Peugeot F1 Engine Photos
24 replies to this topic
#1 desmo
  • 32,164 posts
Posted 02 December 2003 - 05:24
Some pictures a friend sent that he took of the Peugeot F1 engine at their rebuild shop. Click on the images for high-resolution versions.
#2 Todd
Todd
  • 18,936 posts
Posted 02 December 2003 - 06:04
Look how short the stroke is. The photo with the finger in it really puts these engines' dimensions in perspective. No wonder they can live with such high crank speeds. Well, maybe not the Peugeots, but other F1 engines with similar bore and stroke ratios. ;)
#3 Halfwitt
Halfwitt
  • 576 posts
Posted 02 December 2003 - 07:52
I don't know how recent an engine this is, but they were using direct acting cams, rather than the finger follower types which seem to be the norm today, and butterfly throttles. Note the odd looking tappet bucket in the bottom right of the lowest picture with the domed ridge. Note also that the valves are the radial type.
I assume also that the green thing on the bottom of the tappet bucket is a seal for the pneumatic valve return. Is this correct?
#4 Wuzak
  • 9,083 posts
Posted 02 December 2003 - 12:00
Thanks desmo. :D
Do you know what the engines are being used for now???
#5 ZoRG
ZoRG
  • 198 posts
Posted 02 December 2003 - 12:53
I thought that they used a form of PTFE for the seals? Usually ptfe is white or black, never seen it in color.
Maybe they use something different.
#6 Jordan191
Jordan191
  • 7,264 posts
Posted 02 December 2003 - 15:53
Originally posted by Wuzak
Thanks desmo. :D
well they were asiatechs for awhile ..
#7 Wuzak
  • 9,083 posts
Posted 03 December 2003 - 00:05
I notice that part of the counterweights are bolted on.
Is this usual?
#8 ZoRG
ZoRG
  • 198 posts
Posted 03 December 2003 - 06:05
I notice that part of the counterweights are bolted on. Is this usual?
Yes, I've seen a Ferrari crank, looks exactly the same.
#9 J. Edlund
Posted 03 December 2003 - 15:33
Could it be so that they are using heavymetal counterweights, and they are therefore bolted onto the crankshaft? Heavy metal should be able to make the counterweights smaller. I've seen a picture on an older Ferrari F1 engine, it used heavy metal counterweights, but there they were in the form of solid cylinders that were probably pressed into the steel counterweight.
The green thing on the tappet bucket is probably the air spring seal. A guess is that the seal isn't PTFE, probably some sort of rubber or softer seal. PTFE is heat resistant and have low friction, that must be the reasons it's used as a seal at the valve stem. But this seal has probably a lower operational temperature so the material can be something else. Just a guess however.
Furthermore, the tappet bucket must be of some two piece design that allow a valve to be locked to it.
At the side of the intake runner it looks like some sort of plug, must be an air intake or outlet for the pneumatic springs.
The shaft and throttleplate in one piece was also an interresting design, all the throttleplates I've seen earlier have seemed to be more traditional shaft and plate screwed together.
#10 AndreasL
AndreasL
  • 19 posts
Posted 03 December 2003 - 17:22
The big version of picture 4 is not the same one as the small one. But one can still see that two distributors lie behind the camshafts.
Do F1 engines today still use distributors, or have they gone the way of street car engines to 1 coil per cylinder?
/Andreas
#11 ZoRG
ZoRG
  • 198 posts
Posted 03 December 2003 - 17:31
The reason for the crank weights might be manufacture related, ie oil ports, or could be for weight, if it was due to weight it could be argued that the heavier metals do the same job as bigger counters, however does not have the same arc, and thus does not increase by the same magnitude when spun at high rpm's.
As far as I know most cars run coil on plug and not distributor based systems, or maybe some sort of wasted spark type system to save a bit of weight.
#12 RDV
RDV
  • 6,765 posts
Posted 03 December 2003 - 17:50
All F1 engines running today are of the finger following type, this allows for better cam profiles, as a direct acting cam on a bucket will have problems of acceleration up cam cheeck , and tends to give severe wear and friction problems, plus needing very big buckets, thus increasing moving weight .
Domed ridge is a way of reducing cam cheek pressure, whilst giving high lift and duration... efectively cam profile can be softer as part of trajectory is controled by bucket(note cam profile cheek radius on end view). Downside is you must locate bucket to keep it in position (avoid rotating in bore)
Counterweights are of hi density material. Renault to my knowledge had used depleted uranium in some of its engines, but most have gone to tungsten now due to (percieved if not proved) health risk
#13 J. Edlund
Posted 03 December 2003 - 18:36
They use a coil on plug capacitor discharge ignition system, not that diffrent from the system that can be found in serial production Saabs, except that it has better performance and lower weight. It's completely controlled by the ECU without any mechanical parts. In TAG:s systems the capacitors are placed in the ECU and the cigar type coils direct on the plugs.
If you look at picture 2 you can see that it says A18 (possibly A16, it's difficult to see) on the carbon fibre cover. Peugeot A18 raced in 1999 I believe.
#14 ZoRG
ZoRG
  • 198 posts
Posted 03 December 2003 - 18:52
That bucket design is weird ... since it is just that bucket, I do not understand why it would need a seal, since it does not seem like it is able to attach to a valve to pull a valve up, It could also be designed like that(with a seal) to keep oil out the pneumatic system.
#15 J. Edlund
Posted 03 December 2003 - 20:16
It's probably made in two pieces, when they are separated the valve can be locked with something similar to a normal valve keeper.
If you take a look on this picture I think it will become clear: http://members.atlas...valvesystem.jpg
#16 ZoRG
ZoRG
  • 198 posts
Posted 04 December 2003 - 06:29
I suppose so ... however I do not see any provision for shims? Also the del west system looks completely different www.delwestusa.com any ideas?
#17 J. Edlund
Posted 04 December 2003 - 18:19
The system on Del Wests webpage is a system for finger followers, with direct acting cams the system looks a little diffrent.
It seems that there is a sort of shim above the valve stem and keeper which then come into contact with the upper part of the bucket. By using diffrent thickness of those we can adjust it, this will also give a lower weight than a traditional shim.
#18 MRC
MRC
  • 308 posts
Posted 06 December 2003 - 02:59
Fantastic pictures desmo. Best close up shot of the side of an engine that I've seen. I always like to see more of the ancilliaries. It appears from the offset of the water pump center and the oil pump shaft, and the casting shape, that they are using gear type oil pumps for the scavenge section on this motor. And it appears there are 3 scavege sections.
#19 Rainer Nyberg
Rainer Nyberg
  • 1,768 posts
Posted 07 December 2003 - 08:03
They actually never "rebuild" any F1 engines these days. Very few parts are recycled after a GP. All main parts goes into the scrap container. This compares well with the number of engines built per year for a team (80-100 engines).
The teams who are using previous years spec engines, does not have any rebuilt units. They are all brand new engines but built to the previous years spec.
However the new "longer-life" engines for 2004 and beyond will possibly change this again.
#20 ZoRG
ZoRG
  • 198 posts
Posted 08 December 2003 - 14:29
I still can't see any way for that bucket to attach to a valve?
#21 J. Edlund
Posted 08 December 2003 - 16:35
Look again and I think you will see it.
You pull the lower part of the bucket over the valve, place the keepers on the valvestem and move the lower part of the bucket upwards. Now the valve is locked to the bucket in one way. Place a lash cap on the valve stem above the keepers and the upper part of the bucket over that. As long there is an air pressure below the bucket and a camshaft above it will be locked in both directions.
#22 Greg Locock
  • 6,494 posts
Posted 08 December 2003 - 22:34
Great pics. I've never seen a V10 crank before, since I'm not interested in truck engines.
I wonder if they use bolt-on counterweights so that they can change the counterweighting on the fly? This might be necessary if the engine is run at different red lines, or they weren't too sure what the optimum would be when they tooled up.
Alternatively I like the idea of putting depleted uranium or whatever in them to give max counterweighting for minimum drag.
#23 J. Edlund
Posted 09 December 2003 - 20:40
They use no flywheel, the clutch is bolted directly on the crankshaft.
I also think that they use some sort of program in which they can simulate crankshaft dynamics, the weight of the counterweights and the complete crankshaft and conrods are in other words already known before they have even started the making of the parts. The only thing that will change the need of counterweighting is if diffrent con-rods are used.
#24 Greg Locock
  • 6,494 posts
Posted 09 December 2003 - 21:44
Oh, we use those programs as well. Nonetheless, if you really want to optimise the main bearing loads then a bit of fine tuning on the real hardware is no bad idea, especially given that they will be operating (I'm guessing) somewhere near the 1st bending mode, so real life damping will start to affect the responses.
#25 ZoRG
ZoRG
  • 198 posts
Posted 10 December 2003 - 17:45
Those engines still used a "limited" flywheel and ring-gear, I have heard that in the newer engine they actually weld on the flywheel.
