more efficient means of generating downforce than the wings or diffusers of an F1 car.
Posted 03 October 2000 - 02:22
Posted 03 October 2000 - 02:29
gascoyne of Jordan states in an article in F1 racing that in Monaco trim, and at Monaco top speeds, total weight on the tyres is 2.5 times the static weight. cD in that trim is in excess of 1.0. In Hockenheim trim, cD is in the region of 0.7.
