This is the constantly variable transmission unit developed by DAF (now part of Volvo) and used in a Brabham F3 car circa 1966.
Posted 12 July 2000 - 07:31
Posted 12 July 2000 - 13:53
Posted 12 July 2000 - 15:37
Posted 12 July 2000 - 15:56
Posted 12 July 2000 - 17:27
Posted 12 July 2000 - 21:44
Posted 13 July 2000 - 07:08
Posted 13 July 2000 - 08:42
Posted 13 July 2000 - 10:21
Posted 13 July 2000 - 13:15
Posted 14 July 2000 - 03:08
Posted 14 July 2000 - 04:33
Posted 14 July 2000 - 05:36
Posted 14 July 2000 - 06:09
Posted 14 July 2000 - 06:45
Posted 14 July 2000 - 06:47
Posted 14 July 2000 - 06:57
Posted 14 July 2000 - 07:36
Posted 14 July 2000 - 09:31
Posted 14 July 2000 - 13:07
Posted 14 July 2000 - 14:07
Posted 25 July 2000 - 11:11
Originally posted by desmo
I would love to read that article by Setright. In fact, I highly recommend reading anything you can get your hands on by LJK. He would be the ultimate poster for this forum (except maybe a certain Mr. Newey!).
Posted 25 July 2000 - 12:43
Posted 25 July 2000 - 14:49
Posted 25 July 2000 - 19:50
Posted 25 July 2000 - 22:14
Posted 03 August 2000 - 15:02
Posted 04 August 2000 - 15:26
Posted 05 August 2000 - 06:03
Posted 09 August 2000 - 21:06
Posted 10 August 2000 - 07:26
Posted 17 August 2000 - 13:33
Posted 18 August 2000 - 11:43
Originally posted by mat1
Yes. Where is LJKS now? is he still writing? Or is he retired?
Mat1 [/B]
Posted 09 February 2002 - 00:37
Posted 09 February 2002 - 02:16
Posted 09 February 2002 - 22:35
Shifting gears in 0.8 sec in a road car is not a good thing unless it is hooked to a very low-inertia, narrow-powerband engine. If the engine takes 1 sec to drop from one rpm speed to the next, then shifting gears in 0.2 sec will cause nothing but damage to the driveline, engine, handling, and driver's ego.Originally posted by MN
Forgot to mension.
Nissan engineer in the interview says avarage driver can shift gears in 0.8 sec.
Professional racer in a long destance race who has to look after gears may shift in 0.5 sec.
Professional racer in qualify sessions may shift gears in 0.2 sec.
Driving Skyline 350GT-8 in manual CVT mode, "Anyone can shift as fast as Schumacher in qualify" he says.![]()
Posted 14 February 2002 - 16:50
Posted 16 February 2002 - 04:13
Posted 20 February 2002 - 13:42
Posted 20 February 2002 - 17:06
"We started out three years ago looking for a way to improve our truck and SUV fuel economy, and were totally unprepared for how spectacular the results would be from a driver's perspective. What we've ended up with is a tranmission which offers refinement, smoothness, and responsiveness unmatched anywhere in the truck or SUV industry." -Vance Zanardelli, manager, Transmission and Engine Systems
Continuously variable transmissions hold potential for significant fuel savings, however up until now, their use has been limited to relatively small vehicles with engines generally 3.0 liters or less.
After three years of development, Ford Motor Company engineers are testing a more robust CVT design in a Ford Expedition sport utility, with its standard 215 hp, 4.6-liter V-8 engine. This represents the first time this technology has been applied to a full-size truck.
The most common CVT technology uses a belt-and-pulley system to transfer torque through a range of drive ratios. These systems are typically used in front-wheel-drive applications, with relatively small engine sizes, due to an inherent limitation in the design.
As the belt-and-pulley components are made larger to handle the higher torque demands of more powerful engines, the belt eventually gets so large that it generates excessive centrifugal force as it moves around the pulleys. The clamping force required to hold the belt in place eventually generates unacceptable mechanical losses.
The research system uses a Traction Drive CVT design that offers several advantages. In this architecture, called a "variator," two discs are arranged on either side of a tilting or articulating roller - one disc for torque input, the other for output. The roller angle between the discs determines the final drive ratio. There is no belt.
While torque in the belt-and-pulley system is transferred via metal-to-metal friction between the components, the Traction Drive CVT establishes a fluid film between the polished surfaces of the roller and discs. This boundary layer - about one micron thick - develops enough shear strength to transfer torque between the components, without actual metal-to-metal contact. These qualities allow it to be upsized for larger uses, as in full-size trucks or sport utilities.
Ford Motor Company engineers estimate it could handle engines up to 7.3 liters in displacement.
The fluid is completely synthetic, developed specifically for this purpose. Where conventional transmission fluids would simply allow the smooth bearing surfaces to slip past each other, the new fluid - dubbed "liquid gear teeth" by engineers - begins to act more like a solid under the high pressures generated in the Traction Drive CVT, and adheres to the molecules of the metal surfaces. The roller and discs can exert up to 600,000 pounds per square inch against each other.
The Traction Drive CVT technology - for which Ford and Mazda hold 10 patents - holds out the promise of considerable fuel economy improvements for these vehicles, in addition to the benefits of smoothness and refinement that come with eliminating the relatively large steps between gears of a conventional automatic transmission.
For example, Ford Motor Company engineers are projecting a potential, immediate 10-percent fuel-economy improvement in the test Expedition, with only calibration changes in the powertrain and without sacrificing either engine power or emissions performance.
In fact, project engineers expect both overall emissions and vehicle drivability to improve with the Traction Drive CVT.
One reason for this immediate fuel economy gain is the wide gear ratio that the CVT offers. The Expedition's four-speed automatic transmission operates over a ratio of approximately 4:1 from low gear to overdrive. The Traction Drive CVT fitted to the test vehicle uses a 7:1 ratio range.
In highway cruising and most daily operation, this allows a much lower engine speed - perhaps 500 revolutions per minute less. When more power is needed, such as for passing or climbing a steep hill, the CVT seamlessly steps down, engine speed rises, and more power is on tap almost immediately.
It reacts so quickly to engine load changes that it can shift from lowest to highest gear within about six engine revolutions - far quicker than would be necessary in the real-world environment.
In another economy benefit compared with traditional automatic transmissions, the Traction Drive CVT design allows a very aggressive lockup strategy at the torque converter, reducing mechanical loss.
Ford engineers are currently refining and calibrating the newly completed test vehicle, as they begin field trials to confirm the fuel economy benefits.
CVT Joint Venture
Ford Motor Company also is pressing ahead with plans to develop belt-type Ecotronic variable transmissions to bring the benefits of CVT wide gear ratio span to front wheel drive vehicles, such as passenger cars and small sport utilities. The new Econtronic family of transmissions can handle up to 174 foot-pounds of torque, greatly expanding the possibilities for belt-type CVTs. "
Posted 20 February 2002 - 19:46
Posted 24 February 2002 - 04:15
Tell Nissan about it, they may not know that.;)Originally posted by imaginesix
Posted 27 May 2003 - 00:14
Posted 27 May 2003 - 00:21
Posted 27 May 2003 - 00:50
Posted 27 May 2003 - 01:18
Posted 27 May 2003 - 01:54
Originally posted by gshevlin
This was not the first time the FIA had done this to Williams - they banned cars with more than 4 wheels at the end of 1982, ruining Williams' plans to run their six-wheel car in the 1983 season.
Posted 27 May 2003 - 03:39
Posted 27 May 2003 - 04:10
All four rears were driven in the '81 FW07D and '82 FW08C (be advised, the taxonomy is controversial) as was the earlier March with four rears. The advantage was said to be primarily aero, although anecdotal reports were that the Williams both did standing starts very smartly and was notably steerable under hard throttle. Neither made it to a race as far as I know.
Posted 27 May 2003 - 04:12
