Mercedes-AMG achieves 50% thermal efficiency on 2016 F1 engine
111 replies to this topic
#101 gruntguru
  • 6,733 posts
Posted 19 November 2016 - 01:33
What it doesn't show is the portion of the fuel that leaves the chamber from the channels at the bottom into the main cylinder and granted, a different fuel (hydrogen) directly injected is simulated. With gasoline, there is a much greater momentum of the liquid spray and additional processes of spray wall impingement and evaporation, but the principle holds. What ends up at the moment before ignition is nonetheless very homogeneous at a targeted equivalence ratio.
If F1 engines used a gaseous fuel I would have agreed with your analysis from the start. The volume of fuel injected for the main charge would be many times the volume of the pre-chamber. For liquid fuel the situation is reversed. It is possible that the fuel is heated to the point where a greater-than-usual portion vaporises instantly on injection but the majority will remain liquid in the pre-chamber - wetting the walls etc etc.
Your dual function injector that sprays into the pre and main chambers simultaneously sounds more likely. I think most probably, the teams have convinced the FIA to allow an auxiliary injector providing less than 5% of total fuel. (ie Mahle TJI)
Edited by gruntguru, 21 November 2016 - 23:44.
#102 TDIMeister
TDIMeister
  • 286 posts
Posted 21 November 2016 - 17:49
See highlighted.
Screenshot%202016-11-21%2012_11_36_zpsn8
#103 desmo
  • 19,430 posts
Posted 22 November 2016 - 15:13
The highlighted text is too small to be legible here.
#104 ray b
ray b
  • 2,746 posts
Posted 22 November 2016 - 18:36
if you use Ctrl + your mouse wheel to max the page size
you can read it [almost]on a 24''1080 monitor
yes bigger would be better
now why do I get the nsb before and after the quote [edited out]
next after the nsb edit I get amp ?
Edited by ray b, 22 November 2016 - 18:41.
#105 TDIMeister
TDIMeister
  • 286 posts
Posted 22 November 2016 - 20:55
Sorry guys, the screenshot was taken at 1920x1080 resolution, it got downsampled either through the image hosting site or the forum software. Here's the text of interest:
Mahle is aiming to create a similar effect, albeit
with a very different tech solution. The Mahle
Jet Ignition (MJI) system uses a pre-ignition
chamber, fed by its own fuel injector and
spark plug. Only a small amount of the
overall fuel delivery (less than 5%) is injected
via the MJI system, while the remainder of
the charge is supplied by a conventional DI or
PFI system. Once the spark plug fires, it sends
streams of partially burned mixture outward
from a series of nozzles in the pre-chamber.
These ignite the main charge almost
simultaneously across the whole volume.
This concept made headlines earlier this
year when it emerged that several engine
manufacturers were using a similar idea in
Formula 1 (including Ferrari, whose system
was reportedly engineered by Mahle). Where
these differ from the road-going MJI system,
however, is that they syphon fuel passively
from the main fuel injector into a pre-chamber
through a collection of orifices, instead of
using a dedicated injector unit. ETi has been
told this is largely done for the sake of the
Formula 1 technical regulations, which
prohibit the use of additional injectors.
Sources close to the project suggest that
the technology is showing promise. ETi
understands it allows the engine to operate
stably at very lean equivalence ratios (circa
λ=2), with multiple high-energy ignition
points. These can extend right to the
extremities of the chamber, speeding up
the combustion and specifically targeting
the areas where knock tends to occur. This
allows increased compression ratios – up
to a four-point increase in some applications,
according to the company’s website –
combined with reduced pumping losses.
Almost diesel-like fuel consumption is said
to be possible as a result. Tests have reportedly
shown specific consumption below 200g/kWh,
with considerable reductions in CO2as a
consequence. NOxemissions on the PFI test
engine are also understood to have been cut
by more than 99% in the ultra-lean area,
with HC emissions comparable to standard
SI operation. Particulate emissions are
said to have been somewhat increased
compared with regular PFI, but they
remain significantly less than the
equivalent DI engine.
It’s also understood that
the system has now been
miniaturized to the point
where it can usually be
packaged in a similar manner
to a conventional spark plug.
Casting and machining changes
are still likely to be required, but
the fundamental design of the
cylinder head – at least on PFI
applications – is thought to be unchanged.
Edited by TDIMeister, 22 November 2016 - 20:56.
#106 J. Edlund
Posted 02 December 2016 - 23:19
Point is that it is better than flat top, flat piston. If a chamber shall contain 500cc of mixture you want it to be round to minimise surface area.
We "only" use "flat" top, "flat" piston to get the desired compression ratio. And the only reason they have to be flat top, flat piston is because bore/stroke ratio is more important with this type of engine and application.
A ship engine with more stroke and lower rpm runs more hemi like piston and head. I googled to prove my teories and sure enough:
http://www.marine-kn...ston-Rings1.jpg
http://www.bcmtourin...0009-jpg.59825/
Well i say only but there is also piston speed to consider, weight of the piston and the extra friction that causes, the flame front and all kinds of other variables. Hence modern piston designs.
To say it differently..
If i was only chasing Horsepower with unlimited fuel i would run much bigger bore like the old engines. Excess pressure would simply get dumped out so you could make more "peak" pressure to work with. Hence the rpm, overlap on the cams etc.
There is a sweetspot where bore/stroke ratio + rpm is optimal for a given fuel type and flow. If they open up the rules F1 engineers will find it..
They probably have some idea where that is. So they made the odd fuel flow ramping  and a locked Bore and stroke ratio to keep the show factor in the sport. "We can not simply be seen dieseling around Monaco can we"
Personally i still vote for allowing Straight 5 engines. Some would prob give it a go as it sounds gnarly (ferrari) and it has one less piston so it would be more efficient.
Offset for that engine is packaging.
Increasing efficiency has the added challenge of giving less reusable energy for the turbo KERS. If all the pressure drop happens in the engine the turbo is simply a back pressure generator. That will never happen ofc.
I guess you have never seen a piston like this then, a high compression piston for a hemi head.
http://raybarton.com...6-hemi-dome.jpg
The surface area of such a piston plus the surface area of the head itself is very large compared to a flat head and flat piston with the same bore and compression ratio. The upside is that it allows rather large valves to be fitted.
https://upload.wikim...mi_chambers.jpg
The piston you linked to is a diesel piston, the bowl in the piston forms the combustion chamber combined with a flat head.
#107 Canuck
  • 2,072 posts
Posted 03 December 2016 - 00:54
The dome required on a hemispherical piston to achieve a proper compression ratio makes for a torturous flame path. Dual-plug Harley-Davidson "Shovelhead" engines appeared as a direct result, albeit only in the aftermarket.
#108 MatsNorway
  • 2,730 posts
Posted 03 December 2016 - 11:26
Yes i have.. But im not talking about that old crap. in addition.. thats not a high boost piston is it? Here is some: http://www.enginelab...tock-and-boats/
Anyway what im talking about is more on the teory side. And looking at diesels is a nice way to look at what ifs.. because they run at lower rpms and can afford more complex designs due to the weight being less of a issue.
Due to limits in bore/stroke and the fuel ramping curve  on the current F1 engines the pistons probably look fairly similar to what you would expect from a turbo engine. Biggest difference is probably in the head.
#109 Cynan
Cynan
  • 4 posts
Posted 01 June 2017 - 19:40
Interesting theory about being stratified lean - do you have some inside knowledge to know this is a fact, or is it your speculation? It is certainly plausible, but let's straighten out a few things. Lean mixtures would actually promote knocking by reducing the mixture laminar flame speed and thus leaving increased residence time in the end-gas before being consumed by the flame front, thus causing it to spontaneously combust, leading to knock. I admit that it makes for interesting theory, but I have read nothing about knocking at 15000 RPM. I did schlieren imaging on the mixture formation and combustion process in an optically accessible engine at what I believed from the published literature to be unprecedented at 5000 RPM when most were done at 1200, 1500 and 2400 RPM.
Charge stratification is certainly one way to address the above. When I have more time I'll do some back of napkin calculations to figure out what the air mass flow of a 15000 RPM 2 litre engine with at 3.5 bar MAP and typical volumetric efficiency of an F1 engine is - we could use the last naturally aspirated engine figures as a rough guide. Then we can know much more accurately the global lambdas these engines are running.
I'm extremely hungry for more info like this - whether exotic fuel injection tricks, charge motion and stratification (subjects of my PhD dissertation) or advanced combustion modes. If anyone has articles or papers on the subject, I would be grateful if you would share it and I'll do the same.
latest development is that they use somekind of jet ignition, igniting fuel earlier in a pre-chamber to shoot out high velocity charge into the combustion chamber fo rthe rest to burn
Edited by Cynan, 01 June 2017 - 19:41.
#110 gruntguru
  • 6,733 posts
Posted 01 June 2017 - 23:52
See post #105 above.
#111 Cynan
Cynan
  • 4 posts
Posted 03 June 2017 - 02:37
making it obvious ive only gone through two pages of this thread  :confused:
#112 gruntguru
  • 6,733 posts
Posted 04 June 2017 - 00:45
:lol:  105 is on this page!
