Despite all track and gravel Zhou Alfa Romeo still got much energy and only the flipping and jump really took a lot energy of it. What if cars had a deployable parachute to slow them down? This could only be activated outside track.
Deployable parachute to slow down an out control car?
Posted 04 July 2022 - 14:46
Posted 04 July 2022 - 14:49
A parachute that will work in all 360 degrees and on the wheels, on the side and upside down?
Posted 04 July 2022 - 14:51
Where would you mount such a device? It's very ahrd to predict the direction in which someobdy will lose control.
Posted 04 July 2022 - 14:52
Posted 04 July 2022 - 14:54
Only deployable outside the track. The idea is that it will not be far from car.
Edited by AlexS, 04 July 2022 - 14:55.
Posted 04 July 2022 - 14:55
Let’s stick with the big energy absorbing barriers that work really well as long as something doesn’t launch the car in the air.
Posted 04 July 2022 - 14:57
Oops sorry wrong button. I don't think you can implement such a device in a safe and workable way.
Posted 04 July 2022 - 15:01
Have you ever felt the wind at Silverstone? I'm sure the marshals would thank you for having to deal with a flapping parachute threatening to blow across the track or trip them up.
Posted 04 July 2022 - 15:42
Iirc, the Mercedes SLS AMG had explosive material in the door hinges that would be detonated in the event of a crash to make sure the gull wing doors could be removed in the event of a rollover accident so the driver could get out.Not to mention the added danger of the pyrotechnics needed to deploy such a questionable device.
Also, many cars have explosives in the seatbelt pretensioner and the airbags that go off during collision. Explosives deploying in an accident strangely isnt the difficult part here.
To me the hard part is not knowing how the car will crash as parachutes only work in certain ways and a lot of risk that the chute just gets entangled with the car itself since you cannot predict crash trajectories. Then we start talking about multiple parachutes deploying in different directions to try and compensate for the unpredictability and it quickly gets out of hand.
Edited by ARTGP, 04 July 2022 - 16:03.
Posted 04 July 2022 - 15:50
Posted 04 July 2022 - 16:02
Posted 04 July 2022 - 16:06
Posted 04 July 2022 - 16:07
The NHRA has entered the chat
Yes, that's the unworkable part.
Posted 04 July 2022 - 16:10
I was about to add its not a dragster, but NHRA is close enough By the way parachutes on dragsters are deployed by air canisters not pyrotechnics.
Posted 04 July 2022 - 16:14
Like i said the parachute will be near the car.
Posted 04 July 2022 - 16:17
It's the 4th July, not the1st April.
Posted 04 July 2022 - 17:31
Maybe it is a good idea - just make the parachute automatically deployed if a car leaves the 'black bit' - would make perfect solution to the track limits problem.
Posted 04 July 2022 - 17:38
I'm thinking it should be something more like a missile defense system - when a car is launched into a protected airspace, cannons should fire big guided pillows towards it.
Ejector seats for each grandstand seat if a car flies towards them.
Posted 04 July 2022 - 17:39
Re: airbags, didn’t they explore this years ago but found that they didn’t deploy fast enough for F1?
Posted 04 July 2022 - 17:56
Not a fans of this idea ... but keep thinking outside the box, Alex.
Posted 04 July 2022 - 17:58
you are on a roll todayI want to see full car airbags instead. Car goes off the track and *poof* it becomes a giant bouncy ball that the crowd can punt back to the pits.
Posted 04 July 2022 - 18:54
Why not just ban all motor sports !
Posted 04 July 2022 - 19:06
Don't be crazy, lets just ban parachuting and were done with this.
Posted 04 July 2022 - 19:42
All drivers should be so fat thayt they would become their one airbag. This is my suggestion.
Posted 04 July 2022 - 19:45
Just have them race simulators. Then everyone is safe.
Posted 05 July 2022 - 05:39
Posted 05 July 2022 - 05:56
This thread has potential.
Posted 05 July 2022 - 06:35
Edited by GiorgioF1, 05 July 2022 - 06:36.
Posted 05 July 2022 - 06:59
Ok, aircraft carriers have elastic barriers that stop >20t aircraft in a short space. F1 cars weight 800kg or so.
So we can put elastic barriers at end of straights were cars get on higher speed.
Posted 05 July 2022 - 07:05
We have those. They’re usually made of old tyres, or a more modern one called Tecpro.
Posted 05 July 2022 - 07:32
Posted 05 July 2022 - 07:37
A large amount of kitty litter from the edge of the track to the fence, instead of a mile of asphalt first, would have slowed it down properly.
Posted 05 July 2022 - 08:25
Pretty sure that steel cable is not as elastic as you describe it to be.
Posted 05 July 2022 - 08:35
Yep. A combination of no roll hoop and the asphalt meant hardly any speed was scrubbed. If the roll hoop had remained intact and the gravel was there, we would have had some spectacular barrel rolls (like Wurz in 98) but much of the energy would have gone by the time he reached the wall.
Posted 06 July 2022 - 00:55
Not gonna work. If anything, this is a more dangerous proposal.
Posted 06 July 2022 - 01:26
Posted 06 July 2022 - 03:00
imagine the parachute accidently opens up on a straight suddenly slowing the car down and blocking the view of drivers behind
Edited by William Hunt, 06 July 2022 - 03:00.
Posted 06 July 2022 - 03:24
Posted 06 July 2022 - 05:29
How about a huge boat anchor on a rope released from the car in case of an emergency ?
Posted 06 July 2022 - 06:07
That’s not the point. It would still be an added safety concern which would need addressing. Even with the alternative suggested below.
Both options would be adding an unnecessary complication for a completely silly idea. Perhaps I didn’t need to mention these things at all because the idea is terrible on multiple fronts.
How near is near? It has to be big enough to have a worthwhile effect on slowing the car, which means having long lines to match. That also means it would take time to fill and at that point the car would probably be in the wall anyway.
Sorry. I guess you’ll have to put this idea in the bin.
