ENGINE BRAKING
Posted 24 June 2000 - 06:09
Posted 24 June 2000 - 14:05
Gunner
Posted 25 June 2000 - 03:26
This compression stroke is certainly going to slow the car down, and without power coming from the power stroke, as when the throttle is closed, it will aid braking considerably. In addition to this, the power stroke becomes another help under these conditions, and to a lesser degree the inlet stroke does too.
First, the inlet stroke is sucking mixture from a manifold and port that is closed off by the butterfly that controls the flow, so the piston's downward progress is ******** by that vaccuum. Then, in the firing stroke, it is ******** in the same way, but in a more confined space.
Posted 25 June 2000 - 14:18
Posted 25 June 2000 - 19:56
You are talking about a Jacobson engine Brake. My son drives a truck and told me that they are told to only use them when necessary as they put a heavy load on the engine. Some towns have signs that say (don't use Jake Brakes) as the loud cracking sound disturbes people.
Gunner[p][Edited by gunner on 06-25-2000]
Posted 25 June 2000 - 20:19
Gunner, here's a tricky one I asked in 'Nostalgia Forum'/superchargers. Did BRM P56 have it's exhaust pipes so nicley sticking up to get opposite effects of Jacobson/Oetiker brake (increasing power through decreasing exhaust pressure)? [p][Edited by Wolf on 06-25-2000]
Posted 25 June 2000 - 20:43
There is an old boy that goes by my house and uses the Jake brake to get his girl friends attention. Loud isn't the word for it It sounds like a high speed anti aircraft gun.
Gunner
Posted 25 June 2000 - 20:59
I don't know about the BRM but what little I remember about the Jake that my son said that it limits the opening of the valves? And builds up a very high pressure in the cylinders. So if it was used on an F1 engine I would think it would tare it to pieces??
Posted 25 June 2000 - 21:15
Let me re do this I would say that BRM's exhaust would be the opposite of an engine brake. It might of been a tuned exhaust system which would suck out the exhaust and pull in the intake charge quicker with the help of valve overlap. But if it was Supercharged it wouldn't make any difference.
Gunner
Posted 25 June 2000 - 21:42
The Jake brakes then come into play, and as Art says, they are quite loud. We used to live on the highway at the bottom of a very long and steep hill (the Gov spent $3mil doing it up because of the steepness and length, the house in which we lived had been hit previously, while another nearby house had a hole made straight through the middle!) and each night we were certain that each truck was coming in to see us... because of the ever increasing noise of the Jake brakes.
Brake smells always lingered in the air around the place, too.
Posted 25 June 2000 - 22:43
Posted 25 June 2000 - 23:49
Posted 26 June 2000 - 01:33
Gunner[p][Edited by gunner on 06-26-2000]
Posted 26 June 2000 - 15:45
Posted 26 June 2000 - 22:08
Posted 26 June 2000 - 22:29
Posted 26 June 2000 - 22:33
Posted 28 June 2000 - 23:54
Gunner
Posted 28 June 2000 - 23:59
The simplest things oft turn to be most effective. I like that brake.
Posted 29 June 2000 - 00:13
Remembering everyone at school had said to put your shoe up against the tyre, he promptly put his foot on the front wheel.
Pretty hard on the teeth!
Later he learned that they meant the rear wheel... that was after Dad showed him how to straighten bent front forks!
Posted 29 June 2000 - 00:29
Posted 29 June 2000 - 02:19
Posted 29 June 2000 - 02:31
I just wouldn't drive any other way, myself.
Posted 29 June 2000 - 06:02
My dad always toold me when I was learning to drive, Gears are for going, brakes are for slowing.
Yes it does make a difference to engine brake for large loads, as in a truck, but a modern day car is designed generally for an auto trans, where engine braking becomes less of an effect. So therefore the brakes are generally more then enough to pull the car up.
Posted 29 June 2000 - 16:43
Gunner[p][Edited by gunner on 06-29-2000]
Posted 29 June 2000 - 20:52
Posted 30 June 2000 - 01:09
Gunner[p][Edited by gunner on 06-30-2000]
Posted 30 June 2000 - 08:40
The eastern seaboard, where most of us live, is full of curvy mountain roads, and then in the cities we have intersections, traffic lights, pedestrian crossings, all the sorts of things you enjoy when you go to the big smoke in Maryland... and probably more.
Posted 30 June 2000 - 18:12
Big Savage is nuthing more than an extended hill 2700ft high. The real mountains are the Rocky Mountains out west. I use to set in my living room in San Bernadino Cal. and look at San Gergonia mountain 14,000 ft high. Once you leave Maryland and get to northern Ohio it is flat as a board untill you hit the Rockies. If the weather doesn't get better in 10 years you could put a big red rock in southern Indiana and you would sware you were in the outback.I guess we are kind of Hillbillies we live in a board shack a mile off of the main road with news paper stuffed in the holes in the wall and a wood stove for cooking and heating. We also have a pig pen next to the house that gets a little testy in warm weather. Also a few Chickens in the yard. Maybe someday we will get the modern conveniences you have down under? The worst thing is the outhouse in the winter time man that is a rough trip in three feet of snow.
Posted 30 June 2000 - 22:34
Snow won't be as deep... what's it like where my son is, Bloomington, Indiana? I haven't seen him in seven years and he's not much on writing.
Posted 30 June 2000 - 23:24
Bloomington Im not sure but Indiana is about like ohio both are a little hilly in the southern part and when I say hilly I mean more or less rolling land but mostly flat. They get some pretty harsh weather in the winter. I don't really live that bad but it sounded good at the time. As far as the Sheep if I would of had any when the boys were growing up they would of been getting in practice for there future lives.
Posted 30 June 2000 - 23:41
Just for interest's sake, Art, I'll tell you about this. I was divorced from my first wife on 11th Nov, Armistice Day, you might recall, and at 11 o'clock, what's more.
Is that good stuff, or what?
Looks like there won't be a twelfth, however, the war is still on, lasted nearly three times as long as WW1!
I sent the above notes to my son, the stuff about ohio, snow and outhouses, might jolt him into writing to me.
He works in Indy, but doesn't go to the race. Works with computers.. which brings me to something else... your scanner.
Don't make the mistake of scanning at high resolutions. For use on the net, or emailing, scan at about 70dpi. Sure, for printing out you might go higher, especially if you have a really good colour printer and good paper for copying pictures, but the files get too big and it's no use anyway. When I scan for the quality mag I write for, I use about 350dpi, that's all that's necessary. Also, always save as jpg files (you'll find there are options like BMP, TIF etc) because they are only tiny compared to the others. I got a pic via email the other week and it was 519k as a jpeg (which took long enough to download!), but I had to use it in a program which didn't recognise jpegs and converted to a Bitmap (BMP - you can do that in Paint in your Windows accessories) and it blew out to 25.6 megs... MEGS!
Enjoy yourself learning to use it...
Posted 01 July 2000 - 00:52
Gunner
Posted 01 July 2000 - 03:07
