Acceleration and gearing
Posted 27 March 2002 - 01:40
Posted 27 March 2002 - 02:54
Posted 27 March 2002 - 06:58
A very reliable source has told me the new Ferrari F2002 can change gears in the middle of a sharp bend, without upsetting the car at all....
Jezz
Posted 27 March 2002 - 08:01
Posted 27 March 2002 - 10:26
Posted 27 March 2002 - 13:33
Originally posted by MRC
The RPMs you drop is dependent on the difference in the ratios, and not the time of the shift.
Incorrect. Drive your car, put it in 2nd. Change from 2nd to 3rd in 1s, and note the rev drop. Then go back, 2nd. Change to 3rd in 4s and you tell me if your revs don't drop - and if they don't, mail me, cos you got an amazing car.
Jezz
Posted 27 March 2002 - 13:49
Posted 27 March 2002 - 15:43
Ok. Now I might have taken you the wrong way, but let's break down this statement.
"The quicker you change" - so the quickest is time=0. Correct? Yes, obviously. Can anyone or anything change gears in zero time? No. Is that what they are trying to approach? Yes.
So, with a zero time gear change, the revs still drop drastically changing up a gear.
Now, let's look at a 5 second gear change. You are in gear X. Now you begin shifting. For 5 seconds you are decelerating, and thus losing speed (unless your going down a hill or something). The drop in speed (AND the gear ratio change) that happened over those 5 seconds, is what will give you the drops in revs.
So I guess I will restate - the rev drop will be due to the loss in speed and the change in gear ratio. Time is not an issue, except for it's effect on how long you will be decelerating or accelerating (although most likely the former). So, with a very small gear shift time (ie F1) the biggest part of the rev drop is due to the gear ratio change.
Yes, I understand that a fast shift is required, and means faster lap time. This is due to less time spent decelerating.
If I misconstrued your statement, then I apologize.
Posted 27 March 2002 - 15:50
When you shift a gear you should be at or around the engines peak torque. You then shift to a hugher gear which takes you back to the bottom of the power band to allow the car to accelerate up to a higher speed with the higher gear.
Check out Hewland.com where you can create ratio charts and adjust the rpm drops to allow you to maximise the gearing dependent on the power band and anticipated speed range. Also creating tractive effort curves using the methods shown in Gillespie or Genta is very instructive.
Ben
Posted 27 March 2002 - 15:55
Well no, because there is a rule which states the minimal time for changing a gear.Originally posted by mcerqueira
I was wondering, do you think that with today's gearing change times (measured in milliseconds I guess) the focus is still on shaving that even further? Since the ideal would be instantaneous shifting I guess it is...
Ciao,
Liran Biderman.
Posted 27 March 2002 - 18:57
"Incorrect" was specified towards "...and not the time of the shift.", because, as you rightly said, the time isn't a factor of rev 'loss'; the deceleration is (thats where my crap wording kicked in), but time is a factor in relation to deceleration which is responsible for rev loss.
*PHEW* Hope that makes some sense.
Jezz
Posted 27 March 2002 - 19:24
Posted 27 March 2002 - 23:05
No problem. All ist klar.
Wunderbar.
Posted 28 March 2002 - 01:27
Originally posted by schuy
Wunderbar.
Also gut. anyway regarding the minimum amount of time to change gears, I guess CVT won't see the light in F1.....
Posted 28 March 2002 - 04:09
Posted 28 March 2002 - 07:51
Posted 28 March 2002 - 21:33
Indeed if they do (as claimed) produce 900hp they do have more torque so that would explain it.
Ben
Posted 28 March 2002 - 23:36
Unelss we're just talking about how long the gearshift itself takes, but I didn't think that was the original question.
Posted 02 April 2002 - 03:35
Posted 11 April 2002 - 14:25
I remember that at the time Ferrari had a legal traction control system running in their car that only switched on for about 200milliseconds, which was the time that the engine and wheels were disconnected. Something about FIA's rules being interpreted as to allow TC if the wheels are not being driven.
I asked on that thread about revving your enine as high as possible during a gear change to reduce the lost revs. If you had a high performance clutch and a sizeable flywheel I think it would make a difference... or would it?
Posted 12 April 2002 - 01:18
Posted 12 April 2002 - 05:06
Ciao,
Liran Biderman.
No there isn't.
Posted 12 April 2002 - 08:10
Originally posted by Pioneer
No there isn't.
Sorry, my bad.
I seemed to remember, there was a suspicion Ferrari employed a very clever TC since it's gearbox was so fast, and they used the rest of the time to get to the minimal time required to change gears to regain lost traction.
I just went over the regulations again, nothing like this is closely stated there.
Liran Biderman.
Posted 12 April 2002 - 08:21
The test included the new Lamborghini Murcielago, the Pagani Zonda C12 and the B.Engineering Edonis.
The Lambo has 571BHP over 1819kg.
The Pagani has 555BHP over 1250kg.
The Edonis has 708BHP over 1400kg.
But, look at this 0-60mph information.
So, from this data, you would the Edonis would kick ass, and the Pagani will probably be better than the Lamborghini Murcielago.
But, both the Lambo and the Edonis do 3.6s, whilst the Pagani does 3.7.
I think this is very strange.
The Edonis is geared for high-speeds(226mph), but still, it is supposed to kick ass, because a long first ratio would mean it doesn't have to change gears until 60.
Perhaps the Edonis is having trouble, because it has to wait until it's quad-cam turbos kick in, as max torque is at 3,750 rpm.
The Edonis has more BHP than the McLaren.
Maybe just clever mechanics by the Lambo crew?
Thism is their first 6-speeder.
But, what is really strange, is how the Pagani didn't clock a better time.
Maybe bad traction then?
Liran Biderman.
Posted 12 April 2002 - 10:19
Posted 12 April 2002 - 12:49
Posted 12 April 2002 - 13:32
Originally posted by Ursus
When you've got that kind of power, 0-100kph times is greatly affected by how well you can put down the power. The lambo may well have 4 wheel drive (didn't later model diablos have this?) and so can use it's power better and keep up despite it's unholy weight.
Yes, that's very true.
I can't believe I forgot that.
Posted 12 April 2002 - 18:38
I just read a group test by Autocar, from April 3 2002.
Liran Biderman.
0-60 is about balancing traction and torque curve against inertia: spin the wheels and you go nowhere; don't spin the wheels, the engine bogs (because it's geared to do 1000rpm at 10mph or whatever) and you go slowly. The Lambo is naturally aspirated and large capacity (i.e. good low-end torque) and has 4wd but is heavy. The Zonda is rwd, but big-cube nat-asp and light. The Edonis has the worst of all possible worlds: small(-ish) capacity turbo, rwd only and not the lightest. Remember also that the Edonis as tested as down on power, producing only about 680bhp.
It would be better to measure 30 to 90 if you want a 60mph increment. This still avoids the zone where drag becomes the overriding issue.
