https://www.motorspo...screen/4395079/
Seems rather ironic that a company owned by an F1 team is developing something far superior (in my opinion) to the halo for a different racing series.
Posted 24 May 2019 - 14:23
Posted 24 May 2019 - 14:31
Looking at those pictures... Isn't it just a plexiglass-covered Halo?
Posted 24 May 2019 - 14:33
Should have titled it "Red Bull to IndyCar" for clickbait
Interesting, because word first was that a "halo" type device would not work on ovals for visibility issues, yet here it is...? Would like to see this in the road course config car, which would look a bit more balanced, methinks. Doesn't look bad at all, though.
Edited by maximilian, 24 May 2019 - 14:33.
Posted 24 May 2019 - 14:34
Posted 24 May 2019 - 14:36
Seems like "the halo" as F1 implemented didn't work for ovals, but a tweaked version did, in the simulator, and they went forward from there. Seems like a much better solution, aesthetically and safety-wise.
Posted 24 May 2019 - 14:37
Yes.
Posted 24 May 2019 - 14:38
This is what I always thought F1 should've done, combine a Halo with a screen. Not only isn't it nowhere near as offensive looking as the Halo it also offers more protection.
What I don't really understand though is that Indycar said it couldn't use a Halo because of the banking on ovals and the Halo blocking the view, you would still have that problem with this new solution.
Posted 24 May 2019 - 14:46
The comments from the drivers are they when they tested this version in the simulator, they could see. So, the previous concern was not longer valid with this solution.
Marshall Pruett has an article with a lot more detail:
https://racer.com/20...ars-aeroscreen/
Edited by juicy sushi, 24 May 2019 - 14:48.
Posted 24 May 2019 - 14:53
He basically confirms that it is the fugly HALO with an oversized windshield around it. In my opinion it looks much worse than F1s HALO.
It's a halo with a windshield. That's ugly, but it is the perfect solution.
Posted 24 May 2019 - 14:55
Edited by ANF, 24 May 2019 - 14:56.
Posted 24 May 2019 - 14:59
For what?It's a halo with a windshield. That's ugly, but it is the perfect solution.
Posted 24 May 2019 - 15:00
And I feel the opposite.
Posted 24 May 2019 - 15:01
For what?
Debris coming at the driver. The halo on its own can't prevent smaller debris from striker a driver. The windscreen does a much better job of that.
Posted 24 May 2019 - 15:06
Wait...
“One of the options was to, and this was Dallara’s suggestion, just to go to the regular FIA Halo,” Belli continued. “So we tested the Halo for visuals on the Dallara simulator, because there was concern that on the high banked speedways, the Halo would obscure the vision. So we ran with Scott Dixon and on the Dallara simulator with a standard FIA Halo, and to our surprise, it didn’t obscure any visions in any way. But when we came to do the stress test on the tub, this current tub couldn’t sustain the loads of the FIA Halo in the back corner of the cockpit opening, which made us revisit some of our other thoughts.”Affixed to every custom F1 chassis atop the cockpit’s sidewalls, the Halo proved unsuitable for mounting in the same manner on the DW12, which was never designed to accept crushing vertical loads in those locations.
That says that Dixon could see perfectly with the FIA Halo. The only issue they had was that they couldn't fit it to the current chassis which isn't what they were saying at the time. They said that Halo had visibility issues.
There is literally no difference between this and the FIA Halo except for mounting points and wrapping it in perspex.
Posted 24 May 2019 - 15:26
Wait...
Not a lot of difference, no. At the time, they said there was a visibility issue, and then explored their own windscreen solution. That didn't work out as they'd wished, so they came back to this. They did say at the time that there were visibility issues. It would be interesting to hear how that changed, or why.
Still, this is where things are now.
Posted 24 May 2019 - 15:34
Looks much better than the Halo. Hopefully it is as strong.
Designed to withstand a blow of 150 kilonewtons – nearly 34,000 pounds – Belli and RBAT will pivot from the Indy 500 press conference and begin work on testing Aeroscreen 2.0 in the lab and on the racetrack in the coming months.
“We’ve been really pleased,” [Belli] said. “All the calculations done by Dallara and Red Bull show that the tub with this type of mounting can take the 150 kilonewtons, and we’ve just gone from there.”
“We have to obviously decide who’s going to manufacture the windscreen, and we have to start deciding who’s going to manufacture the top frame and the bottom frame. Then we have to take the prototype frames and put them into a fixture and do the load test on the first frames that we make. We’re going to make three to five frames to start.”
Posted 24 May 2019 - 15:35
For what?
The United States' lack of high profile cabriolet racing series.
Posted 24 May 2019 - 15:41
"Indycar will do it much better."
"Indycar takes more time to get it right."
It's still just an awful Halo, to which some enthusiast pasted a bunch of plexiglass left over from his kitchen garden DIY greenhouse.
Just race LMP1 cars.
Posted 24 May 2019 - 15:48
..and open wheeled racing takes another step backwards.
Posted 24 May 2019 - 16:05
I prefer the halo. I actually think it is a good solution. Keep the drivers outside but with a crash structure.
Well, I actually prefer the cars from the early 90:es where you could see the driver properly but for so many reasons that is not really something to dream about having.
Posted 24 May 2019 - 16:12
I liked the previous aeroscreen which was tested by Dixon last year. This is just even worse than F1's halo, for me it is completely changing the nature of the racing, I might as well watch NASCAR or LMP1 if I wanted enclosed racing. I've left F1 and I'll leave indycar as well in the next year. I am sure I take more risks as an amateur go-KART racer, skier or just driving to work than F1 racers of today.
Posted 24 May 2019 - 16:14
It looks futuristic.
Edited by Vielleicht, 24 May 2019 - 16:14.
Posted 24 May 2019 - 16:21
I remember being called a troll for this halo vs oval argument
Posted 24 May 2019 - 16:24
This looks better integrated than the halo to me. I'm intrigued to see how it will look in practice.
Posted 24 May 2019 - 16:28
What happens if the car is upside down? Can the driver extricate himself or is he stuck inside an upturned fishbowl?
Posted 24 May 2019 - 16:34
Posted 24 May 2019 - 16:39
Can a driver extricate themself now?
What I am surprised about is how good it does look considering it's a retrofit to a near 10-year old chassis.
Imagine how it could look when a new chassis is designed around the concept.
Posted 24 May 2019 - 16:42
Reminds me of a Vanwall...
Posted 24 May 2019 - 16:46
Hasn't every opinion on the Halo/Aeroscreen been expressed already?
Enough with the hand wringing, we knew this was coming, just deal with it. It'll be fine.
Posted 24 May 2019 - 17:00
I've actually been working on a design (purely graphical) that's almost identical to the Indycar solution, but for F1. The HALO represents what is the bare minimum in terms of the design (3 pillars) for structural load requirements and adding a screen to it was a no-brainer. This combination will certainly improve driver head protection. The other option is to stick with the current HALO design (no screen), but have the central support angled further and thicker (front to back), this redesign would be for aesthetics.
Posted 24 May 2019 - 17:09
Current LMP1 cars look ugly though! Give me something from the Group C era, such as the Sauber Mercedes C11.
Posted 24 May 2019 - 17:22
In the 80s, were there folks saying 'these Group C cars are ugly, give me something from the 50s - they were much nicer'?
Edited by Ben1445, 24 May 2019 - 17:22.
Posted 24 May 2019 - 17:24
I'm sure there were.
Posted 24 May 2019 - 17:25
I'm lost for words at the number of people that think it looks better than the already ghastly halo. I mean, realllllly?
If you put turd sprinkles on a turd it's still a turd.
Edited by danmills, 24 May 2019 - 17:26.
Posted 24 May 2019 - 17:26
Yeah. Looks like a fighter-jet.
The halo looks like a flip flop.
Posted 24 May 2019 - 17:30
I believe the term is 'hanging like a cow'
Posted 24 May 2019 - 17:38
I think there are still peole who say this...
Posted 24 May 2019 - 17:46
blargh. please, no.
Posted 24 May 2019 - 17:56
Wait...
Yeah, they lied. Visibility excuse never made sense to anyone who can understand basic geometry. They just don't like how the halo looks.
Posted 24 May 2019 - 18:24
Posted 24 May 2019 - 18:27
Edited by thegamer23, 24 May 2019 - 18:27.
Posted 24 May 2019 - 18:39
Posted 24 May 2019 - 19:07
Nah, these are awesome cars. There's a few quirks about them, like the silly fin - but on the whole they're great.
Other cars are and were also great, some mostly in their time, a few are all-time classics.
Posted 24 May 2019 - 19:12
