OT: Sound of Porsche air-cooled engines
Posted 02 June 2004 - 23:50
Posted 03 June 2004 - 05:40
Posted 03 June 2004 - 06:25
Posted 03 June 2004 - 09:16
The sound form a air cooled motor is more (Noiser or Ratter) because the piston firing is not dulled by a layer of water as in a water cooled motor and this tends to increase the overall Rat-tat-tat sound .This is at lower RPM however once the Revs go up who cares they sound just Great.
Posted 03 June 2004 - 13:08
Posted 03 June 2004 - 23:50
Originally posted by Yelnats
I can't say I noticed a drastic change in sound when motorcycles when from water to air cooling. Similarly when snowmobiles underwent the same changes.
There's quite a change now with the 996 engine though. Even with the water cooled heads there was a change. But the engine grew in both power and refinement. I also have a vague recollection from reading a book 20 years ago, that the fan back then was absorbing 30 kw or something huge like that. Fan technology has improved greatly with computer technologies, and such changes would have changed the sound as well as the air cooled engine gained in refinement. I've driven an old 911E lately, an early one, a good hot up car, and its sound really pleasant. They got a bit harsher as they got more powerfull, then they got more powerfull and got quieter. Also there was more insulation between the engine bay, and the body was quieter, different heating etc. The 90's ones were really very refined. My comments are based on being inside the car ...
Posted 04 June 2004 - 13:15
Originally posted by Melbourne Park
The WRX engine, a four cylinder, sounds really fantastic.
You will find that is more to do with the exhaust manifold configuration than the layout of the engine. Cylinders 1, 2 and 3,4 are paired up with inequal length pipes.
Posted 04 June 2004 - 14:19
Originally posted by zac510
You will find that (the XRX engine sound) is more to do with the exhaust manifold configuration than the layout of the engine. Cylinders 1, 2 and 3,4 are paired up with inequal length pipes.
But I've not known another 4 to sound like the WRX's engine. I should say, not the standard XRX engine, but ones that have been worked on a bit. Actually, I liked the sound of a Triumph TR4 (for some reason, nicer than the TR3s similar Fergerson tractor engine). But the WRX can sound almost like some kind of V8 ... I can't but help think the layout has something to do with it, at least the apportunity to tune the exhaust more easily is there with such a great IMO layout.
Posted 04 June 2004 - 16:29
Posted 05 June 2004 - 00:20
Posted 06 June 2004 - 23:51
Posted 08 June 2004 - 07:31
The WRX does sound quite unique and awesome and I've always assumed it was from the boxer configuration (I believe the 6-cylinder Subarus also make similar noises, though they're far less popular -- those with free flowing exhausts anyway).
But as for the comparison to a V8... you make it sound like a compliment that the WRX sounds like the supposed higher-end V8 but we all know the best V8s sound like inline 4s ;)
Posted 17 June 2004 - 15:00
The cyl banks can be paired up and installed into a collector like the Cosworth Flat Plane Cranks.
The street versions of the later type have a rather complicated Cat. sys. and the two outlets are routed to the opposite sides of the vehicle , hence the thump. On racing versions we bring the outlets together and produce a great racing sportscar sound.
Best regards
Posted 17 June 2004 - 18:29
The firing order for a flat four is 1-4-3-2 with 1 & 2 on the same side, right, and 3-4 on the other,
left, and only one firing order. Bosch.
Now the question is, how did they number the one that you are talking about?
If they numbered it like the 6 cylinder Corvair it would be 1 & 3 on the left and 2 & 4 on the right.
One must also remember that the Corvair is turning the wrong way, in relation to the output.
M.L. Anderson
EDIT; Subaru fires 4 cyl., 1R- 3R-2R-4R
Subaru fires 6 cyl., 1R-6L-3R-2L-5R-4L
Posted 18 June 2004 - 00:54
Originally posted by Randall Aase
The firing order for Porsche 6 cly Boxer Motors is 1 6 2 4 3 5 this wil allow the aspiration periods to complement one another for the 3 cly on the drivers side and the 3 on the passengers side.
The cly banks can be paired up and installed into a collector like the Cosworth Flat Plane Cranks.
Best regards
Originally posted by marion5drsn
M.L. Anderson
Strange that Subaru did not copy the firing order of the Porsche ... I wonder why not?
Posted 18 June 2004 - 19:44
The Porsche engine is in the front of the axle is it not? There fore it probably turns the “right way”, that is to the clockwise direction if you had to hand crank it (not possible”).
The Porsche is numbered to the DIN standard
right rear. # 4 is on the left in the front with 5 left, 6 left rear.
M.L. Anderson
Posted 21 June 2004 - 15:31
I forgot the original question was about old Porsche engines.
The 6 cyl firing order M.L. Anderson described is for a 914-6 middle motor.is
Mine is for a 911 where the engine is the closest thing to a rear end accident.
Cyl. 1 is furthest back drivers side and 6 furthest forward passenger.
This will allow a clockwise rotation and the Trans Rang gear is situated in relationship to the pinon to allow proper dirve to the dirve line.
Best regards
Posted 21 June 2004 - 16:31
Best regards
Any relation to the famous Porsche Aases?
Posted 21 June 2004 - 20:34
