If anyone has this information would be gratefully recieved .
Thanks in advance...............dyno's would be a bonus LMAO
Mark.
Posted 26 July 2003 - 18:13
Posted 26 July 2003 - 18:49
Posted 27 July 2003 - 08:39
Posted 27 July 2003 - 09:54
Posted 27 July 2003 - 10:39
Years of Activity:
1976/1977/1978
Engine:
Type 015, rear-mounted 180° V12, light alloy cylinder block and head, aluminium wet liners, 112 mm connecting rods, water cooled
Bore & Stroke:
80 x 49.6 mm
Unitary and Total Displacement:
249.3168/2,991.801 cc
Compression Ratio:
11.5:1
Max. Power Output:
500 bhp at 12,200 rpm
Timing Gear:
4 valves per cylinder, 2 camshafts per cylinder bank gear driven off the rear of the engine
Fuel Feed:
Lucas indirect injection
Ignition:
Single plug with coil-ignition unit and Dinoplex electronic capacitive discharge
Lubrication System:
Dry sump
Transmission:
Rear-wheel drive, Borg & Beck multi-plate clutch, 015 5-speed gearbox + reverse, transverse in unit with limited-slip friction plate differential
Gear Ratios:
Variable depending on track
Chassis:
Type 629 monocoque with aluminium panels riveted to variable section light alloy structure
Front Suspension:
Double wishbones, inboard spring/damper units
Rear Suspension:
Upper arm, lower wishbone, single central radius arm
Brakes:
Brembo discs, Lockheed callipers, inboard at rear
Steering:
Rack and pinion
Length:
4,316 mm
Width:
1,930 mm
Height:
1,020 mm
Wheelbase and Front/ Rear Track:
2,560/1,405 mm/1,430 mm
Kerb Weight (with water and oil):
575 kg
Front Tyres:
9.2-20.0-13" Goodyear
Rear Tyres:
16.2-26.0-13" Goodyear
Wheels:
split-rim, front 10x13", rear 19x13"
Fuel Tank:
200 litres, 2 side + 1 central tanks, NO 98/100 petrol
Bodywork:
Single-seater aluminium body with composite elements
Posted 27 July 2003 - 23:02
Posted 27 July 2003 - 23:20
Posted 27 July 2003 - 23:25
Posted 28 July 2003 - 21:23
Posted 28 July 2003 - 21:34
Posted 05 August 2003 - 14:15
