AERO SETUP FOR MAXIMUM SPEED!
Posted 11 July 2005 - 15:59
This is my first time to post at this forum.
I have a big questions regarding aero setting for top speed in a F3 car.
Let´s put in this words: I do not care at all about handling, just care about top speed.
I tried many different combinations: (ride heights at the end of straight)
1.- Rear higher than Front (that logically gave the worst results).
2.- Rear lower than Front , but ride height quite low (Rear around 12mm, Front around 16mm).
3.- Same as before but higher (Rear 18mm, Front 22 mm).
Combination 3 was the one that expect to get more speed, but 2 was better, I expected that leting the air flowing more freely under the car will reduce the drag.
All the time was same wing settings.
Does anyone has an opinion about this?
Thanks a lot and wonderful site.
Pace for everyone in this world!!
Dolsum
Posted 12 July 2005 - 06:55
Dolsum
Posted 12 July 2005 - 07:01
Posted 12 July 2005 - 07:02
Originally posted by Dolsum
Hello all!
Dolsum
Why do you only care about top speed and not handling?
Ben
Posted 12 July 2005 - 07:25
Posted 12 July 2005 - 09:31
BAR-Honda is to send a car to the Bonneville Salt Flats in Utah in October to see what the top speed of an F1 car can be in an out-and-out burst of speed. The BAR-Honda 007 is expected to be driven by James Rossiter and will probably feature no wings and perhaps a cockpit canopy. The car will also be fitted with a rear parachute to slow it down after the run, which are being staged as a promotion for Lucky Strike.
Interesting - Will the car be able to put the power down to the ground? I don't expect this to be much more than a publicity stunt as the thing that strikes most people about a modern day F1 car is it's cornering and braking...
Posted 12 July 2005 - 12:06
Generally, the lower the ride height, front or rear - the lower the drag, and the highter is the top speed.Originally posted by Dolsum
If the car does not handle well in a turn, the driver may tend to do through the turn slower but he will start accelerating sooner. The top speeds will increase.
The higher top speed does not have much correlation with lower lap times. Actually, on tight handling courses the correlation is exactly opposite.
Philip
Posted 12 July 2005 - 12:26
Handling was not a problem, actually was quite good and cornering speed was ok, so exit also was ok, but the car start to loose speed after 200 km/h (top speed around 260, Monza). Circuits like this, top speed turn to be more important (talking about F3 cars), of course that you have to have the balance in cornering speed so your exit specially is good to get a god top speed, for example PARABOLICA is a typical corner where some drivers (unexperienced) try to keep a lot of speed (with the coming US situation), so they screw up totally the exit and at the end of the main straight they are 10-15 km/h down.
I was thinking that higher the car less drag, lower more downforce.
Great forum!
Dolsum
Posted 12 July 2005 - 12:52
Combination 3 lets airflow pass more freely ,true.
It allows, infact, more high pressure air from the sides to pass in the low pressure area that the underbody and diffuser are trying to produce.
This produces bigger vortexes than in situation 2.
Vortexes consume (lots of ) energy.
That's where your horsepower went.
Drag is not necessarily related to downforce. If you had sideskirts, you would have a lot of downforce, since very littlle high pressure air would spill to the underbody, and very little drag, for the same reason.
Posted 12 July 2005 - 18:08
Zero toe, higher tire pressures, no wings, close off the air to the radiator as much as possible (without overheating the engine!), close off brake ducts (be careful when you stop!).
Posted 12 July 2005 - 20:21
Posted 13 July 2005 - 16:20
I will try some of your ideas this weekend, and I will tell you after how was it.
Thanks a lot.
Till next time!
Dolsum
Posted 13 July 2005 - 16:39
wing setups for the various wing configorations i.e mainplane.
What sort of engine are you running and how is your gearing?
What topspeed do you wish to achieve and at which track?
Posted 20 July 2005 - 13:33
Posted 20 July 2005 - 16:11
Dave
Posted 26 July 2005 - 23:42
I found this story from 3 sources, but unfortunately none of them can be considered fully reliable.
Posted 28 July 2005 - 15:30
Dallara manual is good, but does not give you really parameters to setup the car for max speed. Because the series where the car race are open for another car manufacture, the info is very restricted, for example they do not give you any aero data from wind tunnel testing, however they do in supernissan because is one make series or GP2.
They put in the manual diferent configurations (flaps, etc) but not info about ride height, so you have to find it by yourself!. Here is a point where teams with high budget can go to wind tunnel test and/or straight line tests or even better to a proper test track for aero test like IDIADA in Spain.
Also, I think is important to know when the car start to be stall (I think that is the english term when the wings doen not create anymore down force and no more drag), so you can put the car in this condition in straight line so you win speed. There is directely related to the RH of the car.
See you soon.
Dolsum
Posted 29 July 2005 - 17:12
For the ride height it's what you said!
but it's difficult to see the result without a pitot!
good luck,
i suppose it was for the Norisring?
Posted 29 July 2005 - 17:13
do you look at the british F3 at monza?
Posted 29 July 2005 - 21:51
Sorry, a pitot? Pilot?
Posted 30 July 2005 - 10:00
Posted 09 August 2005 - 17:15
Yes I was looking at MONZA and Norisring as well. But after lask weekend at Nürburgring, I found out that (what was already written in one of the post) having a MERCEDES engine make life much much easier!. I do not have any doubt of Hamilton skills, but I would like to see him driving the same car with another engine, let´s say a TOYOTA for example. Sure is in top 10, not so sure about top 5 and certainly not sure about top 3.
Also, HWA brings to all MERCEDES team a set of "special" parts develop by themselve at wind tunnel. Last year also different suspension geometry as well. So make life more complicate to those that do not run MERCEDES. I hope it will change soon, or F3 is in troubles..
Regards
Dolsum
Posted 09 August 2005 - 17:29
Posted 09 August 2005 - 19:26
In my opinion there's between 0.6 to 0.8s:lap between an Opel and a Mercedes!
It's very significant on racetrack, this différence is less in urban track or on wet track!
For hamilton still leader of the championship without a Mercedes but he couldn't win so many race!
I hope that one day someone will demonstrate the différence between the engine, because guys like Perera, Duval, Rossiter, van der garde and so one are very good driver too.
Imagine at the Nurburgring is the mercedes was 0.7s slower in qualify 1 their will be these gap:
Di Grassi 23.709
Hamilton 23.815
Di resta 23.834
Bonanomi 23.949
Perera 23.965
Franchi 24.006
Moreau 24.029
VDG 24.082
Vettel 24.161
Duval 24.186
Rossiter 24.209
Guerrieri 24.348
Watts 24.398
Sutil 24.408
Hirate 24.443
Nunez 24.668
Abreu 24.745
Carbone 24.881
Neuhauser 24.93
Salaquarda 25.056
Holzer 25.176
Jelley 25.377
Kuhn 26.376
For second qualify:
Di resta 23.163
Di Grassi 23.275
Hamilton 23.338
Hirate 23.387
VDG 23.391
Duval 23.519
Rossiter 23.554
Franchi 23.593
Moreau 23.663
Perera 23.665
Nunez 23.673
Guerrieri 23.851
Sutil 23.858
Neuhauser 23.858
Bonanomi 23.918
Carbone 23.975
Watts 23.977
Holzer 24.035
Jelley 24.165
Abreu 24.544
Salaquarda 24.578
Vettel 24.733
Kuhn 26.299
It will be a lot more exiting!
Posted 10 August 2005 - 20:08
The Merc engine is a thoroughbred race engine specifically with F3 in mind,it being at least 15kg lighter than the Opel,and thats a lot of ballast that can be spread out around the bottom of the car.
Unfortunately reducing wing does not let us pick up top speed to make a noticable difference on the straights.
Nürburgring was particularly bad as there was a lot of understeer in the first section which necessitated a rather large amount of front wing to help combat this.The big drawback was a speed loss on the run down to the chicane.
Posted 10 August 2005 - 21:03
Even if you considere that Hamilton is a super star, and you compare the time of the second Mercedes or the third Mercedes with the second or the third opel, it will be the same gap!
Sorry for the Opel, hope it will rain for the 3 last event!!!
Posted 10 August 2005 - 21:42
Posted 11 August 2005 - 06:46
Posted 11 August 2005 - 07:40
If you look at Nurburgring, it was Manor on the front row, but ASM win the 2 races
At Monaco, Manor was nowhere, why? like at Pau and so one!
and di resta made some good one too
but it's like that ASM is strong, and noone with a Mercedes is as strong! if you are but with an Opel you still 0.7s behind!
Hirate make 2 very good race, for sure! and we all hope for a crash in the first corner and for two first row
Posted 11 August 2005 - 12:59
Here's some info, from a local source, it seems Alan van de Merwe is driving & the actual speed attempt will be in October
http://tinyurl.com/8vomt
Posted 14 August 2005 - 11:30
I agree that Mercedes engines are faster, I do not know if 0,6 - 0,8 sec a lap, just faster.
Another interesting point at Nürburgring was that an unknown driver like Neuhauser, qualify 5th and finished 4th (of course Merc engines), so the question is: If he was able to be there, lapping very similar times like Sutil for example, then even if you are a meddium level driver, you look like a really good one just because you have the money-contact-etc to have a Merc engine?
But this is racing, and if Mercedes did a really good job in last years, investing a lot of money and time, is logical that they reach such a high level so quick, I hope Spiess can make an step..
Regards
Dolsum
Posted 14 August 2005 - 11:59
Neuhauser obviously benefitted from the qualifying engine mapping but was slow throughout the first section of the track and could only catch Hirate on the straight sections.
Hirate was setup to use a lot of downforce to get him through the first section but lacked top speed on the run down to the chicane.
Neuhauser was not able to catch up at all and the gap remained constant throughout the race.
Posted 15 August 2005 - 13:41
Dave
