Austin Seven-based Grand Prix engine
Posted 12 November 2011 - 22:29
Did anybody ever consider building a Formula 1 engine from two of them either as in V8 or a straight 8 configuration?
Posted 12 November 2011 - 23:02
I've been looking at the possibilities on the 1941-43 formula for some time now and it's my belief there is an untold story there: if I'm correct then the Austin engine probably wasn't an option. And no - that sentence is not contradictory to the first!
I've not seen any suggestion of the Austin block being used as a basis for an engine for the 1947-53 F1 though - it was probably considered a bit long in the tooth by then.
Posted 13 November 2011 - 04:07
The Murray Jamieson designed twin overhead camshaft Austin Seven engine produced probably the highest horsepower per litre of any prewar engine.
Would the MG R have been close enough to equal it or at least modify that statement to "arguably the highest"...?
Posted 13 November 2011 - 06:17
I know that Daimler-Benz stripped down an MG engine when developing the M154 but I don't think I've heard of them doing the same for an Austin.The Murray Jamieson designed twin overhead camshaft Austin Seven engine produced probably the highest horsepower per litre of any prewar engine. I believe that I read somewhere that Mercedes Benz stripped one down to see how Austin did it.
The twin cam Austins were a wonderful achievement but the very high power figures were only available for the shortest sprints. They had 90-100 bhp available for longer races.
I think there's no doubt that Austin had the financial and technical resources to develop a successful Grand Prix engine but they closed down the racing department in 1937. We will never know whether a 1.5-litre racing Austin would have been derived from the 750 or a clean sheet of paper but successful Grand Prix engines need factory involvement. They are not cobbled together by small racing teams.
Edited by Roger Clark, 13 November 2011 - 06:18.
Posted 13 November 2011 - 06:44
On the matter of bhp/litre, I'm sure the 1100cc Appleton Special was right up there (166bhp/litre in 1937) but again it was a sprint car and probably never ran more than a mile at a time
Posted 13 November 2011 - 07:24
Posted 13 November 2011 - 07:25
Since an Austin 7 engine is a very primitive sidevalve with a crank made for a bent paperclip I suggest that they would have started with a clean sheet of paper.I know that Daimler-Benz stripped down an MG engine when developing the M154 but I don't think I've heard of them doing the same for an Austin.
Plenty of people have made a better engine from the A7 engine but really it is little more than the original block. Everything is aftrermarket or from something else, eg Renault conrods. Which were not even manufactured pre war.
Posted 13 November 2011 - 07:56
Lee, have you ever seen the Murray Jamieson designed Austin engine that they are talking about? The only thing it has in common with the Austin Seven is the name. It is a specialised racing engine. It is not the mass produced road car motor. Sort of like comparing a Ford side valve V8 with a DFV.Since an Austin 7 engine is a very primitive sidevalve with a crank made for a bent paperclip I suggest that they would have started with a clean sheet of paper.
Posted 13 November 2011 - 08:43
I thought it was a vee, but I've been wrong before - 1978, I thinkDidn't the Harker have two crankshafts, rather than a vee?
Posted 13 November 2011 - 08:46
That's what he wrote!Didn't the Harker have two crankshafts, rather than a vee?
After the crash Harker moved on to using MG Midget blocks - which I never quite understood as the MG block is not separate from the crankcase as is the A7.Slightly OT, but in 1931 W E Harker mounted two Austin Seven engines in a vee and geared them together. The whole lot was then supercharged, but the 1494cc Harker Special was unable to show its true potential before it crashed very badly at the July Shelsley Walsh hillclimb.
It survives in that form.
However as pointed out above no amount of discussion of Austin Seven engines can change the fact that the Jamieson twincam had nothing in common with the production engine - not even bore and stroke dimensions.
As for horsepower, claims are all over the place. The MG Q and R are normally said to have produced 113 b.h.p. (from 746cc) mainly due to good (Zoller) supercharging rather than the hemispherical combustion chambers but roots blower of the Jamieson Austin which I think made it to 116 b.h.p. in sprint form.
Posted 13 November 2011 - 09:16
Didn't he fit the Austin-based engine in a Lombard chassis first?After the crash Harker moved on to using MG Midget blocks - which I never quite understood as the MG block is not separate from the crankcase as is the A7.
Posted 13 November 2011 - 09:57
Purely semantics. I did say "probably" as there is uncertainty. The piece that sparked this off suggested the Austin was more powerful. (You can't use a statistical argument as there were only three 2 OHC Austins while the R-Type was sold in larger quantities.)Would the MG R have been close enough to equal it or at least modify that statement to "arguably the highest"...?
Thanks for the clarification. As one of the three Austins found its way to Germany I recalled the Daimler-Benz story and put two and two together to make five.I know that Daimler-Benz stripped down an MG engine when developing the M154 but I don't think I've heard of them doing the same for an Austin.
Edited by D-Type, 13 November 2011 - 17:33.
Posted 13 November 2011 - 19:59
Posted 14 November 2011 - 18:04
There were only 3. One was destroyed in July 1936 in Driscoll's crash at Blackwell, and after that whenever Austin entered 3 cars, one of them was the Jamieson Side-Valve, often driven by Kay Petre.
They were lovely little cars. Jamieson's target was 120bhp at 10,000 rpm. I don't think he got there, though, and there has been some discussion about a redesign of the cylinder head, which had very wide-angle valves. It came to nothing, and Jamieson went to ERA and was sadly killed in 1939 anyway. But the cars he left, once they'd been sorted out in 1936, were pretty much unbeatable in their class anyway, and from time to time even made ERAs look out!
Posted 14 November 2011 - 18:27
I have seen suggestions that Mercedes Benz did at least "look it over" - and Bäumer did later secure a seat as an MB reserve driver ;)D-Type, I know that Walter Baumer hillclimbed an OHC car in Germany in 1936 and 37, but I didn't think one went there to stay, so to speak.
In the interests of accuracy, "Blackwell" should of course read "Backwell" and TMJ was killed in 1938, not 1939.There were only 3. One was destroyed in July 1936 in Driscoll's crash at Blackwell, and after that whenever Austin entered 3 cars, one of them was the Jamieson Side-Valve, often driven by Kay Petre.
Difficult to know how much credit to give to Bert Hadley, but the Austin was so dominant at Crystal Palace in 1939 that there were suggestions that class handicapping might have to be abandoned there in favour of individual handicaps. Bert and the Austin were certainly streets ahead of the 750cc MG drivers - and even the 1100cc MGs and Rileys, come to that - and 'Bira' (admittedly driving Romulus rather than the newer Hanuman) decided to withdraw from the August meeting rather than get soundly beaten!
Edited by Vitesse2, 14 November 2011 - 23:08.
Posted 14 November 2011 - 19:09
Immediately postwar Austin would have been focussed on getting production going and in a market where they could sell every car they made there was no need to produce racing specials to publicise the marque. A similar situation existed at MG, particularly once the US market took off.
That leaves the specialist engine makers, Anzani, Meadows, Coventry Climax etc, assuming they could have done a deal with Austin or MG to use their basic design to develop a racing eight. They too would be focussed on postwar reconstruction.
And in addition, the whole of the British motor industry, if they had any interest in racing, were backing BRM in cash or in kind. A development of the Austin or MG designs would be in direct competition with it.
Posted 14 November 2011 - 19:44
Posted 14 November 2011 - 20:25
It might have been a little bit of self aggrandisement - but I doubt it - when all these former works team members were unanimous in declaring that the 750 OHC Racers were absolutely the apple of Lord Austin's eye, and he was both extremely enthusiastic about them, and supremely proud of them.
Edited by Doug Nye, 14 November 2011 - 20:27.
Posted 14 November 2011 - 21:29
And in the later 30's they were entered in events (and financed )by the good Lord himself, rather than by the no-longer-interested company that bore his name.
Posted 14 November 2011 - 23:04
Correct up to a point. Blown cars of as little as 666cc were eligible. However, the sticking point was the bodywork regulations, which specified a minimum width of 85cm at the cockpit, whatever the engine size: I think the Austins are about 60cm. There's an article in the August 1936 Motor Sport which goes into this at considerable length, but is to a certain extent redundant in that it refers to a version of the rules which had to be scrapped. At that point, the minimum was expected to be 750cc, so the Austins' engines would have had to be increased in size by a smidgin.I was expecting one of you clever chaps to have said this because I'm not 100% sure about it but in a way the OHC Ausin 7 engine WAS a GP unit. I'm sure I read somewhere that the 38/39 GP formula which we know as being for 3 litre supercharged; 4.5 normally aspirated actually had a sliding scale of capacities and minimum weights all the way down to 750cc. I'm sure I've seen it mentioned that the "less well informed" press suggested that the Austin may be a competitive GP car because of this?
Posted 14 November 2011 - 23:16
Posted 24 May 2015 - 11:37
Posted 24 May 2015 - 14:46
It was certainly talked about. But whether Tom ever committed it to paper - other than 'back of a fag packet' or maybe a sketch on a sheet of foolscap to show to Lord Austin - seems very unlikely. There are occasional mentions in the press of the time, but I've never seen anything in the way of drawings. And when you consider the interest that there was at the time in rear-engined cars like the Auto Unions, the Miller and the Marmon-Oldfield, even the tiniest nugget of real information would have been seized on by the specialist magazines. Drawings would have merited a double-page article!
Perhaps there's something lurking in a forgotten or overlooked file at Gaydon, but I think that's a very unlikely scenario. Chances are that anything that existed was simply chucked out when TMJ died.
Posted 24 May 2015 - 22:56
On a different point, did anyone ever copy the twin-cam engine apart from for the 1/4 scale model? Thanks!
Posted 25 May 2015 - 00:23
http://en.wikipedia....wiki/Triumph_V8
Posted 25 May 2015 - 06:46
I've nothing to add save for the comment that THIS is the sort of thread which makes TNF so compelling.
Posted 10 June 2015 - 15:45
Does anyone have a copy of 'Four wheel drift' by Nick Carter? I remember reading it as a child, and the F1 car the hero drove powered by an engine based on 2 Austin engines. Or has my memory failed me?
Regards
Glenn
Posted 14 June 2015 - 10:40
Two Jowett flat fours from memory.
Will have to read the book under the sheets with a torch to night!
Eddy Lash was the baddy - Duclos was the goody, Nick was the hero and Bruce was the author.
Great little book gifted on 21/09/59, very special [sat]
Edited by Patrick Fletcher, 14 June 2015 - 11:14.
