Oil
Posted 12 November 2000 - 16:51
How much do you guys think Oil affects the cars performance? Granted there are rules as to the makeup of the oil, but every oil is going to be different. How much difference do you think it would make? There's an oil and lubricant brand being used in a certain junior championship by a certain incredibly successful team that is rumoured to give them an extra few HP (and in a low HP car thats gold baby, gold!)
Posted 12 November 2000 - 16:53
Posted 12 November 2000 - 17:14
Reducing friction leads to less loss of energy to friction. That is the obvious part of having more power make it to the wheels. In addition to that, the engine will run cooler and smaller heat exchangers can be used. That equals lower drag for better airodynamic performance.
Cutting pumping losses equals more power making it to the output shaft. This is why racing engines run dry sumps. The weight of a dry sump system is more, but the power that isn't lost due to windage more than makes up for it. Thinner oil reduces the energy needed to pump it around the engine and to the remote sump. That accomplishes the same thing a dry sump does, although not enough to do away with the dry sump too.
An oil that can stand higher heat without breaking down allows for a higher operating temperature engine. That means smaller radiators for oil and coolant, and the resultant reduction in drag.
These are the goals of a good racing oil. Teams also work with oil suppliers to analize their used oil. By looking at the trace elements of engine materials in used oil, the teams can tell what is wearing and at what rate. This helps with development and with identifying causes of failures.
Posted 12 November 2000 - 17:52
It is important and vital. The difference in oil could, as Todd say, could reduce drag. A good oil reduces temperatures and that is vital too. So oil is vital.
Say No to Traction Control!
Posted 12 November 2000 - 18:13
I mean between teams
Posted 12 November 2000 - 18:56
Sorry about not fully reading your question.
Posted 12 November 2000 - 19:31
Niall
Posted 12 November 2000 - 21:51
In Mclaren for instance the Mobile Tri-Synthetic they use is not much different than the 5W-30W Mobile Tri-Synthetic I use in my Honda Vtec V6. There is also a 0W-30W Mobile Tri-Synthetic available commercially. An F1 engine only has to last for a race and does not need any temperature considerations for very cold temperatures and they can know that the high temp. will be within a certain range. However, the race car does have demand for extremely high flow rates. It's around these considerations that Mobile makes adjustments to the advatage of the race engine.
Best Regards;
Posted 13 November 2000 - 00:51
Ross, I used to hear rumours like this when I was racing karts - "X brand of oil gives you another 500rpm on the straight". I tested all the brands of oil I heard these claims for, and never found one better than Castrol R30/40, which karters have been using for many years. I imagine the rumours are started by the makers or promoters.
Posted 13 November 2000 - 02:23
Duckhams Racing with Van Diemen - 2000 British Formula Ford champs
Manor Motorsport - 2000 Formula Renault Sport and British Formula 3 champions
Im going to ask for a test with some NEO lubricants
Posted 13 November 2000 - 02:35
Am I being too cynical?;)
Posted 13 November 2000 - 02:48
VD was getting their buns burned by Mygales for the past few years, and now they win
Cant wait till im in F1
"he only got there because he had the best oil in juniors!"
Posted 13 November 2000 - 21:59
Best Regards;
