Cooling fans set low in the side pods could be used in the hotest moments, perhaps adding up to only a very small proportion of the total race time, allowing radiator dimensions to be further reduced with associated benefits for aerodynamics. Y/N?
Posted 25 May 2003 - 12:52
Posted 25 May 2003 - 13:14
Posted 25 May 2003 - 13:26
Posted 25 May 2003 - 14:01
Originally posted by lustigson
...fans like in any road car don't have any function whatsoever on a Formula 1 car.
Posted 25 May 2003 - 17:38
Posted 25 May 2003 - 20:56
Posted 25 May 2003 - 21:35
Posted 25 May 2003 - 23:43
Posted 26 May 2003 - 02:56
Posted 26 May 2003 - 05:53
Posted 26 May 2003 - 14:15
Originally posted by YKTS
As far as i know, you cannot run fans on a modern day f1 car. they come under a movable aerodynamic devide, think back to the brabham fan car, that was argued as a cooling device.........
Also in the book, Formula 1: The Turbo Era - Alan Henry 'He had elected to use a fan assisted intercooler, but recalled Brabham designer Gordon Murray coming into the garage at one race and saying "It's a good idea boys, but I'm afraid it's illegal." However as he (Brian Hart) explains, "We were so far back on the grid that nobody bothered with us. In those days you didnt screw your mates!"'
Posted 27 May 2003 - 01:28
Posted 27 May 2003 - 01:39
Posted 27 May 2003 - 02:07
Posted 29 May 2003 - 01:22
Posted 29 May 2003 - 15:12
Posted 29 May 2003 - 22:54
Posted 30 May 2003 - 03:27
Originally posted by Engineguy
If fans with their inlets underneath the car or their outlets on the top surface of the bodywork are moving aerodynamic devices... what does that make the pistons in a car with its exhaust outlets pointing upward? Hmmm...
Back on topic... As for pit stop and extended grid delay engine cooling... under drivetrain disengagement (i.e. clutch disengaed and/or trans in neutral) conditions, I would monitor the coolant temp and randomly fire fewer and fewer cylinders per crank revolution, with richer and richer fuel mixture as needed to keep temps out of the red zone.... it doesn't take much power to keep revs up without load, and the special map can be instantly abandoned upon detection of drivetrain status change. Cadillac boasted of total coolant loss limp home capability for their Northstar engines a few years ago... and that was while generating enough power to drive the car.
Posted 30 May 2003 - 05:09
And if not the pistons, surely the valves are
Posted 30 May 2003 - 12:18
Posted 30 May 2003 - 17:52
Posted 10 June 2004 - 13:55
Posted 15 June 2004 - 14:30
