Porsche 917 gear ratios and other specs
Posted 09 January 2002 - 00:31
I´ve also posted this thread on Nostalgia Forum, but I´m guessing you might also be very able to help out.
I´m looking for the porsche 917´s gear ratios -any porsche 917, any year, any configuration- as well as some numbers, like handling in g´s (if such thing is viable) or braking distances (with any of the brakes used during the exixtance of the car, girling, bendix, whatever)
Any pointers on the matter??
Best regards
cj
Posted 09 January 2002 - 02:38
Take a look at this project, comments?
http://project917.itgo.com/
Posted 09 January 2002 - 04:53
Thx for the links. I´m afraid I knew both of them, but I admit not investigating thorougly enough.
The second link is of no use, because the engine to be installed on the car is not the original engine, hence using a 911 one.
Gunar racing has great knowledge on the matter, but still, couldn´t find any info. I might as well try to contact them.
Thanks again
cj
Posted 09 January 2002 - 14:04
Do you have the 'Motorsport' issue of February -99?
It´s got much info on various Porsche models, including chassis #22 917K
There´s a picture showing the exhaust and current gear ratios
1 - 14 - 29
2 - 21 - 29
3 - 24 - 27
4 - 27 - 25
If that was any help
Posted 09 January 2002 - 18:48
THANX!!!
Unfortunately i don´t have such magazine, because, obtaining such "precious" material in mexico on a regular basis is very hard, and kind of expensive
But the info is excellent, thanks a lot!!
cj
Posted 09 January 2002 - 21:57
I´m a big Porsche enthusiast myself and I have an Vintage Porsche 356 coupe -64
for restoration at the moment. I´m planning to make it an historic racer hopefully.
cheers
Posted 09 January 2002 - 22:07
I can imagine the ratios for a 917 K (short tail) being very different from the langheck version at Le Mans and as for the 1100hp 917-10 that Folmer and Donahue drove in CAN-AM well something different again I should think.
Ben
Posted 14 January 2002 - 23:56
He quotes 'absolute best' figures of 1.65g for lateral acceleration and 1.50g for braking deceleration. These figures were recorded on a 917L (042) at Hockenheim in 1970.
He also quotes the gear ratios for the 5-speed boxes used on the long-tailed cars if you want them.
Posted 16 January 2002 - 04:24
And welcome to atlasf1
cj
Posted 17 January 2002 - 00:36
Le Mans 4.5 litre long-tail: 15:29, 21:29, 23:24, 26:21, 30:21
Le Mans 4.9 litre long-tail: 15:29, 21:29, 23:24, 26:21, 31:21
Le Mans 4.5 litre short-tail: 15:29, 21:29, 24:23, 27:20
Le Mans 4.9 litre short-tail: 15:29, 21:29, 24:23, 32:23
Monza 4.5 litre short-tail: 14:29, 22:29, 23:24, 26:21
Monza 4.9 litre short-tail: 14:29, 22:29, 26:26, 29:22
Spa 4.5 litre short-tail: 15:29, 22:29, 24:23, 28:22
Spa 4.9 litre short-tail: 15:29, 22:29, 24:23, 29:22
all with 8:37 crown wheel & pinion
(Source is Paul Frere's 'The Racing Porsches')
I was going to ask what you did with all this information but then I went and had a look at your website - wonderful stuff
Posted 17 January 2002 - 07:05
Thanks A LOT for this.
Glad you liked the page (don´t forget to sign the guestbook
cj
Posted 17 January 2002 - 12:22
"The spaceframe of the original 917 was pressurised, gas-filled, so that if the gauge lost more than so much pressure, you knew you had a crack. When that happened, they'd go round all the joints with a cigarette lighter!"
Posted 17 January 2002 - 17:01
Man those must be really thick gears to necessitate an entire rear bodywork extension for one more ratio!Originally posted by Bumblyari
Here we go then:
Posted 17 January 2002 - 18:26
Posted 07 January 2021 - 19:02
Can anyone confirm either from Paul Frere's book, or Walter Näher's book, the actual weight and front/rear track widths of the 1971 Porsche 917s?
