What does BDA stand for?
8 replies to this topic
#1 Danny1
Danny1
  • 19 posts
Posted 11 August 2001 - 06:09
Can anyone say What BDA stand for
Like Mike Wilds drove a Ralt RT1-BDA.
What kind of motor is that?
Greetings Dann1
#2 Frank de Jong
Frank de Jong
  • 1,830 posts
Posted 11 August 2001 - 07:26
BDA=Belt driven type A. Roadgoing engine designed for the Ford escort RS1600. Originally 1601 cc, 4 valves per cylinder. Based on the Cosworth FVA but with belt-driven camshafts.
Designation used for all sorts of F2 engines (2 litre) based on this block and head.
#3 Rainer Nyberg
Rainer Nyberg
  • 1,768 posts
Posted 11 August 2001 - 16:41
It should also be mentioned that the Cosworth BDA engines were badged as Fords. See illustration below.
Also the BD series were developed over the years BDB, BDC, BDD, BDE, BDG and so on. But usually the BDA tag stuck even for the developed versions.
The BD series was replaced with the YB series in the mid 1980s.
It was seen in the Sierra RS Cosworth and Escort RS Cosworth.
#4 Danny1
Danny1
  • 19 posts
Posted 11 August 2001 - 18:21
Thanks for your help
So I learn something about motortechnics
Greetings Danny1
#5 Catalina Park
  • 6,896 posts
Posted 12 August 2001 - 09:17
If you look at the cutaway you will see it is a three camshaft engine (2 up 1 down)!:drunk:
#6 Frank de Jong
Frank de Jong
  • 1,830 posts
Posted 12 August 2001 - 10:43
You've are right, the BDA actually has a sort of third camshaft, not for the valves but the ignition ditributor and some pumps were driven by this shaft. I can't look it up now, but IIRC this shaft is the remains of the OHV Cortina block where the BDA was based on. And why remove something that still has a function?
#7 leegle
leegle
  • 499 posts
Posted 13 August 2001 - 00:56
That shaft is referred to as a 'jackshaft' and is also present if I remember rightly on the Fiat 125 engine.;)
#8 Rainer Nyberg
Rainer Nyberg
  • 1,768 posts
Posted 13 August 2001 - 14:46
The Saab 2-litre slanted-four used between 1972-80 also used a similar shaft. The shaft provided drive for the waterpump and distributor.
#9 Catalina Park
  • 6,896 posts
Posted 15 August 2001 - 02:51
Yes the shaft is just a standard camshaft left in to run the distributor and oil pump but I wonder if the lobes are perfect or not?
