I would just like to know what the advantages would be, because apart from strength wouldn't aluminium be the better metal because its lighter and dissipates heat better?
Thanks for any input.
Posted 10 August 2002 - 18:39
Posted 10 August 2002 - 18:57
Posted 10 August 2002 - 19:20
Posted 10 August 2002 - 19:22
Posted 10 August 2002 - 19:54
Originally posted by F1Champion
Hi, I've been recently reading articles suggesting that the 2003 Ferrari engine block will be made from cast Titanium.
Posted 10 August 2002 - 20:12
Posted 10 August 2002 - 22:22
Posted 10 August 2002 - 23:40
Posted 10 August 2002 - 23:59
Posted 11 August 2002 - 00:33
Posted 11 August 2002 - 00:49
Posted 11 August 2002 - 01:02
Posted 11 August 2002 - 01:16
Originally posted by desmo
A crankcase, it appears to me in order to be made this way, will have to be done in pieces and then welded together.
Posted 11 August 2002 - 01:40
Posted 11 August 2002 - 02:00
Posted 11 August 2002 - 02:19
One F1 engine guy I communicated with seconds VAR's suggestion that explosion formed steel crankcases may offer the best potential for mass reduction. Weren't the Barnard designed Ferrari's cases of steel, nevermind the '50s Mercedes GP racers? [/B]
Posted 11 August 2002 - 13:35
Posted 11 August 2002 - 16:42
Originally posted by Pioneer
5.5.1 The basic structure of the crankshaft and camshafts must be made from steel or cast iron.
5.5.2 Pistons, cylinder heads and cylinder blocks may not be composite structures which use carbon or aramid fibre reinforcing materials.
Make of that what you will.
You could make the block out of non-metallic substances if you wanted to. I think.
Posted 11 August 2002 - 18:50
Posted 11 August 2002 - 21:22
Posted 12 August 2002 - 11:22
Originally posted by Top Fuel F1
8. To eliminate these voids they do an "after cast" process called Hot Isostatic Pressing or "HiPing" (at 1,600 deg. F and at 15,000 psi in an inert gas vacuum), which closes the voids.
Posted 12 August 2002 - 19:16
Posted 12 August 2002 - 19:35
Posted 12 August 2002 - 19:58
Ti is effectively half as stiff as steel and a little under half the weight. To expand on how tedious it is to cast Ti.: One company which actually was started to exclusively supply Ferrari with Ti parts, and now supplies others as well, uses a proceedure which is probably what would be used to cast such a block:
1. They can make the casting pattern directly from CAD, which is used in the Investment Casting Process.
2. Use a gravity casting in a vacuum chamber.
3. The melt time is carefully calculated and the amount of material is critical.
4. One main problem is that the Ti solidifies extremely fast (a matter of some number of seconds)
5. Ti melts at 3,000 deg. F ,with the mould temp. probably about half that.
6. The melt doesn't retain much "super heat" above the initial melt temp. so you must get it into the mould quickly.
7. Small voids can form in the center of the casting because solidification is from the skin inwards
8. To eliminate these voids they do an "after cast" process called Hot Isostatic Pressing or "HiPing" (at 1,600 deg. F and at 15,000 psi in an inert gas chamber), which closes the voids.
9. Although they are working in inert gas I guess it's not perfectly inert. If Ti is over a 1,000 deg F it's surface tends to react with any oxygen present. The higher the temp. the more reactive.
10. The surface (maybe for 10-20 thousands) becomes oxygen rich which can allow flaws/weaknesses to form and propagate cracks.
11. To get rid of the oxygen enriched layer requires chemical milling of the surface which also producess a nice finish.
Posted 12 August 2002 - 20:24
Posted 13 August 2002 - 01:51
One factor not mentioned in this thread is thermal conductivity. One reason why engine blocks are converted from cast iron to aluminium alloys is because the higher thermal conductivity of aluminium allows higher engine compression ratio. A typical cast Al alloy for F1 blocks is 356, with thermal conductivity of 150-160 W m K^-1. Titanium alloys have thermal conductivity of ~ 7 W m K^-1. This difference would require significant redesign of a block.
Posted 13 August 2002 - 02:19
Posted 13 August 2002 - 02:51
Posted 13 August 2002 - 03:17
Posted 13 August 2002 - 04:27
Posted 13 August 2002 - 06:39
Posted 13 August 2002 - 06:59
Originally posted by Ferrari_F1_fan_2001
Titanium is 5 times more expensicve than steel and i think its 3 times stronger
Posted 13 August 2002 - 09:06
Posted 13 August 2002 - 09:50
Originally posted by MRC
A
I think running an aluminum cylinder head would have larger benefits than converting to aluminum block. The exhaust valve temperature is closely related to the tendency for detonation. An aluminum head allows more even temperatures around the exhaust valve.
Posted 13 August 2002 - 12:52
Posted 13 August 2002 - 14:10
Posted 13 August 2002 - 15:37
Originally posted by random
However, I've recently read in few different sources that some (most Nascar) teams have managed to acquire titanium suspension pieces that a magnet will stick to... Neat trick that.
Any clue how it's done?
Posted 13 August 2002 - 16:17
Posted 13 August 2002 - 19:01
Posted 13 August 2002 - 19:43
Posted 13 August 2002 - 23:35
Of course the pre-war engineers were aware of this; whilst aluminium was often used, bronze was also popular. Most curious of all was the AJS company's plan to cast the 500cc" Porcupine" motorcycle's head from silver.
Posted 14 August 2002 - 17:01
Posted 14 August 2002 - 17:39
Posted 14 August 2002 - 17:43
Originally posted by Cory Padfield
Can someone explain the chamber geometry we see? What is the shape we see in the upper part of each chamber? The lower part of each chamber seems to be a smooth, right circular cylinder that would define where the pistons move. Does this block need liners? Any evidence of coolant passages? Thanks for any help.
Posted 16 August 2002 - 12:25
