Posted 09 December 2005 - 08:18
Posted 09 December 2005 - 13:41
Posted 09 December 2005 - 18:11
Posted 09 December 2005 - 18:31
Posted 09 December 2005 - 22:39
Detonation a non-concern?? Really?
Posted 10 December 2005 - 03:22
Originally posted by bobqzzi
F1 compression ratios are low because of the geometry of the combustion chamber. Given that the bore is very large in comparicos to the stroke, it is hard to get much compression without a large dome- which you can't use if you hope to have camshafts that give proper valve timing for 19,000rpm. In actuallity the cumbustion space ends up being the valve reliefs. I'm guessing compression is somewhere around 11:1
Posted 10 December 2005 - 22:41
Posted 11 December 2005 - 01:12
Originally posted by m9a3r5i7o2n
The reverse flow cooling is old stuff, the 1955 Pontiac had it in 1955. That was the first year of the Pontiac 287.5 cubic inch V-8. The only requirement seems to be a tube, similar to the one in old straight sixes and eight “L heads” that directed the flow more evenly to the exhaust valve seats. Just who was the first I don’t have any idea but my guess is that it was much older than that. M.L. Anderson
Posted 11 December 2005 - 01:28
Originally posted by phantom II
Incidently, my 06,C6, Z06 gets 24mpg in town and 31 on the highway with US gallons. Long live push rods.
Posted 11 December 2005 - 01:59
Originally posted by desmo
It seems a bit like a dirty little secret that pushrod engines still make perfect sense in many respects for roadcars where peak specific outputs are essentially irrelevant. Not that you can't get eyebrow raising specific outputs from them either. They have distinct advantages in terms of mass, complication and packaging, particularly for V engines.
Posted 11 December 2005 - 08:33
All small block Chevys since the second 92 LT1 (first 1970) have been reversr flow. From the L98 to the LT1. Most of the 50hp gain beteen 91 and 92 when the change occured was because of this. They also have a high volume gear driven water pump with two inlets and two otlets. The new LS1 all aluminum versions cylinder heads water temp runs around 80'f and the block water temp will go as high as 260. Incidently, my 06,C6, Z06 gets 24mpg in town and 31 on the highway with US gallons. Long live push rods.
Posted 11 December 2005 - 13:28
Posted 11 December 2005 - 13:35
Posted 11 December 2005 - 15:09
Originally posted by hydra
While the LT1 had reverse-cooling, GM engineers reverted to conventional cooling for the LS1... Not sure about the LS2 but I'd bet it hasn't changed in that respect...
Posted 11 December 2005 - 15:21
[ To change the subject a little, Gordon Murray has joined the staff at Road&Track and his first article in the latest issue is a technical and aerodynamic analysis of the Bugatti Veyron 16.4. He berates it if you read between the lines and plugs his own F1. Great story and drawings
[/B]
Posted 11 December 2005 - 17:46
Hydra:
That's my understanding also, based on what my friend said about his LS1 Camaro.
Posted 11 December 2005 - 18:15
Posted 11 December 2005 - 18:38
Originally posted by zac510
I read that, but in the UK Top Gear magazine. R&T must use articles from it?
Posted 11 December 2005 - 19:13
Posted by phantom II
I read the R&T article by GM about the Bugatti and had the same feeling, that GM expressed sour grapes. I also re-read R&T's road test of the McLaren F-1. It over heated on them three or four times. Also the air conditioner could not keep the interior cool. The test was done in Arizona in the summer. GM does not mention the acceleration ability of the Bugatti compared to his F-1, either. WPTPosted by phantom II
In keeping with the title of this thread, Murray also discusses cooling considerations....
Posted 11 December 2005 - 20:52
Posted 11 December 2005 - 21:10
Posted 14 December 2005 - 00:34
Posted 16 December 2005 - 16:10
Originally posted by Freebird
Phantom II:
LT4, 396 CID Camaro here. Not as light as your your bullet, but I'm able to squeeze 525 out of it.
One other thing that I have noticed with regards to reverse cooling. As the ambient temp drops, my car seems to "pick up" power significantly better than other cars I've driven.
msw
Posted 16 December 2005 - 16:43
Bolt the engine to the gearbox like God intended.
Posted 16 December 2005 - 16:46
Originally posted by McGuire
...and once again demonstrating that there is more to engine development than hp, should we wish to open that can of worms again.
Posted 16 December 2005 - 17:23
Posted 16 December 2005 - 19:28
In racing too. For example in the Rolex Series Daytona Prototypes...here all the engines are regulated to 500 bhp, so the advantage goes to the engine with the broadest torque curve. Since the Gen III GM has the largest displacement, it has a leg up on everyone else in this regard.
...and once again demonstrating that there is more to engine development than hp, should we wish to open that can of worms again.![]()
The other advantage of the pushrod V8 is its signifcantly smaller package dimensions and lower CG over the DOHC V8's from Lexus, BMW and Ford. If you look at the back end of a Riley chassis powered by Pontiac vs. one powered by a Lexus etc, it's pretty obvious. So in this series, based on production engines, the GM pushrod V8 is currently the engine to beat.
Posted 17 December 2005 - 15:12
Originally posted by NTSOS
phantom,
That's interesting, so not having a transaxle combo for my '56 is not all that bad after all.....at least for a slalom course I guess.
Does your Z06 launch like this one? I see more 06 Z06 videos with horrendous launches and then the car recovers quite easily and manages a fairly spectacular et/mph. The LS7 seems to have a wide power band and relatively good gas mileage......$14k for a crate motor.
Z06 Lauch
John
Althea's Garage
Posted 17 December 2005 - 16:22
Originally posted by Fat Boy
Check me if I'm wrong here, but don't the BMW and Ford also run as 5 liter engines? No arguement that the pushrod engine is a smaller package than the OHC engines, but in terms of output (power or torque, if we're talking the same rev ranges, then the point is a semantic), why would a pushrod engine have an advantage on a OHC engine of the same displacement?
I believe the Ford has been called the most powerful and most fuel efficient engine of the lot. Getting that engine with the right chassis/driver/team combination has, so far, not happened. I think they will have good combinations with a couple cars in 2006, though. It will be interesting to see what combination comes out on top.
Posted 17 December 2005 - 16:26
Posted 17 December 2005 - 20:34
Originally posted by knighty
which way does the coolant flow through an F1 engine?.........from the heads to the block.........or the block to the head?..........the conventional way for production engines is block to head........but I have heard that some bike engine tuners reverse the flow in order to keep the combustion chamber cooler, and therefore reduce the det limit.........I'm interested to hear what you guys know![]()
Posted 17 December 2005 - 22:19
Posted 17 December 2005 - 22:42
Yes, and Chrysler used the same principle in their engine for midget OW, didn't they? 155 inches versus whatever the Fords and others have. This may be one of the reasons that Ford went to their Focus series. M.L. Anderson
Posted 18 December 2005 - 21:05
Deuce,
Thanks so much for the various launch scenario's.........Martha Stewart says that low 11's will be a good thing!![]()
The chassis is a bare Newman conversion and the headers are not mine and I agree about the blonde, I certainly never had a teacher that looked like that.
The chassis is in for powder coat as we speak and then I can start to assemble it.
I just love the new Z06! Whilst we have you here, please tell me all about the PBR brakes. I was going to go with a set of Movit's but they want around $7000 for a complete bolt on setup for my C4 pieces and parts.
I noticed we can get the PBR calipers for around $175 each and I can machine the adaptors myself and Precision Brake is coming out with a set of 2 piece rotors. I think eventually the difference in price between the Movit's and the Z06 setup will equal a lot of extra Budweiser.![]()
John
Posted 19 December 2005 - 17:56
My roadster is a exercise in simplicity and purity.
Posted 19 December 2005 - 22:59
phantom,
Forget about my brakes for a moment.........would you mind pulling the camera out a bit on your 1750 lbs hot rod?![]()
John
