316 Cubic-Inch N/A Comp Eliminator Engine Makes 870 Horsepower
No replies to this topic
#1 Bob Riebe
Bob Riebe
  • 3,169 posts
Posted 01 May 2024 - 23:33
https://www.enginela...870-horsepower/
In abstract this can be called Oldsmobiles best push-rod V-8; though rather expensive.
I did not know OHC engines could be bored for push-rod use.
There are certain classes of drag racing where most, if not all, of the competitors utilize the same engine platform. At the same time, there are other classes where the wild, the obscure, the vintage, and the modern can be found in the powerplants racers choose. TRE Racing Engines just wrapped up this engine build and made 870 horsepower with just 316 cubic inches from one of the rarest combinations you might never have heard of.
“In the 80s-90s, we built nothing but these, then we ran Pro Stock truck. Now we do a little of everything,” noted TRE Racing Engines’ Taylor Lastor.
The engine is based on GM Performance Parts’ Motorsport Aurora engine block, which was derived from the production L47 DOHC engine for the Oldsmobile Aurora. In that form, and with less than 250 cubic inches of displacement, the 8.2-inch deck small-block produced 250 horsepower. The motorsports division got a hold of it, and created a twin-turbo version of the DOHC engine that produced around 600 horsepower for IMSA and LMP applications. Later, a naturally aspirated and methanol-fueled version that revved to over 10,000 rpm was created for Indy Racing League competition.
naturally-aspirated-316-cubic-inch-screa
It wasn’t long before drag racers got a hold of it, but rather than use the dual overhead cam heads, they had to use an inline cylinder head and a single camshaft due to NHRA rules.
“NHRA makes you run GM part number parts just like Super Stock, but these parts haven’t been made in over 20 years so you need to source, find, or beg for these parts,” Lastor explained of the rarity of the parts used in this build. “They only sold them bare, so there are no lifter holes, cam holes, bolt holes, etc.”
TRE Racing Engines has engineered the necessary changes to the block to accommodate the solid roller, 60mm tool steel camshaft from Bullet Racing Cams, and Jesel .937 body roller lifters. Lastor revealed the cam specs to us, which include a split duration of 270/280, and valve lift figures of 0.980-inch on the intake, and 0.950-inch on the exhaust.....
Ifin I were rich enough to snag one of these, i would detune it a bit and put it in a last generation Oldsmobile 442, and let people muse over what Olds engine that is.
Edited by Bob Riebe, 01 May 2024 - 23:45.
