Tamiya version of the BT46.
The Brabham BT 46 F1 car above was, to my knowledge, the only attempt ever made to utilitise "surface cooling" on a race car. The concept failed, and the car was quickly fitted with radiators.
I was wondering whether or not it would be possible to use a similar arrangement of cooling "units" (radiators, whatever), but with the units installed as part of a wing. For example, on an F1 car, if you made the underside of the rear wing out of an aluminium matrix, and piped a small proportion of the cooling water through that matrix, would the heat being dissipated at the surface of the wing create an increase in downforce? After all, the heat transfer would excite the air flow, make it (the air) run faster and reduce the pressure at the under wing surface, thereby increasing the downforce for that particular wing angle. (I think my physics on this one is sound ....
For sure, there are downsides wiith this layout. First there would be the negative effect on the car's C of G by the weight of the pipework and the weight of the water inside the pipwork, both mounted high up on the rear of the chassis. Also, radiators would still be required (tho' slightly smaller) so there would need to be a very clever valve arrangement to divert sufficient water between the wing and the radiators.
Finally, if you again think of one of today's F1 cars, and throw away the wooden plank on the underside of the chassis, you could then mount a single long, thin radiator "unit" in its place. With a similar proportion-valve arrangement described above, you would have another area where the heat being dissipated under the car could excite the airflow, and for the reasons described above, would generate more downforce.
Final thought. If you could mount a radiator in the wing, I would estimate (guesstimate actually) that it would be able to radiate away about 10% of the engines heat. As far as I understand it, the engine oil-cooler is about 10% of the size of the water radiators......
Anyone else want to chip in their 2c on this one?
