Rear wheel castor?
Posted 03 January 2010 - 23:41
Just wondering if any engineers can give me a few tips as to the importance or not and effects of rear wheel castor.
Is there any effect in handling from the angle of the suspension upright/kingpin on the rear? I know the wheel doesnt steer but there is scrub/toe angle and bump which might make it mean something?
I know all about front castor but I can't really find any info on the rear.
I am about to knockup a new suspension system for my REAR WHEEL drive car (this question is related to RWD only). This will comprise of dual wishbones, lower H and upper A. I am simply wondering what effect racking the wishbone pickups/upright could have.
Or do I simply put the upright and wishbone mounts flat the floor?
Thanks.
Posted 04 January 2010 - 00:15
There is one important effect that I know of. If the suspension has zero longitudinal hub offset then the mech trail point is set by the castor. This will govern whether you get lateral compliance understeer or oversteer. On a multilink this is a compliance effect, as such not easy to calculate by hand. I'd rather have understeer, but again the effect is small.
Randomly picking two cars with some pretence at handling, one has 30 degrees of castor, the other has -30. So I suspect that it is not very important, or more accurately that other things get priority.
Posted 04 January 2010 - 05:50
Ifyou have compliance then as Greg suggests the thinking cap has to come on.
I think some mistake it as a stability item forgetting you already have the length of the wheelbase as your primary caster.
Posted 13 January 2010 - 09:00
Posted 13 January 2010 - 09:10
Posted 14 January 2010 - 23:44
Thanks for the replies, I understand most of the points you make bar this one, car to make the point in easier to digest terms. Thanks.
Posted 15 January 2010 - 02:22
Draw a line between the 2 ball joint holes (upper and lower) and see if the center of the wheel bearing is on that line or to either side of it, that is the hub offset.
If you put that offset forward of the ball joint line the side forces under cornering will make the wheel turn inwards (probably understeer) and vice versa (all other things being equal).
This can also be used as a tool to offset other deflections apparent in a suspension layouts - something that they pay Greg a bowl of rice (and a bucket of chips, Australia after all) to resolve.
Posted 15 January 2010 - 03:22
that defines where the steering axis hits the ground. Then applya torque around the vertical axis, and measure the change in camber and toe. With a bit of maths that gives you the compliant castor angle and kingpin inclination.
So altogether that defines a virtual steer axis.
The same really applies to a double wishbone, since the inboard end compliances do have an effect, and of course if youn have a steering link then you really have a multilink anyway.
Posted 15 January 2010 - 10:20
Posted 15 January 2010 - 14:09
If there is a convergence due to anti squat then I think the castor will change with wheel movement even if the geometry causes no steer at the nominal ride height.
Is that sort of variance with vertical wheel movement ever significant in altering lateral steer. If so I could see it ( maybe) causing "squirming" when cornering on very bumpy surfaces.
Posted 16 January 2010 - 04:06
