Movable Fuel Rail Coupling with Injectors!
Posted 26 April 2013 - 15:21
Thanks!
John
Posted 26 April 2013 - 16:05
Posted 26 April 2013 - 16:23
Posted 26 April 2013 - 17:58
saudoso, on Apr 26 2013, 09:23, said:
Like this:
Yes sir saudoso....after thinking about your drawing, I can easily machine a fuel rail slide assemby block using linear bearings and glass filled dynamic seals with a hollow/hardened SS fuel supply rod.
Thanks again for the idea!
Juanito
Posted 26 April 2013 - 20:20
You are blending throtle with the injectors? Like the injector assembly opens/closes the intake trumpet mouth?
Edited by saudoso, 26 April 2013 - 20:31.
Posted 26 April 2013 - 21:34
saudoso, on Apr 26 2013, 13:20, said:
Yes sir, it's kind of like that but in this case it would not be the primary engine throttle, but a variable device controlled by an air cylinder off of manifold pressure......but I don't see why a foot operated primary throttle such as you describe would not work in a normally aspirated engine.......very interesting!Would be cool if it works. Keep us posted!
Thanks!
John
Posted 26 April 2013 - 22:03
NTSOS, on Apr 27 2013, 07:34, said:
That's elegant, but the obvious way to my mind is a flexible hose and a banjo bolt. Your fuel lines already have an equivalent arrangement to allow the engine to roll.Yes sir, it's kind of like that but in this case it would not be the primary engine throttle, but a variable device controlled by an air cylinder off of manifold pressure......but I don't see why a foot operated primary throttle such as you describe would not work in a normally aspirated engine.......very interesting!
Thanks!
John
Posted 26 April 2013 - 23:08
Edited by saudoso, 26 April 2013 - 23:15.
Posted 27 April 2013 - 00:15
Posted 27 April 2013 - 06:44
Posted 27 April 2013 - 15:44
Yes Greg, that would definitely be the easiest method. Problem is, there is not much space in the plenum area where the fuel rail is located and it would require a very tight loop to allow the fuel line to wind and unwind as the rail repeatedly rises and falls along with the mechanism.......and I was concerned about fatigue failure. I think it would work just fine if it was the length of a flexible brake line on a IFS, but in this application it is very short and tight......I don't know, it's just a gut feel.....what do you think?
Thanks!
John
Posted 27 April 2013 - 15:50
Lee Nicolle, on Apr 26 2013, 17:15, said:
Lost me. Why move the fuel rail? Unless ofcourse it moves with the ram tubes. Most injectors on race engines are near the ram tube mouth these days. Only one I have seen upclose had flexible lines from the rail to injector.
It's an updated variable geometry mechanism that I've used since the '80's Lee, and on the new design, the fuel rail and injectors are kind of along for the ride! If I had access to DI, that would certainly circumvent all the monkeying around with the rail and injectors!
Thanks!
John
Posted 27 April 2013 - 16:19
TC3000, on Apr 26 2013, 17:43, said:
I guess to get good torque and top end power at the same time, depending of the rpm/load condition.
In the past, some people have used a near and a far injector per trumpet and switched from near for low rpm
to far at a higher rpm in some Supertouring car engines the cross over point was at ~5500 rpm (8500 rpm max.).
Saudoso's proposal is neat, if you have the extra vertical space in the plenum/airbox to spare, which depending on
the application, could be a challenge.
dual injector layout:
Yes, saudoso's proposal is neat and there actually is vertical space "outside" of the plenum for the fuel delivery tube to operate. It is a strictly street turbo supercharged application and there is virtually no intake port beyond the cylinder head, so there is little room for injector placement....hence, they are along for the ride with the movement of the variable mechanism......like I said, access to an aftermarket DI system would eliminate the hassle, but that's probably not going to happen for awhile. In any case and as the result of necessity, it would be interesting to note the effect on power production at various injector heights above the inlet port at differing RPM's
Thanks!
John
Posted 27 April 2013 - 16:20
Tony Matthews, on Apr 26 2013, 23:44, said:
The Ilmor 265E/500I had two bosses cast on the inlet manifolds, one low, one high, in case secondary injectors were needed further up the airstream. In the event they weren't needed.
Tony, do you recall if they ever used two injectors per cylinder?
Thanks!
Juanito
Posted 27 April 2013 - 17:33
Posted 27 April 2013 - 18:17
NTSOS, on Apr 27 2013, 17:20, said:
They may have tested with them, John, but they were never used in anger as far as I know, they just remained as unused, unmachined bosses on the castings. Wouldn't be the first occasion of a useless boss!Tony, do you recall if they ever used two injectors per cylinder?
Thanks!
Juanito
Edited to add that there were two injectors per trumpet, firing down from inside the plenum.
Edited by Tony Matthews, 27 April 2013 - 18:19.
Posted 27 April 2013 - 19:25
Tony Matthews, on Apr 27 2013, 11:17, said:
Yes sir, that was exactly the same conclusion that Ricardo had......he gave up trying to figure out where to cast bosses for sensors/probes etc. and simply increased the wall thickness of all castings on the test engines!They may have tested with them, John, but they were never used in anger as far as I know, they just remained as unused, unmachined bosses on the castings. Wouldn't be the first occasion of a useless boss!
Thanks!
Juan
Posted 27 April 2013 - 19:40
Posted 27 April 2013 - 21:45
Magoo, on Apr 28 2013, 05:40, said:
Esprit Turbo had two extra injectors, at the time you couldn't get injectors which gave enough max fuel rate and good idle control. Or perhaps it was cheaper!One reason to have 2x injectors on champ car engine is methanol, which requires big fuel mass delivery. Doubling up allowed inexpensive production-based injector rather than some hideously expensive handmade thing.
Posted 27 April 2013 - 22:09
as for injector size.. with the growing popularity of E85, 1200 to 2000 cc injectors are becoming quite common..
Posted 28 April 2013 - 16:24
NTSOS, on Apr 27 2013, 09:44, said:
I'll see if I can't sketch it out later to explain what I mean. If I'm in the plenum looking towards the rear, injector bank on either side with their respective fuel rails. End of each rail has a straight banjo fitting (meaning it protrudes perpendicular to the rail towards the center of the plenum). The flexible fuel line runs across the centre of the plenum towards the opposite side where it's mating banjo fitting is located - as far as practicable along the rear wall of the plenum, on the opposite side. This gives the maximum distance between fittings to allow for "excess" line.Yes Greg, that would definitely be the easiest method. Problem is, there is not much space in the plenum area where the fuel rail is located and it would require a very tight loop to allow the fuel line to wind and unwind as the rail repeatedly rises and falls along with the mechanism.......and I was concerned about fatigue failure. I think it would work just fine if it was the length of a flexible brake line on a IFS, but in this application it is very short and tight......I don't know, it's just a gut feel.....what do you think?
Thanks!
John
Along the same lines, one could use a 90' fitting at the back of the rail, a bulkhead fitting on the same side and run the loop from the rear of the plenum to the banjo located on the front. Or even loop it back again so the flexible line runs back to front to back again. All kinds of space for loop length.
In terms of fatigue - motorcycle front forks and rear swingarms require flexible brake lines. Forks move in a purely linear fashion constantly with several inches of travel and brake line mechanical fatigue is never a concern despite being exposed to all the debris on the road, the constant flexing and the very high line pressures.
All that said, I'm envisioning motorcycle steel braided brake lines which are considerably smaller than a fuel line would need to be. Should still work scaled up depending on the space constraints.
Posted 28 April 2013 - 17:39
Yes sir, got it.......all great ideas as it relates to flexible fuel line configurations/management within a plenum.......I came to the right place!
Thanks man!
Additionally, a nice little street engine on the dyno....I love to start and stop the video and watch the dials on the last pull!
a street engine!
John
PS.....I wish Tom would say lb/ft!
Posted 28 April 2013 - 23:41
NTSOS, on Apr 28 2013, 13:39, said:
a street engine!
John
Just goes to show that talking the talk isn't everything. Love the stock FEAD, A/C compressor, etc. Just a stock little motor. Less than 2 bar MAP, that's nothing.
Posted 29 April 2013 - 01:06
Magoo, on Apr 28 2013, 16:41, said:
True......and I agree, have always preferred the stock FEAD to the after market billet stuff! The original Electromotive FI unit is what got me started working with computers. I bought an 8086 computer with a floppy drive and it had a turbo button that scared me. It changed the processor speed from 4 MHz to an incredible 8 MHz.......but I didn't push it for over a year because I wasn't sure what it was for!Just goes to show that talking the talk isn't everything. Love the stock FEAD, A/C compressor, etc. Just a stock little motor. Less than 2 bar MAP, that's nothing.
Posted 10 July 2013 - 14:38
Posted 11 July 2013 - 14:53
saudoso, on Jul 10 2013, 07:38, said:
Did this fly?
Yes sir.......combined your fuel supply tube idea, the injector and the air cylinder piston rod that controls the variable geometry into a single rod/multi purpose assembly. The more I think about, the more integrated it becomes so I am in no hurry to build it just yet.
Thanks!
John
Posted 11 July 2013 - 16:19
Posted 12 July 2013 - 04:25
presumably these injectors have a lower bound on the time taken to open/squirt/close, so it could make some sense to have smaller injectors for when you don't need a firehose per cylinder
