Thanks, Andrew!
Posted 16 May 2004 - 19:58
Posted 16 May 2004 - 20:45
Posted 16 May 2004 - 21:10
Posted 16 May 2004 - 21:19
Posted 16 May 2004 - 21:29
Posted 16 May 2004 - 21:53
Posted 16 May 2004 - 23:09
Posted 16 May 2004 - 23:18
Posted 17 May 2004 - 00:13
Posted 17 May 2004 - 03:21
Posted 17 May 2004 - 05:09
Posted 17 May 2004 - 17:06
Posted 19 May 2004 - 22:11
Originally posted by desmo
I wondered about the caged rollers as well. I wasn't sure if those were for the big ends or the mains- I assume the rod big end bearing. Odd choice, I thought plain bearings were universal there in F1.
[Edit] Upon further inspection, it appears the roller bearings (with split cages!) are for the mains. Strange. Note also the bolt on counterweights for the crank- compare these with the Ferrari crank with more material near the outer radius here and plug-type counterweights. Also note the April Fool's day ('02) date on the DelWest Ti intake valves!
Posted 19 May 2004 - 22:39
Posted 20 May 2004 - 00:03
Originally posted by Chevy II Nova
Thanks for the info Mr. Edlund. Can I ask how you came to know this?
Posted 20 May 2004 - 13:46
Posted 20 May 2004 - 17:00
Posted 21 May 2004 - 09:34
Posted 21 May 2004 - 19:40
Originally posted by hydra
Any idea how big the con-rod bolts are? (I'm guessing they're made of Aermet 100 or Maraging Steel)
Posted 21 May 2004 - 22:35
Posted 24 May 2004 - 04:55
Posted 24 May 2004 - 07:24
Sketch of split pin conrod journal of 90 degree block engine which show how much the overlap area would decrease at 18 degrees offset. Note how this should still stiffen the crankshaft even tho the area is smaller. I am begining to believe that the 90 degree blocks have this feature but is the exhaust note of an even plulse?
Posted 31 May 2004 - 21:43
