Oval-Piston diesel Engine (serach photos)
14 replies to this topic
#1 Speedman
Speedman
  • 63 posts
Posted 16 December 2005 - 22:41
Hello
I search photos from a VW oval piston diesel- engine
This was a prototype-Engine in the 80th years.
The photos was in the magazine "Auto, Motor und Sport" in the 80er years.
This piston is not to compare with Honda-oval-piston
best regards
Speedman
#2 perfectelise
perfectelise
  • 244 posts
Posted 17 December 2005 - 12:19
"1990 VW 2.3L diesel 4-cylinder engine with oval pistons: exterior view and engine block comparison with the standard 1.6L unit." http://www.ibiblio.org/tkan/audi/
#3 rhm
rhm
  • 990 posts
Posted 17 December 2005 - 14:38
What was the idea, just to increase displacement without lengthening the engine?
#4 Speedman
Speedman
  • 63 posts
Posted 18 December 2005 - 13:38
Thanks for the pictures.
best regards
Speedman
#5 McGuire
Posted 18 December 2005 - 13:40
exactly.
#6 Fortymark
Fortymark
  • 6,022 posts
Posted 18 December 2005 - 17:33
Originally posted by McGuire
exactly.
Why ain“t nobody using it? Like in a Porsche boxer engine?
Too expensive? Or are there other disvantages?
#7 Speedman
Speedman
  • 63 posts
Posted 19 December 2005 - 12:01
Oval cylinder/piston is very expensiv.
You can make this parts only special machines.
#8 Terry Walker
Terry Walker
  • 3,005 posts
Posted 02 January 2006 - 09:04
There was a burst of interest in oval pistons in the motorcycle gp world a few years back. In practice, I recall, the advantages weren't quite there.
#9 Wuzak
  • 9,084 posts
Posted 02 January 2006 - 11:29
The oval piston in the motorcycle GP world was Honda's last 4-cycle stand in the 500cc GPs. The 2 strokes had all but taken over by the late '70s, and early '80s.
The FIM had introduced a limit to the number of cylinders, which for the 500cc GPs was 4.
Honda wanted a V8 - needed a V8 - to compete with the 2 strokes. But they weren't allowed. So they designed and built the oval piston NR500.
The idea of having an oval piston was to enable them to have 8 valves per cylinder, 32 valves all up.
Unlike the VW Diesel oval pistons, the Honda NR500 (and the NR750 road bike) pistons had their long axes parallel to the crank axis. Each piston had two connecting rods too.
There is probably a picture in the Crazy Racing Engines thread.
#10 soubriquet
soubriquet
  • 376 posts
Posted 02 January 2006 - 12:49
There certainly is:
It would have been fun fitting the rings on this. I guess they would be two-part, so I was interested to see that the VW rings are single piece.
#11 Speedman
Speedman
  • 63 posts
Posted 02 January 2006 - 15:01
The System from VW Ovalpiston engine is better as Honda Ovalpiston engine.
The Honda ovalpiston make problems with piston ring.
#12 Halfwitt
Halfwitt
  • 576 posts
Posted 03 January 2006 - 20:13
I've got one question: how is it possible to finish the bores of the cylinders on these engines? :confused:
I've never seen an oval honing tool. Is it possible to do this?
#13 desmo
  • 32,166 posts
Posted 03 January 2006 - 21:52
I suppose one could do a probably poor job of it easily enough with one of those "brush" type hone/glazebreakers. They work reasonably well on brake cylinders and for cleaning the remains of piston sticks from 2-stroke engine bores after the highly technical pretreatment of dilute HCl on a Q-Tip.
#14 McGuire
Posted 19 January 2006 - 11:00
Sure, to bore and hone these cylinders you will need a tool with an orbiting spindle. Shouldn't be terribly difficult but it will be slow.
#15 McGuire
Posted 20 January 2006 - 12:33
To bore and hone cylinders like these you could also use a fixed spindle and orbit the table. Depending on your equipment that might be the easier way. That's how I think I would do it if I got stuck with one. Locate the elliptical centers, fabricate a cam lobe and use it to reciprocate a fixture.
