Are there regulations about this?
cya
Posted 29 April 2002 - 12:24
Posted 29 April 2002 - 13:04
Posted 29 April 2002 - 13:18
Posted 29 April 2002 - 18:53
Posted 29 April 2002 - 19:07
Posted 29 April 2002 - 19:53
Posted 30 April 2002 - 05:51
Posted 30 April 2002 - 15:14
Posted 01 May 2002 - 07:12
I think this weekend proves it's not enough. Or the rules needs to be adjusted.They specify the forces that must be resisted, and allow the teams to find the appropriate solutions.
The FIA have a habit of not letting the teams deicide too much for themselves if safety is a concern.If the F1 teams are using ultra-high modulus fibers and resins with little fracture strain, then they have to live with the consequences.
Posted 01 May 2002 - 17:03
Posted 01 May 2002 - 17:14
Watch out, you could get the wrath of Max over you for that one ;)Why do you believe wing structure should be regulated? This is a volunteer sport
Don't they today?I don't think the FIA should be involved in specifying any materials or construction for any component.
Posted 01 May 2002 - 18:08
Posted 01 May 2002 - 18:20
Thanks, didn't know thatSpectra, Dyneema, and Zylon all suffer the same problem - low surface energy, which makes it difficult for other materials to adhere to them, which makes it difficult to use them in composites with high mechanical properties.
Posted 02 May 2002 - 01:27
Posted 02 May 2002 - 09:23
Are they faster than F1 cars? No? I knew something was wrong.Well, take a look at Le Mans prototypes over the past decade
Posted 02 May 2002 - 22:52
Posted 03 May 2002 - 02:44
Originally posted by Fredrik Billig
Are they faster than F1 cars? No? I knew something was wrong.![]()
