Focus on PROST AP04 with Technical drawings
16 replies to this topic
#1 MODE
MODE
  • 306 posts
Posted 12 March 2005 - 11:02
Focus on PROST AP04 with original technical drawings, here : http://www.gurneyfla...p04photost.html
#2 Earthling
Earthling
  • 3,645 posts
Posted 12 March 2005 - 11:52
Nice, although i have got pics of the unraced AP05 in the windtunnel being developed, from another fellow Atlas member over 2 years ago.
#3 ZE.FT
ZE.FT
  • 31 posts
Posted 13 March 2005 - 06:55
Thank you MODE.Although I visit gurneyflap fm time to time, I had missed that one.I hope also
these guys keep up the good work.
Earthlink,thank you too.
#4 MODE
MODE
  • 306 posts
Posted 14 March 2005 - 18:10
I just added more technical drawings,, that's always here :
Enjoy !
#5 desmo
  • 32,179 posts
Posted 14 March 2005 - 19:32
Absolutely great stuff there MODE! :clap:
Some higher resolution versions would be a wonderful addition, if I run them through a photo editor and play with them I can almost make out some of the finer print. If you don't have sufficient server space, feel free to email them to me at haxixe@gmail.com and I can then post links to them.
#6 Sir Frank
Sir Frank
  • 4,275 posts
Posted 17 March 2005 - 11:51
Wow! :up: Gearbox weighs 45kg rather heavy :)
#7 MODE
MODE
  • 306 posts
Posted 19 March 2005 - 14:14
As you like these technical drawings, I added 6 other ones today, still here :
#8 shaun979
shaun979
  • 417 posts
Posted 19 March 2005 - 21:00
I was looking at the Ferrari 049 data, calculating valve area to bore area, and intake to exhaust valve area ratios. Are my numbers off?
Total bore area is approx. 7235 mm^2
Total int. valve area is approx. 2563 mm^2
Total exh. valve area is approx. 1710 mm^2
Total valve area is approx. 4272mm^2
Total exh. valve area is about 40% of total valve area
Total valve area to bore area is about 59%
Isn't this a little low? I mean just looking at 4V racing heads, the bore area LOOKS much filled up with valve area (at least a lot more than 60%) . Is this optical illusion?
[MODE: Sorry for the delay. I just emailed you the engine pictures as promised.]
#9 Antoine
Antoine
  • 92 posts
Posted 21 March 2005 - 10:08
MODE do you know from where come these plan? who is "ingénieurs de course" (this mention is on all the drawing)? Is it an internal mention for PGP or add after the end of PGP?
#10 MODE
MODE
  • 306 posts
Posted 21 March 2005 - 20:09
Auction in Paris at the death of the team. Ingenieurs de course could mean "for the race team". Don't know if it was added.
#11 dolomite
dolomite
  • 1,200 posts
Posted 21 March 2005 - 21:06
Ingenieurs de course = Race Engineers
#12 Antoine
Antoine
  • 92 posts
Posted 22 March 2005 - 12:37
Thank you, very interesting drawing!
#13 Engineguy
Engineguy
  • 989 posts
Posted 22 March 2005 - 14:18
58 or 59% is consistant with the racing 4-valve engines I have info on. Can't get more than that without going to kidney bean shaped valves :drunk:
#14 indigoid
indigoid
  • 384 posts
Posted 25 March 2005 - 13:29
now there's an interesting idea. have you heard of anyone trying it? could get awfully messy if the valves spun themselves around even a little bit :)
#15 MODE
MODE
  • 306 posts
Posted 05 November 2008 - 14:49
Hello, it's a long time ;) I put the original drawings of the PROST AP04 to download, not for free, these are very high resolution copies. I have also Packs of Photos for iconic cars, MATRA MS120, FERRARI F2004..... That's here, thanks :
http://www.gurneyfla...m/download.html
#16 Greg Locock
  • 6,494 posts
Posted 05 November 2008 - 21:01
"could get awfully messy if the valves spun themselves around even a little bit"
Well, that's probably why no-one tried it. If your valves don't spin then they stop working rather quickly. Hmm, I wonder if they'd last one or two races ?
#17 cheapracer
Posted 06 November 2008 - 06:44
Isn't this a little low? I mean just looking at 4V racing heads, the bore area LOOKS much filled up with valve area (at least a lot more than 60%) . ]
The air needs room to come in too you know!
