Engine Technical Specifications
Posted 04 August 2004 - 21:16
Posted 05 August 2004 - 07:29
If you do a quick search in the forum, you'll get a lot of numbers, from which you can choose the correct ones...Originally posted by Helterkskelter
[colour=red][b] Does anyone out there know the technical spec of a Formula 1 engine. e.g acceleration, top speed and deceleration rate of the car????? [b][colour]
Posted 08 August 2004 - 14:12
Posted 08 August 2004 - 15:19
Posted 08 August 2004 - 16:22
Why thanks thas so much help!!!!![]()
Common courtesy to search a BB before asking a question. Don't get upset when someone suggests you do it, you won't last long otherwise.
Ben
Posted 08 August 2004 - 21:38
Posted 08 August 2004 - 21:59
3.0 V10 engine
top teams have engines that can rev upwards of 18,000RPM (i think the BMW does 19,000 but not sure)
top speed, well that depends, but all cars are closely matched these days in a straight line, its through the twisty bits that the time is made up these days
Deceleration, well if a driver lifts off the loud pedel it can generate upto 1.0G in a straight line and upto 1.5G in a bend (lifting off that is)
Top speeds, Monza - 90% of the cars capable of 220mph upwards (even the minardi's) but like i said, the time these days is made up in the slow bits (ie the corners)
Posted 10 August 2004 - 05:26
Top speed recently was by Montoya at Monza, wasn't it. Just go to Monza last year in the Atlas archive and get the top trap speed. Course, with constant tech reg tweaking, this change readily. Put slicks on the car and they'll do just about everything quicker.
Posted 10 August 2004 - 05:33
Posted 10 August 2004 - 11:55
Originally posted by Lukin
I expect them to to 0-100-0 (in km/h) in 2 seconds or there abouts. I read that the cars can do 0-100 in 1.2 seconds and can decellerate much quicker than that so I would expect a time under 2 seconds for them.
Nah 1.2 seconds is ridiculous man, that is quite literally against the law of physics for these cars. a Jet fighter does 0-100kph in 1 second with many thousands of pounds of thrust. An F1 car does 0-100 (60mph) a tenth or two quicker than a superbike, so in around 2.1seconds (i dont see them breaking the 2 second barrier to be honest). 0-100mph (160kph) and back to zero is done in a mind boggling 4 seconds!!!!
Posted 10 August 2004 - 12:02
0-100kmh is about 2.35G - unlikely.
Ben
Posted 10 August 2004 - 12:25
Posted 10 August 2004 - 12:35
Now I think of it, there was an article with JPM and Sete Gibernau comparing their paces and lap times.
Posted 10 August 2004 - 12:46
Perhaps when slung from an aircraft carrier with a catapult, but not on engine thrust alone.
Posted 11 August 2004 - 13:39
approximately 5.5 seconds. Deceleration to stop is much less.
Ron Sparks
Posted 11 August 2004 - 15:39
Montoya says 2.5 seconds 0-100 km/h. So I think they would do 0-100-0 in 3.5 seconds or there abouts?
Posted 13 August 2004 - 19:34
http://f1.racing-liv...508040953.shtml
Acceleration at low speeds (below 150 km/h or at some low speed tracks slightly lower) are grip limited, so if the car goes to 100 km/h in 2.5 seconds, you should expect 0-100-0 km/h to take around the double time, that's around 5 seconds.
But it should also be noted that the carbon-carbon brakes need tp be warm to offer their best performance.
Performance according to the book Ferrari Formula One
0-100 km/h: 2.8 s
1/4 mile: 8.8 s / 297 km/h
Fuel consumption: 63-72 litres/100 km
They don't quote any braking figures for 100-0 km/h as there is no point doing that, maximum brake performance is however 4.4 g, of which 1 g is caused by aerodynamic drag. Today the braking is probably over 5 g. This allows the driver to drop about 100 km/h in just one second, but this is only at high speed.
Renault for example have a little more weight on the rear, about 60 percent instead of less than 55 which other teams use. This can be one reason of why they are so fast away from the start line.
Posted 13 August 2004 - 20:34
Posted 05 September 2004 - 00:59
On of the fastest horizontal accelerations is the launch from a carrier, a 20 ton F14 can be airborne in 2sec.! It has to go faster than 200 km/h! The pilot nearly passes out every time. It might not be spectacular in G's but is't pure force in contrary to not-kinetic accelerations like free falls, hits,... I don't think that the jet-engine can blow that strong in the air (+200 km/h in 2 sec.)!
