How to start an F1 engine
14 replies to this topic
#1 d246
d246
  • 1,094 posts
Posted 19 June 2011 - 18:26
Always wondered what the process of starting an F1 engine involves. Obviously the fine tolerances of the individual components will dictate a different strategy to your normal competition engine. I read somewhere that hot water is pumped round the unit prior to the lap-tops getting involved and starting the motor. Is it as clinical and complex as this?
#2 undersquare
undersquare
  • 18,929 posts
Posted 19 June 2011 - 18:29
I think they heat and circulate the oil too.
#3 Clatter
Clatter
  • 45,774 posts
Posted 19 June 2011 - 19:25
Yes, all fluids are heated and circulated. I'm sure they said during the broadcast of the last race that this takes 4-5 hours.
#4 F.M.
F.M.
  • 5,577 posts
Posted 19 June 2011 - 19:29
No way. If they do an engine change, they won't have to wait 4-5 hours before they can fire it up
#5 Clatter
Clatter
  • 45,774 posts
Posted 19 June 2011 - 20:29
Good point, but I'm sure that's what they said. Maybe that's in ideal conditions or perhaps I mis-heard.
It never fails to amaze me that with so much info on the internet, why is something like this so hard to find?
#6 BullHead
BullHead
  • 7,934 posts
Posted 19 June 2011 - 20:32
Aren't spare engines kept pre warmed anyway?
Also the warming process can be accelerated too if necessary. AFAIK and I might be wrong engines are fitted in a "warm" status anyway.
#7 tad8285
tad8285
  • 6 posts
Posted 19 June 2011 - 20:41
I thought it was just as simple as turning a key.  ;)
#8 zold
zold
  • 308 posts
Posted 19 June 2011 - 21:35
Well firstly you have to consider the average fan doesn't really care about the more complex aspects, such as this subject. then of course there are few news outlets that are specialized enough to want to cover this in-depth, and finally, the simple fact that in a competitive environment, the engine manufacturers will not want to part with certain details for the sake of print and discussion. I think it is very probable that each of the four engines in formula 1 today have noticeably different starting procedures, and if there is time to be gained then a more efficient procedure in the matter will not be shared.
but indeed, i suspect the basic details could be found on somewhere like f1technical.net
#9 klyster
klyster
  • 5,738 posts
Posted 19 June 2011 - 23:38
http://www.f1technic...c...?f=4&t=9362 some interesting reading..
Cosworth DFV:
http://www.historice.../dfv/specs.html a fun read too.
Edited by klyster, 19 June 2011 - 23:41.
#10 iiswills
iiswills
  • 54 posts
Posted 20 June 2011 - 00:24
If your in the uk this is still available although only for another 24 hours
there's a bit in here about starting the engines
http://www.bbc.co.uk...es_3_Formula_1/
#11 Bloggsworth
Bloggsworth
  • 9,498 posts
Posted 20 June 2011 - 16:47
It's the windage that causes the delay, the bigger the gap between the pistons and the bores the more power is lost as air passes the pisons into the crank-case - The pistons are such a tight fit in the bores that it is not possible to start the engine without the engine, particularly the cylinder block, being warmed up sufficiently for there to be enough clearance for the pistons and piston-rings to run in the cylinder bores.
#12 Madras
Madras
  • 3,911 posts
Posted 20 June 2011 - 22:11
They have to take the nose cone off, then use one of these:
#13 Bloggsworth
Bloggsworth
  • 9,498 posts
Posted 20 June 2011 - 22:31
While remembering to keep your thumb on the same side of the handle as the palm...
#14 klyster
klyster
  • 5,738 posts
Posted 05 July 2011 - 10:22
Preheaters being used @ 7:10 onwards, not much info but worth a look, and the rest of the vid is okay too ;)
Thanks to Hattiethecat1 whoever you are.
#15 Tombstone
Tombstone
  • 1,396 posts
Posted 05 July 2011 - 10:40
One should always transport one's manservant for such an ungentlemanly act as starting an automobile.
