Posted 30 August 2003 - 13:29
Power = Torque (T) * Angular Velocity (V) = T * V (equation 1)
The trick is to convert this relationship to units with which we are familiar.
For the fps case:
Converting RPM to Angular Velocity
1 RPM = (2 * Pi)/(60 s) = [2 * (Pi/60)] (rad/s) [comment: the term radians (rad) is dimensionless ]
Relating ft-lb to Horse Power
1 HP = 550 ft-lb/s [comment: this constant that will be used in the equation below .]
Now, using eq 1 & dimensional analysis, HP expressed in Torque (ft-lb) and Angular Velocity (RPM)
HorsePower = [T ft-lb] * [(HP * s)/550 ft-lb)] * [RPM (2* pi rad)/(60 s)] = (T * RPM)/5252.11
Or, more or less HP= (T * RPM)/5252 [comment: where Torque expressed in ft-lbs ]
For the mks case:
1 RPM = (2 * Pi)/(60 s) = [2 * (Pi/60)] (rad/s) [same as done above for fps case ]
Relating N * m to KWatts
1 KW = 100 Watts = 1000 * N*m /s [comment: constant that will be used in the equation below .]
Now, using eq 1 & dimensional analysis, KW expressed in Torque (N*m) and Angular Velocity (RPM)
KiloWatts (KW) = [T ft-lb] * [(KW * s)/1000 N-m)] * [RPM (2* pi rad)/(60 s)] = (T * RPM)/9549.29
Or, more or less HP= (T * RPM)/9549 [comment: where Torque expressed in N*m ]
