1.4 seconds per what? Per lap? Which circuit?
As others have mentioned, without fuel, all the top cars weigh the same as they're all down to the minimum limit. An 18KG lighter engine allows more scope to run heavier drivers, but as Merc have two pretty light drivers it probably means they run more ballast, which might help their weight distribution, but it's hard to quantify how much advantage that gives. As far as I know we're not in a 2009 situation where everyone struggled to put enough weight on the front axle, so the non-KERS teams had a big advantage because they could shift the ballast to the front. This year, I'm not at all convinced it makes much difference, as long as you're able to run on the limit.
I suspect the more relevant figures are the poneys, both the 70bhp extra from the ICE and, although we don't have figures for it, what sounds like an even bigger advantage in ERS power. If I remember rightly, the rate at which you can discharge stored energy is limited by the regulations, so if Mercedes are able to discharge for two consecutive laps and Ferrari and Renault can only discharge for 0.75 laps at a time, that looks to me like a pretty sound thrashing has been administered there.
Personally I think Mercedes has done a much better job and they deserve to win. I think the other teams should be given the opportunity to improve, but not before the end of the agreed freeze. If anything, I think Mercedes are hard done by, because if Mercedes and Renault both bulld a road car and Mercedes' engine is 18KG lighter than Renault's, then all other things being equal the Mercedes car will be 18KG lighter than the Renault, which will give it marginally superior economy and performance. It's only in F1 that if you do the best job in making a lightweight engine, you have to put tungsten ballast in your car to even things up. They should keep the crash tests, and then introduce a minimum weight for the driver and seat (so that lighter drivers have to carry seat ballast to make them all effectively weigh the same as the heaviest driver, which would offer the heavier drivers significantly better protection than they get from the current rules) and then they should free up car weight and have it as a performance differentiator.
Edited by redreni, 14 September 2014 - 16:55.
