Singapore F1 onboard - A real sense of speed
42 replies to this topic
#1 FirstnameLastname
FirstnameLastname
  • 10,540 posts
Posted 24 September 2018 - 09:04
Watch this if you’ve got a few spare minutes;
https://youtu.be/83mb5Erd8ZY
That shows better than any of the usual camera angles we see, the true pace of these cars. Insane.
#2 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 09:08
I see this as a fake sense of speed because of the image distortion that this tipe of camera creates. This is not what you see IRL
#3 as65p
as65p
  • 26,207 posts
Posted 24 September 2018 - 09:15
Just what I was about write....  :up: :D
Plus, they should really try and find a half realistic way with video stabilizing, i.e. not overdo it. Or am I supposed to believe Singapore is as smooth as a billard table?
#4 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 09:17
You get all that with the normal onboard camera
#5 as65p
as65p
  • 26,207 posts
Posted 24 September 2018 - 09:22
Sure, but from an obviously too high angle. The OP video is closer to the drivers eye, just that IMO the smoothness and camera distortion ruins it again.
#6 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 09:27
I think the sense of speed is most probably very accurate and the video is a compromise between distortion and the sense of speed.  In reality peripheral vision which the driver perceives enhances the sense of speed, unfortunately the standard lens robs us of that perception.
#7 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 09:29
I think the smoothness is generally fine.  From the drivers POV, the eye and brain tend to filter out most of the bumps.
#8 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 10:04
I can't agree with that. The video looks like the car is going 1000 km/h
#9 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 10:08
That's how peripheral vision works when you're travelling at 170+ mph with barriers just a few feet either side of you. :)
#10 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 10:16
Most of the time the car didnt even come close to that 170mph.
#11 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 10:45
It also depends on how you view the video.  If you watch on a small screen (phone or tablet) the representation can be quite skewed.  If however you use a large screen, large enough that the edges of the video fall close to or into your peripheral vision, then it works far better.
Edited by OO7, 24 September 2018 - 15:19.
#12 absinthedude
absinthedude
  • 6,228 posts
Posted 24 September 2018 - 14:17
The barrel distortion of the camera lens is horrendous, just look at the shape of the tyre. Everything on the periphery is grossly distorted making the track walls and perimeter lights seem to flash past faster than they really do. And they should not be using image stabilisation at all.
I agree that watching on a large screen would negate this to some extent.
Some of the best videos for getting that sense of the speed were in the late 80s and early 90s with a camera simply placed aside the airbox, no image stabilisation, no fancy "360" camera...just bolt the thing on and turn it on. Before the halo and the head rest you could see the driver at work, his head bobbing around, all the effects of the bumps...it almost felt painful to watch. Not that I am against the increased driver protection but you got a real impression of the speed.
#13 Nemo1965
Nemo1965
  • 8,759 posts
Posted 24 September 2018 - 14:33
That... I doubt. Research has shown, for example, that tennisplayers who JOG to a position where they want to hit the ball (meaning: reaching a topspeed of 15 km/per hour) their eyesight is impaired by fifty percent. In the words of tenniscoach Vic Braden: 'Any tennisplayer that hits a ball where he has to move for, is legally blind.'
I don't know how heavy the bouncing of modern F1-cars is, over how great a distance, and at what speed. But I doubt that if you would reproduce these movements in a chair of an optomologist, the scores would not be pretty...
#14 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 15:15
In what way is their eyesight impaired though?  Loss of peripheral vision counts as a reduction of eyesight, however would be less relevant when a players eyes are focused on a ball.  In any event check out vestibulo-ocular reflex.
#15 P123
P123
  • 25,538 posts
Posted 24 September 2018 - 15:19
If you were sat in the car looking out to the side I'm sure that's what everything would look like as you passed by... plus the lights above enhance the effect.
#16 secessionman
secessionman
  • 347 posts
Posted 24 September 2018 - 15:48
My thoughts turned to this.
#17 AustinF1
AustinF1
  • 22,422 posts
Posted 24 September 2018 - 15:53
I like it except for the way they turn the camera on corner entry. That distorts the image and actually takes away from the sense of spend and direction change imho. It takes away much of the sense of direction change and makes the track seem straighter than it is. It does show speed well though.
#18 tmekt
tmekt
  • 1,254 posts
Posted 24 September 2018 - 16:08
Probably more true than the fake sense of slowness a normal onboard creates. It won't be like that in real life.
OP's video while obviously distorted is more what the laymen who have tried an F1 car say it's like. The corners jump before you and your thought can't quite keep up. The video certainly creates that impression. Obviously you can't simulate the experience 100 per cent on video but I'm sure that captures the sense of speed better than onboard or shoulder cam. Those lack, for example, the mentioned peripheral vision effect that you'd have in real life.
#19 Nigol
Nigol
  • 2,781 posts
Posted 24 September 2018 - 16:09
Disagree. Especially the sense of speed is completely ruined in this video. You can't judge distances there because the FOV (field of view) is way to high. Curves are becoming 'less tight' but 'faster'. It's actually the SAME for the "normal" onboard view form above the halo, just that it not that severe. But it is STILL to high.
If you want a realistic view, the onboard shots which shows half the helmet from behind are the best. Closest to reality.
Edited by Nigol, 24 September 2018 - 16:09.
#20 Nigol
Nigol
  • 2,781 posts
Posted 24 September 2018 - 16:19
You would need to be incredible close to a very large screen to make it work though...Plus It'd need to be curved.
Edit: Thinking of it, just look at a real F1 simulator, like here:
0:11 if you want a view close to reality.
0:32 to give you a very bad view in terms of realism (because the camera man tried to catch the whole screen and is too far away from the screen)
#21 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 16:34
I've driven a fast car in a real race track... you and the OP's camera view make it sound like you go 1000 km/h, not the case at all.
#22 tmekt
tmekt
  • 1,254 posts
Posted 24 September 2018 - 16:41
You have driven an F1 car in Singapore or some other street circuit?
#23 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 16:45
No, and it doesnt matter, its the same for any track, you never see this blurry effects or very distorted thing
Edit: what is missing in the video is the stuff you experience IRL that cannot be experienced in a video... G-forces, bumps, air wind, noise from the car and the tires... stuff like that
Edited by NixxxoN, 24 September 2018 - 16:49.
#24 prty
prty
  • 8,853 posts
Posted 24 September 2018 - 16:51
If you have a high field of view you'll have a higher sensation of straightline speed but you lose completely the lateral speed sensitivity. The impressive thing about F1 is how the cars turn.
#25 AustinF1
AustinF1
  • 22,422 posts
Posted 24 September 2018 - 16:58
Yeah I've driven fast cars at COTA a few times. It doesn't even really seem like you're going all that fast until you hit about 130-140, at least in my experience. More than once I've been cruising 100 mph down the freeway and didn't even realize it. :blush:
The car speeds up, but when you're driving fast so does your brain. Or at least you better hope it does.
And re: the other sensations you mentioned, that has a lot to do with it. I feel like I'm going faster in a kart going 60 than in a car going 100.
Edited by AustinF1, 24 September 2018 - 17:02.
#26 AustinF1
AustinF1
  • 22,422 posts
Posted 24 September 2018 - 16:59
Yeah that's removed to a great degree in the clip imho by the way they turn the camera on or before turn-in.
#27 tmekt
tmekt
  • 1,254 posts
Posted 24 September 2018 - 17:08
No one said the blurry effect is what you see. :drunk: Of course that's not how it "looks". That was the whole point. It's not simulating the look of the thing, only the sense by distorting the periphery and putting you lower than normal onboard.
Edited by tmekt, 24 September 2018 - 17:10.
#28 statman
statman
  • 7,312 posts
Posted 24 September 2018 - 17:14
the current t-cam on top gives me a sort of fake sense of speed, as if it's zoomed in or so
I really liked the old t-cam, which gave (in my opinion) a better sense of speed. Check any classic onboard @ youtube:
#29 NixxxoN
NixxxoN
  • 4,149 posts
Posted 24 September 2018 - 17:32
More like the opposite, the old T-Cam had an unrealistic wide FOV that made the cars seem to go faster than the current ones, and also the image quality was worse
#30 prty
prty
  • 8,853 posts
Posted 24 September 2018 - 19:55
Cameras with lower FOV and high framerate is where you can better tell what the car is doing and how the track really looks like:
Compare the elevation change in the first corner in the COTA onboard with this one:
Edited by prty, 24 September 2018 - 19:58.
#31 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 20:07
I'd add the following to your selection prty:
#32 ANF
ANF
  • 33,101 posts
Posted 24 September 2018 - 20:21
I'd like to add this as well:
#33 OO7
OO7
  • 23,612 posts
Posted 24 September 2018 - 20:24
The Indycar visor cams are very good.  I really like the fact that the look-into-turn aspect is quite subtle, but I don't know if that's down to the driver or some form of system compensation.  I'd make just a few slight changes such having it angled downwards a little more, so more of the steering wheel is seen and increase the FOV.
Edited by OO7, 24 September 2018 - 20:26.
#34 AustinF1
AustinF1
  • 22,422 posts
Posted 25 September 2018 - 03:47
Wow, that first one really highlights COTA's bumpiness, and viewing the two of them back to back really shows how much changed in just 5 years.
#35 jonpollak
  • 48,167 posts
Posted 25 September 2018 - 05:38
oooh oooh I was looking for that today... !!!
Bless you.
PS..
I think it's a great video.
#36 jonpollak
  • 48,167 posts
Posted 25 September 2018 - 05:46
Here's a good onboard.
#37 f1paul
f1paul
  • 8,276 posts
Posted 25 September 2018 - 17:20
This is speed...
#38 Kalmake
Kalmake
  • 4,492 posts
Posted 25 September 2018 - 19:13
This is speed...
But 30 fps. Very sad.
Edited by Kalmake, 25 September 2018 - 19:13.
#39 Juan Kerr
Juan Kerr
  • 3,151 posts
Posted 25 September 2018 - 20:56
I'm loving the traction control in the corners  :up:
#40 potmotr
potmotr
  • 12,995 posts
Posted 26 September 2018 - 13:32
I liked it.
Whatever happened to helmet cameras in F1?
#41 rockdude101
rockdude101
  • 578 posts
Posted 26 September 2018 - 21:14
This is what I like. A camera that gives you that lower view so you don't see the HALO!!!
Amen. Another reason why I love IndyCar. Visorcam is the business. You can see them fighting to hold onto the car over the bumps at Toronto, it's crazy.
I 100% LOVE this Camera view. It gives you a sense of speed and action, really cool. Need more of this F1 for promotion and marketing PRONTO. It's better than anything else they've created in the last year, at least.
Edited by rockdude101, 26 September 2018 - 21:14.
#42 OO7
OO7
  • 23,612 posts
Posted 27 September 2018 - 00:09
i'll throw the following into the ring:
#43 genespleen
genespleen
  • 411 posts
Posted 27 September 2018 - 00:54
Sense of speed, car-control, etc.
https://www.youtube....h?v=1ZY0ecWFx6A
