What's wrong with Williams
Posted 06 July 2004 - 15:39
Posted 06 July 2004 - 15:56
Michelin are only good over one lap and go to crap.
Bad strategy decisions, especially from Sam Michael lately.
That's my view on it.
Posted 06 July 2004 - 16:13
1) New Nose (which I think is kool) has caused changes in other areas that they haven't dialed in yet.
2) Bad assumptions. They thought they had made a big enough jump towards Ferrari based on 2003 when in reality, Ferrari just had an off year. Then every1 else leap forwards & in some cases past Williams.
3) Michelin are inconsistent this year & is maginfied on the Williams new chassis which relates to #1 above.v Whereas, Bridgstones had an off year last year & seems back on pace this year.
4) Drivers are very indifferent towards team since they won't be both retained.
5) Sam Michaels, Patrick Head & Frank Williams have mistmanaged various sitations this year.
All in all, like anything else in life, the assumptions & choices we make will always be second guessed if things don't go according to plan...
Hopefully, this will be a watershed year for the turnaround next year!
Posted 06 July 2004 - 16:14
Posted 06 July 2004 - 16:15
Posted 06 July 2004 - 16:16
Posted 06 July 2004 - 16:22
Both are leaving and should have been replaced at the start of the season.
Posted 06 July 2004 - 16:43
I expect them, like I expect McLaren, to get back to their winning ways, because these two teams have proven they can do just that in the past. So far McLaren have deeply disappointed me on that count.
Posted 06 July 2004 - 16:48
Originally posted by pkrash
Drivers.
Spot on.
Nobody else has mentioned this. Frank should have let Montoya go as soon as the deal
with McLaren became a reality (what, late last summer?). There were other drivers that were
available last summer that could've stepped into Montoya's boots.
Regarding Ralf, it was clear last year that his performance was dropping off last year.
An infusion of hungry new drivers would've energized Williams for 2004.
Posted 06 July 2004 - 17:04
First and foremost are the drivers. monty is fast but his testing duties have been reduced. less seat time in the car is not good at this level.
Ralf has always been fast but lately with his big shunts will he be the same?
If they knew about Montoya leaving they should have released him immediatly. He's not getting any testing in I guess because of the secrecy concerning new developements on the car.
They are using test drivers on race weekends....sorry but Gene "might" be a decent tester but if he was a good racer he would already be on a team. And Pizzonia, who the hell knows.
You can't run a top F1 team using test drivers and expect any consistent showings or pace for that matter. And you can't limit your fastest driver to arive and drive on friday.
Now is Williams perfect chance to get someone in the damm car for next year. Someone who will test AND race THIS year.
I think the Williams car has the pace. They need someone fast and motivated to do the job for them.
Posted 06 July 2004 - 17:21
Posted 06 July 2004 - 17:22
Posted 06 July 2004 - 17:29
Posted 06 July 2004 - 17:32
Posted 06 July 2004 - 17:44
B) BMW, and more specifically Mario Thiessen and his people. They seem to be taking over the team. I suspect this is the reason why Patrick Head decided to avoid the race track and head back to the factory. I also sense conlfict over the management and selection of the drivers. BMW should focus on developing their engine and marketing and let Williams and Head run the team.
C) The car: handles poorly in the races, it needs work.
D) The drivers: Ralf has lost self-confidence (and his latest accident won't help him) and Montoya isn't putting in as much time testing, and he's overdriving the car.
Posted 06 July 2004 - 17:51
What are they? 5th best now? Sheesh.
Posted 06 July 2004 - 18:10
Patrick Head was at Magny-Cours on race day, despite the earlier statements. Whether or not there is conflict, this is a hint that Williams has lost its way. When that happens, it goes from top to bottom in a team.
Posted 06 July 2004 - 18:57
Perhaps Williams put a lot of effort in the initial development of the FW-26 and estimated that they would start the season with a substantial lead over the rest - they could then bring in improvements relatively gradually to keep them ahead. IIRC, they employed this kind of tactic in 1992 and 1997 in particular. I don't think this is a good explanation, though. More likely, the new concept of the FW-26 has confused the development team to the extent that they have not been able to come up with developments quick enough. If so, Williams should perhaps write off this season and use it as an extended test session to understand the new concepts in preparation for 2005. But that's when Mad Max's brand new rules kick in ;)
Posted 06 July 2004 - 19:25
we don´t even have a ms-rb fight.
williams stays behind renault and bar these days.
tyre gate and a big flop for the fw26 explains it.
05 will be the same or worst. unless there´s some surprise. new wind tunel, new drivers, new what?!
anyway the bet was strong at melbourne 04. it just didn't work this year. :/
Posted 06 July 2004 - 19:38
Head used to say that Willis ran the aerodynamics department like an "old cotton factory" or whatever, in a kind of derogatory way Head meant it, but I wonder if they shouldn't have kept that way after all.
Posted 06 July 2004 - 19:41
Mclaren had every reason to go radical because their design had pretty much stagnated. But they went overboard. Misjugdement.
Williams had no reason to go radical, they pulled one off in 2003 and almost had a forgettable first half until Monaco and they almost had the WDC. They could have worked on a evolution for 2004 before trying anything radical again. Williams had a pretty good advantage toward the end of the season. The new car partly responsible for performance of the Michelins this season ???
Just my opinion... as good/bad as any.
Posted 06 July 2004 - 19:42
Posted 06 July 2004 - 19:53
Originally posted by vivian
One word: Walrus and the twin keel.
Just my opinion... as good/bad as any.![]()
100% agree Williams had no reason to go radical. They should had continue to develop their 2003 car.
Posted 06 July 2004 - 19:55
Please don't flame me these are my ideas not a discussion point
Posted 06 July 2004 - 20:01
They had a proven design for last year. It may not have been the best, but it was OK at least. Would it have been possible to keep an evolution of last years nose kicking around if needed? I know they couldn't switch it quickly, but they've obviously been working on the walrus for quite a while. If its a turd, quit trying to polish it and move on.
Posted 06 July 2004 - 20:15
The problem seems to be one that McLaren has and that BAR seems to have addressed this year - the gap between engine manufacturers and the aero team. Whether it's a lack of coordination or poor communication. It's no accident that Ferrari and Renault are the two top teams.
BARnone.
Posted 06 July 2004 - 20:26
Originally posted by Zeus
Tiregate is a lousy excuse. Williams' relative performance has worsened since the start of the season.
indeed, they shine at susuka.
Posted 06 July 2004 - 20:29
Posted 06 July 2004 - 20:43
They should have continued with a -25 evo...but what do i know anyways... :
Posted 06 July 2004 - 21:26
Posted 06 July 2004 - 21:31
Originally posted by Vilenova
Alot of things are wrong at Williams. :
That's why Vilenova, sorry Villeneuve is already on a team, isn't it?
Posted 06 July 2004 - 21:43
Williams should have made an evolution of their design instead of this walrus type thing they have now. If Williams are smart, then they will stick to this design (albeit perfect it by the end of 2004) and then hone it even further over the winter thus creating something familiar for the guys to work with. I'm willing to bet £100 that the F2005 Ferrari looks 95% similiar to the F2004 model. Why? Because continuation and familiarity brings success eventually. Williams need to copy the Ferrari ethic in regards to design and continuation. Mclaren managed it and were very succesful with the 17B.
Posted 06 July 2004 - 22:15
So they went for an all new design. The FW26 was immediately quicker than FW25 when launched. But Ralf quickly commented that even during winter testing they had been unable to improve from the initial base. That seems to be the continuing trend. All the other teams have improved faster than Williams, and Ralf and (particularly) JPM have been complaining about that all season.
BMW have lost their power advantage but most teams seem to agree that the power differential between the top five engines is very small. The performance differences are coming from aero, chassis and tyres.
Regarding the drivers - JPM has shown excellent commitment this seaosn despite his impending departure. Ralf has (unsuprisiningly) had a lucklustre season except for Canada. Another driver may have scored a few more points, butthe pace of the car has obviously been down and changing driviers wouldn't have fixed that.
I expect they'll go better at Silverstone.
Posted 06 July 2004 - 22:17
Where did you learn to count?;)Originally posted by vivian
Posted 06 July 2004 - 22:25
By the way, according to Patrick Head, the FW-26 wasn't/isn't radical - just a logical development of the FW-25. I remember reading one of Craig Scarborough's articles to that effect too.Originally posted by vivian
Posted 06 July 2004 - 23:05
Gene who does the tests said after the french gp he needed more speed.
He would be ideally placed to say that because in a race situation you compare yourself the the person in front performace wise.
Posted 07 July 2004 - 00:20
Radical may be the wrong word according to Head but changing from single keel to twin keel is not radical enough?
Wind tunnel results proved that its better than the FW25 but how could they underestimate the extra weight that would result? Thats a gross error from Williams.
The F2004 is similar externally (to the F2003 and F2002) but internally, it must have changed a lot. Suspension geometry, chassis, gearbox... . Its easier to bring updates to the aerodynamic components, track specific changes, gains are few compared to the gains made by better tyres, a lighter chassis, lighter gearbox, better mechanical grip from new suspension geometry and chassis made in winter.
FW25 was strong at the core, they brought about some changes to the suspension before Monaco last year, and it worked wonders.
Williams lost big time due to the weight of the twin keel and whatever aerodynamic gains they made on the FW25 is compromised.
The weight of the twin keel is the biggest factor. Not aerodynamics or anything else. And that has not been addressed or can't be changed easily. So whatever aero changes they bring about is not helping them much.
I might be wrong.
Posted 07 July 2004 - 00:33
Explain the FW25 then.Originally posted by Ghostrider
Williams seems to have gone downhill since Willis left, and after having seen what he has done with BAR, I can see why.
Posted 07 July 2004 - 00:34
Willis had already drawn it but forgot to take the drawings with him to BAR?
Posted 07 July 2004 - 00:43
I cant for the life of me imagine why Williams choose to share their pit to car radio conversations with the media?Isnt that private stuff. Other teams seem to hide intra team conflicts well . And what s with chastising Ralf and Montoya in the press by Patrick Head ? Only Williams' rivals gain from this. Williams always lose a race before the cars hit the track.
Posted 07 July 2004 - 00:54
Willis had already drawn it but forgot to take the drawings with him to BAR?![]()
Willis went on "gardening leave" half way through the design of the FW25.
Posted 07 July 2004 - 01:03
Originally posted by ChessNH
I'm getting sick of JV getting a drive in everything, Toyota, BMW, JAG, or Renault he had one good year with Williams and had a perfect car, moved to BAR and can't develop car while getting massive payment and he is gone, he sucked end of story.Please don't flame me these are my ideas not a discussion point
Posted 07 July 2004 - 06:46
A lot is already stated by other posters but in combination:
Starting the 4th seaon in a row with two drivers with hardly, if any respect for one and another. And even worse: starting the 4th season together after their frustration of knowing they missed a golde opportunity to win the titles last year. Then, both drivers ain't happy with the team anymore since both feel that the other is favored over themselves. One of them already signed a contract to leave after 2004 with another team.
Then: One driver hardly talks with one of the highest ranked engineer.
Then: Changes within the leadership when longtime supremo "Head" wants to take a backseat and the replacement not being there yet if it comes to leadership of the entire team.
Add to that a car with a rather radical concept within its design.
On top of that: instead of being competive inmediately and continuing the the way up that started last year they are beaten devastatingly by Ferrari yet again instantly, what surely must have done wonders for the motivation of both drivers who already were more focussed on themselves and their wages already in additions to their worries that the other is favored yet again.
Henri Greuter
#44
Posted 07 July 2004 - 07:03
Hrvoje
#45
Posted 07 July 2004 - 13:48
Originally posted by Vrba
As in every company, the answer is very simple: those with most responsibility and competence are to be blamed - it's the management and nobody else.
Hrvoje
Well said: the success & failure of any organization begins @ the top.
#46
Posted 07 July 2004 - 18:17
My understanding is that everyone is unscrambled now, since the team orders ban.
