Horizontal rear brake calipers
Posted 14 July 2009 - 13:41
In the last autosport magazine, there is a very interesting and clear analysis of brawn gp and red bull cars.
But there is one thing i have not really understood: the analysis of location of the caliper at the bottom of the disc, read it:
"the only problem can be brake-pad knock-off with high lateral forces if the bearing assembly lacks stiffness. The conventional
location is about 'three o'clock" - the neutral axis of any potential deflection"
i have misunderstanding with the last part: i would like understand why the neutral axis of any potential deflection is at this location.
I have found nothing on the web.
Thank you for your rsponses !!
Elno.
Posted 14 July 2009 - 13:50
I too would like to know the reasoning behind this, apart from occasional practical, packaging reasons, or to alter the polar moment of inertia or CoG, I have never understood why the calipers move about from design to design."the only problem can be brake-pad knock-off with high lateral forces if the bearing assembly lacks stiffness. The conventional
Elno.
Posted 14 July 2009 - 14:53
Hello everybody, first time i post.
Elno.
Posted 14 July 2009 - 15:07
In this house I decide. Ooh! Hello darling, didn't see you there...Adrian Newey decides where everything goes.
Posted 14 July 2009 - 19:34
wheel will move in or out at top or bottom do to D/F or other loads like weight transfer or bumps/curbs
and as the brake disk will follow wheel moves it can hit the brake pads
but this is less likely at the 3;00 mid position as there is little fore/aft load changes vs high up/down changes
Posted 14 July 2009 - 20:18
the article forgets to say that the 9 o'clock position is as good and stable as the 3 o'clock, but hardly ever used( at the front) because of
steering linkages.
I learnt so much about designing disc brakes for semi-articulated trailers when at Fruehauf, you couldn't imagine
the blunders that were made.
I got so upset one day that I overhauled an old drum brake unit and it out-performed the newest fangled disc brake setup with EBS and all !!
Edited by macoran, 14 July 2009 - 20:25.
Posted 14 July 2009 - 20:30
Edited by meb58, 14 July 2009 - 20:30.
Posted 14 July 2009 - 20:32
I understand the reason, but less clear to me is the cause...why the rotor distorts at 12 and 6 more than at 9 and 3.
The rotor doesn't distort. it moves (rocks) due to lack of bearing stiffness/stability.
Posted 14 July 2009 - 21:36
if i may.....?
By definition, the centre bearing has a very small amount of 'play' in it, to allow it to turn. If a non-steering hub is straight, square and 'neutral' (i.e. no inbuilt caster or camber in the geometry), there would theoretically be 'slop' movement in all directions, but by bearing the weight on the stub (the tyre touching the ground) the inherent vertical play is already mostly taken, unless the tyre tread is completely flat, the bearing is directly above the tread centre and the road surface is completely flat as well. Therefore the 12 o'clock or 6 o'clock positions are more stable for the caliper position as the play (or 'slop') are already taken up by gravity. Given that the desire for the unsprung parts is to be a) as light as possible and b) as helpful in terms of CofG as possible, 6 o'clock satisfies the criteria of low CofG height and being in the best possible 'neutral' plane to resist the pad knock-off that's so well demonstrated by Macorans sketch.
yeah? i think......
Yours ......... Wrighty (hopefully happy to help and incidentally ex-Tinsley>Corus and Montracon
ps - no wonder drums worked better than EBS discs.....in terms of the pad size there was no comparison....those ZMX hubs were bad boys
Posted 14 July 2009 - 22:28
The rotor is centered whether there is pressure on the brake pads or not. This is not a street car. If there was any binding to speak of on the slip pads that the rotor rides on, the rotor would shatter. When they do shatter, it is because of a failed wheel bearing.
There is a nice cut away drawing of the wheel bearing and rotor by Matthews in the Ferrari F1 book by Peter Wright.Pg. 147.
Posted 14 July 2009 - 22:49
This was obviously about cooling rather than caliper placement... I must admit I am still struggling to understand exactly why the position makes a difference to the function of the disc/caliper set-up. If it is so cut and dried why do the calipers move around from design to design? What about twin, opposing calipers, once used, are these banned now?
Posted 15 July 2009 - 00:25
Posted 15 July 2009 - 01:11
Braking is the creation of heat. Two calipers would be inefficient and heavy. The rotor must cool before the next braking event. The position of them is determined by packaging, cooling and aero and maybe CG location.
However the pad knock-back issue is real, it's just that your options are very limited in practice, so far as calliper placement goes. This knockback is more obvious on a tall spindle double wishbone, or a MacP, than the short spindle as used in F1 and most circuit cars, as the swan neck/strut is actually quite compliant - effectively reducing the camber stiffness of the suspension. That's one reason why the calliper brackets in a production car's spindle are so heavily braced (the other is that the brakes create huge point loads at the mounting bolts, so the fatigue model tells you to put lots of metal in). There may be additional stiffness requirements driven by squeal and shudder.
Posted 15 July 2009 - 05:32
Because the lateral load, which is what causes deflection, is applied at the contact patch (6 o'clock in the terms we are using). Since the wheel is held in place in the center, the 12 o'clock position gets deflected equally, but in the opposite direction.I understand the reason, but less clear to me is the cause...why the rotor distorts at 12 and 6 more than at 9 and 3.
Posted 15 July 2009 - 06:26
I take your point, but the calipers don't need to be as big if you use two - Williams, amongst others, tried it, but that was really an aside. I know that competition car rotors are a 'loose' fit on the disc bell, and I understand what imaginesix is saying, it's just that, packaging aside, surely that is going to be the result wherever the caliper is situated. Is it worse to have the deflection at 10 past 1, or 11 o'clock? I'm obviously missing something. Possibly brain cells.Braking is the creation of heat. Two calipers would be inefficient and heavy. The rotor must cool before the next braking event.
Posted 15 July 2009 - 11:26
it will take a time to react to each of your responses, because of my poor english.
I would just say it seems this subject is pretty complex, and i note some of you are not agree
(for instance, is there (deflection) distortion or not ?)
Perhaps, some of you could give us any reference (book, article,...) from technical or scientific litterature on this subject ?
thanks.
Posted 15 July 2009 - 13:10
F1 brakes have a praticularly hrad time becuse of the 13" wheel size rule. Most sports car can run 18" wheels or so which gives a bigger clamping radius which partially offsets the bigger braking load ( due to both extra weight and lower drag).
BTW people have played around with calipers etc forever so maybe no one right answer. It was Lola ( I think) in group C who used the inside of the rear uprights as the air channel to the caliper with an air scoop stuck on top sticking up to the airflow over the body.
Louts ( of course ) tried to get really clever on the Lotus 79 by using the diff. side plates as the inside of the caliper with inboard rear brakes. I beleive they forgot about a little detail called differential expansion and used a different material for the caliper outers leading to bad brake problems. In it's first season of the 79 that was not important as it had ground effects and nobody else did. Just to prove even more novelty they had previously mounted the front suspension of the Lotus 77 on twin inboard front calipers so the whole suspension/spring/damper/brake assembly could be moved in/out and back/forewards on little tubular sub frames bolted to a narrow foot box.
The idea was to be able to adjust the cars weight distribution and front rear roll couple between races quickly and at low cost.It was all rapidly replced by a conventional rocker + outboard brake set up but this was the time when Colin Chapman made a the quote " all that matters is how long it is,how wide it is and where the weight is" 30 years later one of the F1 technical directors still re discovers that point every season and builds a lemon.
Posted 15 July 2009 - 14:13
http://www.stoptech....knockback.shtml
So, like ray and macoran told us, it seems that "deflection" (in gary anderson's mind) is a "rigid" displacement of the rotor (so, no distortion due to a flexion constraint )
But, "neutral axis" is a mechanical term related to distorting flexion !
perhaps, it is a misuse of langage ?
Posted 15 July 2009 - 14:37
Posted 15 July 2009 - 22:14
Only good for one landing. http://www.airliners...ead.main/192668
If one had a clean sheet in front of you, rather than using a 'spot caliper', surely an aerospace clutch-type design would be worth having a look at. In fact I think one of the F1 teams actually had a serious look at the concept back in the murky past- maybe the nineties before it was made clear that actual new ideas would no longer be tolerated in F1.
Posted 16 July 2009 - 12:30
the 3 o'clock caliper has not the same dimensions as the 9 o'clock one.
Could you tell us a little bit more on this point ?
thanks.
Posted 17 July 2009 - 04:07
Posted 17 July 2009 - 06:02
I think I have read something about that too, but I seem to recall something about heat issues. To cool a clutch type brake between each turn on a racetrack is probably not without its difficulties. Aircraft brakes on the other hand usually have at least a few hours to cool off between use.
Posted 17 July 2009 - 07:59
As little as 30 minutes on some domestic turn-arounds, usually a maximum of 1:30 on international flight. An aeroplane on the ground = lost revenue, so they're kept working as much as possible.
There are some types that have in-built brake fans in the landing gear assembly to help cool the brakes between landing and takeoff.
This is one unit we used to use when I flew 747's ...
It wasn't unusual to arrive in places like Dubai, where the temperature could easily be in the mid 40's and so stinking hot, and at maximum landing weight so the energy absorbed by the 16 brakes was huge. In such cases we'd call for brake cooling as without it there was a distinct chance of the tyres over-temping and we'd get a fuseable plug blow-out. If we didn't need the extra cooling then we'd often still have to wait a good hour or so to get the temps down to the point were we could go.
</thread hijack>
Posted 17 July 2009 - 08:11
Posted 17 July 2009 - 08:36
Ligier tested this type brakes in conjunction with Carbone Industries in 1989.If one had a clean sheet in front of you, rather than using a 'spot caliper', surely an aerospace clutch-type design would be worth having a look at. In fact I think one of the F1 teams actually had a serious look at the concept back in the murky past- maybe the nineties before it was made clear that actual new ideas would no longer be tolerated in F1.
Was interesting, but gave no clear advantage, and cooling was a bit of a problem on the multi-disc pack, not being homogeneous, also slightly heavier than the standard mono-disk
Posted 17 July 2009 - 09:44
Obviously not a 2009 picture Bill 'cause everyone knows that it's slicks this year.
Still on a roll I see, Cheapy!
Right, so we have a situation where, apart from the sheer practicality of mounting the caliper, and taking into account PMI, the effect of clamping the rotor is the same wherever it is positioned untill yopu introduce the significant effect of the load induced by the tyre through the contact patch, and this determines that in fact the ideal position of the caliper is restricted to a small angular range. Have I got that right?
I will accept no comment as 'yes'.
Posted 17 July 2009 - 09:59
No comment.
Posted 17 July 2009 - 10:13
TaNo comment.
Posted 17 July 2009 - 14:13
Lotus 97 front and rear - single calipers! I am possibly the only person to find that interesting... Williams seem the most consistent, the FW07C had twin rears, but later models didn't vary much, at least up to the FW22, which was the last one I saw in detail.
Edited by Tony Matthews, 18 July 2009 - 10:55.
Posted 17 July 2009 - 14:26
Posted 17 July 2009 - 14:46
Anyone else who can't see anything, put your hand up - one, two... hang on, one hand's just gone down again...
Edited by Tony Matthews, 17 July 2009 - 14:49.
Posted 17 July 2009 - 17:33
Posted 17 July 2009 - 18:46
Ay, he's like that, ay.Dammit cheapy stole my joke about those tyres being grooved.
Posted 17 July 2009 - 19:54
Posted 17 July 2009 - 23:51
Posted 18 July 2009 - 01:20
'ey, I'd agree with yar there Mate if I was a Kiwi,'ey!
'ey, not the 'ey's but the thieving part,'ey.
Posted 18 July 2009 - 08:17
ey, contentious, ey!'ey, not the 'ey's but the thieving part,'ey.
Posted 18 July 2009 - 10:26
Posted 18 July 2009 - 10:39
Posted 18 July 2009 - 10:58
#44
Posted 18 July 2009 - 12:36
Perhaps your vertical hold has gone...
Edited by phantom II, 18 July 2009 - 12:37.
#45
Posted 18 July 2009 - 12:56
Loud and clear, 5 * 5. Have you got permission to use this copy written material?
#46
Posted 18 July 2009 - 13:09
No, I'm a rebel! Whatever happened to Duane Eddy...?Loud and clear, 5 * 5. Have you got permission to use this copy written material?
#47
Posted 19 July 2009 - 03:27
Still twanging!
#48
Posted 19 July 2009 - 03:42
The Guy has already admitted elsewhere a few days ago he's not the real Tony Mathews!
#49
Posted 19 July 2009 - 09:07
Well, that may not be the real Duane Eddy... And wot I said was, whoever thought I was the real TM was in for a surprise, I didn't admit anything, Your Honour, I wasn't even there, ask my wife, I was watching the telly all evening...The Guy has already admitted elsewhere a few days ago he's not the real Tony Mathews!
Edited by Tony Matthews, 19 July 2009 - 09:27.
#50
Posted 07 August 2009 - 11:15
Lunch break!
I've bitten the bullit and ventured into the Technical Forum, this being, IIRC, my first post here (haven't posted earlier for fear of publicly displaying my profound ignorance of current racing car technology in general and current F1 technology in particular).
Anyroads, I thought I might contribute a bit to the caliper placement discussion, mostly from a Formula Ford perspective though.
We've tried running calipers either in front of or behind the upright at either end of the car (on Vectors), but found no measurable difference in lap times or 'feel'. There's a sentiment in some circles that forward location of the caliper would tend to pull the wheel downward and aft location would pull it upward the moment the brakes are applied, but we haven't in practise been able to determine the effect, although I would like to repeat the experiment sometime with instrumentation.
IIRC, one of the arguments put forward for using twin calipers in the late seventies and early eighties (apart form the pad area and pad wear issues) was to balance the reaction couple from the calipers, but irrespective of how many calipers you arrange and how, braking will always try to rotate the upright, so the raction at the suspension attachments won't differ. As others have said, practical implications such as steering arms, cooling ducts and centering of mass will probably decide caliper location more than anything.
On our Formula Ford, we've located the caliper horizontally at the bottom of the upright. For us it enabled the most compact installation with the lowest centre of gravity using a non-handed (symmetrical) upright with the rear suspension geometry we've got. Our lower wishbone sits quite high in order to clear our horizontal floor-level spring damper, and as we like to spread the higher loads on the lower suspension link over more members, we've also got our trackrod in the lower plane, making the upright wide at the bottom and narrow at the top - thus the caliper simply fitted well at the bottom. The only drawback to the arrangement is that since we're compelled to using affordable off-the-shelf AP Racing calipers, you have to remove one of the attachment bolts and swing the caliper into a more upright position when bleeding the rear brakes in order to ensure no air is left behind, but we've become fully accustomed to doing so, so it's only a minor snag. And, oh, it looks rather fancy, too...
