F1 Historical Power to Weight Ratio
33 replies to this topic
#1 EvilPhil II
EvilPhil II
  • 2,030 posts
Posted 23 December 2022 - 01:11
Was thinking about how although bhp may have gone up since 2014 that the power to weight ratio has likely gone far downwards.
Who has the figures from 1985ish to present day?
1988 McLaren Honda 650bhp and 540 kg (1,196 lb)
#2 Jackmancer
Jackmancer
  • 3,277 posts
Posted 23 December 2022 - 02:57
not sure if BHP is the only metric you want to use or also torque
#3 Collombin
Collombin
  • 9,677 posts
Posted 23 December 2022 - 08:03
I would strongly recommend sticking with bhp and ignoring torque numbers altogether, which can be extremely misleading and only tell part of the story.
Re weights, at what point did they start to include the driver?
The bhp of the BMW turbo of 1984 can be found by the formula 1000 x 1.05^y where y is how many years it's been since 1984.
#4 Peugeot905evo1bis
Peugeot905evo1bis
  • 237 posts
Posted 23 December 2022 - 08:13
Are you sure about that ? I thought it was more than that, especially in qualifications.
#5 danmills
danmills
  • 3,686 posts
Posted 23 December 2022 - 09:06
Are you thinking of the BMW turbo engines that lasted one Q lap, the ones the engineers would leave them outside and pee on the blocks to strengthen them or something?
Allegedly a myth but I'm sure a beyond the grid interviewee confirmed it once.
Edited by danmills, 23 December 2022 - 09:08.
#6 GlenWatkins
GlenWatkins
  • 2,538 posts
Posted 23 December 2022 - 09:15
As an engineer, I think exactly the opposite.  I think of torque as the rotational equivalent of linear force.  With regard to motorsport, when I see HP being used to compare engines its frustrating because HP is meaningless to me unless I know what rpm the HP is calculated from
Edited by GlenWatkins, 23 December 2022 - 09:15.
#7 midgrid
midgrid
  • 10,941 posts
Posted 23 December 2022 - 09:22
RaceFans put together some data on historic McLarens back in early 2014, before the introduction of the hybrid power units.
#8 Collombin
Collombin
  • 9,677 posts
Posted 23 December 2022 - 09:33
In the 2.4 litre NA era, my very ordinary road car had higher peak engine torque than any F1 car of the day. As you say, you need to know about rpms too, and since hp = torque x revs and gearboxes effectively exchange torque for revs and vice versa, then bhp is the more significant number.
#9 Collombin
Collombin
  • 9,677 posts
Posted 23 December 2022 - 10:31
Ludvigsen's Classic Racing Engines covers the TAG-P01, saying it had 650 bhp in the 1984 McLaren but by 1987 its typical power in racing trim was 820 bhp, topping 900 in qualifying trim. Peak hp was at 12,000 rpm.
#10 OO7
OO7
  • 23,612 posts
Posted 23 December 2022 - 10:46
That car apparently also ran with 70kg(?) of ballast.
#11 Boing Ball
Boing Ball
  • 428 posts
Posted 23 December 2022 - 14:07
Steve Nichols has said in recent interviews that the MP4/4 had about 600-615 hp in race trim (because of the fuel tank limitation).
#12 cbo
cbo
  • 967 posts
Posted 23 December 2022 - 14:30
So the lard-assed F1 cars of 2022 should have about 1.250 bhp to reach the power-to-weight ratio of 2005 F1 cars....?
Table in: https://www.racefans...s-1966-present/
#13 chdphd
chdphd
  • 3,342 posts
Posted 23 December 2022 - 14:41
For those who prefer graphs to tables
Edited by chdphd, 23 December 2022 - 14:42.
#14 EvilPhil II
EvilPhil II
  • 2,030 posts
Posted 23 December 2022 - 16:33
Ah! You guys are amazing...
That 2005 figure and the last of the v10s and how quick they look is what originally got me thinking about this.
#15 as65p
as65p
  • 26,207 posts
Posted 23 December 2022 - 17:16
No, it's about in the ballpark. The boost limit of 2.5 bar was applied in both qualifiyng and races for 1988. All Honda could do was run the engine richer in qualifying, and stress it more. The numbers I know of were 456KW (620 PS) in race trim and 504KW (685 PS) in qualifying.
#16 PayasYouRace
  • 53,649 posts
Posted 23 December 2022 - 18:40
If anyone is doing comparisons, remember that for before 1995, you must add the weight of the driver.
#17 Otaku
Otaku
  • 1,833 posts
Posted 24 December 2022 - 15:00
This is useful to stop speculating about power figures of Honda 86-88 engines
https://vdocuments.m...ine.html?page=1
#18 JeePee
JeePee
  • 6,046 posts
Posted 24 December 2022 - 16:44
As an automotive engineer, torque says very little when talking about the speed of a car. Horsepower is everything. As Collombin said, a car with very few torque but an extreme number of revs can pump out lots of horsepower and thus performance. Think of older F1 engines, but also 2-stroke karting engines that rev over 15k rpm. Engines with very high torque but a low number of revs can maybe pull a lot of weight, but aren't quick. See freight trucks.
#19 Otaku
Otaku
  • 1,833 posts
Posted 24 December 2022 - 18:29
Gearing exists for a reason.
#20 Lennat
Lennat
  • 2,202 posts
Posted 24 December 2022 - 22:01
As someone mentioned, the old NA F1 engines had basically no torque at all, and it didn't really seem to matter that much.
#21 as65p
as65p
  • 26,207 posts
Posted 24 December 2022 - 23:44
It's true in a absolute sense that the classic F1 engines has little torque, as HP was always the primary goal. Within those constrains however, I remember many discussions how useful it was to have a little bit broader operating rev band (related to torque) than your competitors engine, while peak HP might have been similar.
#22 cbo
cbo
  • 967 posts
Posted 25 December 2022 - 13:53
I wonder if that matters at all today as drivers probably have instant, massive torque available from the electric motor at any rpm?
#23 Dan333SP
Dan333SP
  • 5,213 posts
Posted 26 December 2022 - 21:07
I do remember in the 2004-2005 era people saying that while the Renault V10 had less bhp than the Ferrari and Mercedes, it had a wider operational rev range by a little bit so it was more driveable and thus not losing much on absolute laptime.
#24 Ross Stonefeld
  • 70,106 posts
Posted 26 December 2022 - 21:12
I think it's more that those small displacement engines lacked torque, so the only way to do anything was increasing the revs.
The torque vs peak power balance was best illustrated in the V8/V10/V12 era.
#25 as65p
as65p
  • 26,207 posts
Posted 26 December 2022 - 21:55
Yep, that's what I meant.
#26 EvilPhil II
EvilPhil II
  • 2,030 posts
Posted 26 December 2022 - 22:56
Watching highlights of a 1988 race today and NA cars were 500kg and Turbo 540kg not including driver.
#27 FirstWatt
FirstWatt
  • 1,073 posts
Posted 27 December 2022 - 17:44
Torque at Engine Crankshaft is a measure which cannot get compared between different eras, as it gets transformed with the gearing. It's torque at the wheels (or rather the propelling force at the tyre - surface contact) that is important, and therefore the power (bhp)of the engine that should be compared.
For driveability and when upshifting, of course a flatter torque vs. RPM is a good thing (which again leads to a flatter power curve).
#28 FirstWatt
FirstWatt
  • 1,073 posts
Posted 27 December 2022 - 17:45
julklapp.pdf (free.fr) The very interesting SAE paper about this fantastic engine. Osamu Goto et al...
#29 as65p
as65p
  • 26,207 posts
Posted 27 December 2022 - 19:51
That's where I had my numbers (620/685HP) from! :D
#30 RedRabbit
RedRabbit
  • 3,940 posts
Posted 29 December 2022 - 10:05
Huge torque isn't really desirable in an F1 car - it delays throttle input from the driver and leads to some squirrelly moments in slow corners.
Compare 2013 to 2014. Rosberg mentioned at the time that electric deployment was often quite sudden and the driver was somehow expected to just deal with it. We saw a lot of power slides that year, and unexpected spins.
In 2008, McLaren even had a torque limiter paddle behind the steering wheel, which the driver could use in slow corners, and allowed them to stamp the throttle while holding the paddle for better traction and acceleration.
#31 Wuzak
  • 9,100 posts
Posted 31 December 2022 - 00:22
2026 will be worse.
The power units are the same weight as today's, but will have less power available most of the time, though the peak power will be about the same (~1,000hp).
#32 Ali_G
Ali_G
  • 35,282 posts
Posted 31 December 2022 - 09:51
Torque is not a good judge of speed. F1 cars aren’t pulling trailers.
Says it all that if a car ran a CVT, you’d run the engine at peak bhp and not peak torque.
Edited by Ali_G, 31 December 2022 - 09:52.
#33 dav115
dav115
  • 747 posts
Posted 01 January 2023 - 08:38
Yes - this is why they were able to run a 6 speed transmission (and win a championship with one) when every other team had been running 7 speed since (the late 90s?)
#34 RacingFan10
RacingFan10
  • 976 posts
Posted 01 January 2023 - 16:48
With cars being so low, so lightweight, so aerodynamic, and with so much power, you don't need that much torque. The general speed and acceleration was really high and that's what really matters.
Old turbo cars of the 80s had a lot more torque than NA but if you used all of the torque usually meant lots of wheelspin. Those were also the highest in terms of weight/power ratio, at least the ones used in qualifying, some of them seemed to reach 1500 bhp with weight around 600 kg or a bit less
