Need help for the building of Hayabusa V8 engine
11 replies to this topic
#1 George75
George75
  • 2 posts
Posted 11 November 2015 - 19:16
Hello everybody, my name is George and Im located in Europe.
This thread is adressed to the engine builders....
I need your help for the building of a twin Hayabusa engine....
I have 2 Hayabusa engines avaliable and I would like to match them together ,
in order to build a single V8 Hayabusa engine.
For this thing is required to be designed the commun drive who will mutch the 2 engines together and will make them go on.
This thing has been allready done but nobody gives the plans for this thing,
so, does anybody want to help me out in this concept?
I need the plans because a friend of mine has a small  CNC factory and I can build in his place
the crankcase and crancshaft and anything else in a very convinient price.
In case you can not help me, could you suggest somebody who could do this work for me?
thank you very much,
waiting your replay
#2 Chubby_Deuce
Chubby_Deuce
  • 6,994 posts
Posted 11 November 2015 - 20:24
Hartley were the ones that kind of pioneered the idea, weren't they? I doubt they'd send over all of their CAD files but maybe worth contacting them.
http://www.h1v8.com/...age/1562071.htm
#3 MatsNorway
  • 2,831 posts
Posted 11 November 2015 - 21:38
Ditch the V8, Just run them next to each other if you have the space. It would be really cool to have a look at the work you would put in ofc. to make a V8. before and after machining etc.
Edited by MatsNorway, 11 November 2015 - 21:39.
#4 Lee Nicolle
Posted 11 November 2015 - 21:49
I think a few people have done this style conversion. Really all that is original is the heads, barrells? You need a crank, crankcase, make all the cam timing work etc etc etc.
Either buy one from people that have done it or just focus on a 'normal' engine
#5 mariner
  • 2,401 posts
Posted 12 November 2015 - 17:12
The whole proces was covred in great detail in an old copy of Racecar enginering. Be warned though , it might have ben self build but theuy had access to a casting as well as a CNC capacity
#6 George75
George75
  • 2 posts
Posted 12 November 2015 - 17:38
how can I find this copy of the Racecar Engineering?
what is the Racecar Engineering?
is it a magazine?
#7 Canuck
  • 2,413 posts
Posted 12 November 2015 - 19:32
Magazine, yes. Racecar Engineering
#8 GBarclay
GBarclay
  • 178 posts
Posted 13 November 2015 - 20:25
Already done. Both by garage builders and pro-engine builders
Probably best known would be the ones developed by Radical - at the time referred to as the powertec motors
http://radicalsports...engines#addtab1
https://en.wikipedia...ki/Powertec_RPA
Currently utilizing Hayabusa heads, with custom crankcase and crankshaft.
Hartley, as mentioned by Chubby-Deuce
#9 gruntguru
Posted 16 November 2015 - 00:46
If you want to do this for the challenge - go for it. If you want to save money - buy one ready made.
#10 scolbourne
scolbourne
  • 561 posts
Posted 20 November 2015 - 12:31
How well would the two engines work if used separately but driving a common gearbox ie by chains or gears.
I have seen this done before but I guess it is a compromise.
I have seen  a car powered by three engines (not Hayabusa's) and it won our local hillclimb.
#11 Chubby_Deuce
Chubby_Deuce
  • 6,994 posts
Posted 22 November 2015 - 00:14
It has certainly been done before.
#12 carlt
carlt
  • 4,169 posts
Posted 24 November 2015 - 21:37
http://www.uphillrac...sale-12060.html
